> How many db do phase nines put out?, Need to know...
nine14cats
post Jan 1 2004, 04:08 PM
Bill Pickering -- 914-6 GT aka....Leeloo
Anyone have first hand experience with the db level of phase nines? Infineon recently instituted a 103 db level with one warning....I have a sub 100 db setup using a 911 banana that I use at Laguna Seca...but I'm hoping to get to play at Infineon with my new exhaust set-up...
Bill P.
KenH
post Jan 1 2004, 05:06 PM
Check out: Http://www.victorylane.com/old/Feb98_Noise.html
Then check:
http://www.quiethorsepower.com/quiet_exhaust.html
Then call and talk to Pete Weber at Quiet Horsepower.
Then pray for no rain on 2/14-15
Ken
nine14cats
post Jan 1 2004, 05:20 PM
Thanks Ken,
I'll check it out.....and yep...I don't want rain....praying already...
Bill P.
ChrisFoley
post Jan 2 2004, 08:13 AM
I am Tangerine Racing
A single Phase 9 on a 4 cylinder will bring sound levels down to less than 95dB. I don't have data on six cyl. applications, but I think you will have no problem.
KenH
post Jan 2 2004, 10:51 AM
Chris - Pete said you may noise numbers on the Phase 10 on 4 cyl 2.0.
Do you ?? - and if so is it mounted at the output of the header combiner box (4:1) or is there a length of pipe between the box and the Phase 10??
Ken
ChrisFoley
post Jan 3 2004, 02:21 PM
QUOTE(KenH @ Jan 2 2004, 11:51 AM)
Ken
What's a Phase 10?
KenH
post Jan 3 2004, 04:49 PM
I am sorry thought you knew. Pete Weber said you were making them. It is the muffler that look like a large coffee can on its side with the "in" at one end, and the "out" 180 degrees rotated at the other end.
May be I have you mixed up with sombody else.
Ken
ChrisFoley
post Jan 3 2004, 04:59 PM
QUOTE(KenH @ Jan 3 2004, 05:49 PM)
Ken
Oh, you mean one of these Quiet Cans:
I didn't know Pete called it a Phase 10.
ChrisFoley
post Jan 3 2004, 05:04 PM
The only sound data I have for these is in a 4-2-1 system that includes a Phase 9 with the Quiet Can attached in series.
Sound readings are typically below 90dB at the track with this setup.
- Lo-Fi Version Time is now: 2nd April 2026 - 01:15 PM
