4 Pages V < 1 2 3 4 >
> Morphenspectra Subwoofer Box, Passenger Footwell Type
morph
post Jun 10 2008, 10:28 PM
Post #41
quality parts builder
lots oh questions
the internal volume i have never quite worked out.
but troy (messix)mentioned a volume once. about .4 cubic ft
depth is 5.25 with the spacer
Frequency Response: 25-2.5K Hz
dual coil 2 ohm 2 ohm, i recomend in series to make one 4 ohm speaker
peak 220 nom 100
these Nakamichi where ment to go in a inclosure, so they have no series # on them they where not ment for resale (IMG:style_emoticons/default/shades.gif)
yes you can get terminals from us
ok rich
that is a four channel amp you have there and old school too.i have the 120 watt verson of that amp and the larger one somewhere in my mess.that series of amp is only 15 watts per channel(total of 60 (IMG:style_emoticons/default/sad.gif) ), but at least builders where honest about there power back then .the speaker in your console looks like it has a single coil speaker.you can switch to a bridgeable amp or get a dual coil speaker from me . call me we can get you hooked up with what you need (IMG:style_emoticons/default/phone.gif) 503-551-6191
Scott
we make this to match any carpet we make
our plug and play box,comes with everything you need to run
if you prefer to get your own woofer then you have a choice of a 8 or(if you dare) a 10 inch spacer
and if you want one here is the evil bay link http://cgi.ebay.com/ebaymotors/ws/eBayISAP...585999&rd=1
and if anyone has any questions feel free to call me @503-551-6191
james
RoadGlue
post Jun 10 2008, 10:31 PM
Post #42
Sonoma County Gear Head
Thanks James!
wilchek
post Jun 10 2008, 11:16 PM
Post #43
I made my own box about 2 years ago that was almost indentical to the one that is being made here. Check it our here
http://www.914world.com/bbs2/index.php?sho...ic=47247&hl
I measured the volume with a displacement method and it was perfect for a 8in sub. The 10 needed way too much volume. I bought the JL 8in audio speaker and have way more bass than I need (this fit in my box as I designed it to fit, but may not fit in other check the specs before you buy it). The car interior volume is very small also. It is very clear and has the right sound. If you want to just piss off your neighbors or show off for the ladies go with the 10 but it will not do much as the volume of the box is too small to allow the speaker to move in and out properly. In regards to speaker location, trust me it only works on the left side due to the contour of the body. If you get the JL audio speaker you will need to order the grills on their web site, about 8 dollars if I remember (link to buy the grills) http://store.jlaudio.com/home.php?cat=255. They are strong enough to stand on, really you could stand on top of these things and they will hold it. So get a grill and you should not have a problem with putting your feet thru it. I actually have my floor mats covering the speaker as well. Bass is non-directions unlike trebal and does not need to be in your face or even be seen. The sound waves go in all directions and will reach your ear, even if the speaker in hidden. I love the sound and would totally recommend this set up.
GringoLoco
post Jun 11 2008, 01:10 AM
Post #44
QUOTE(wilchek @ Jun 10 2008, 10:16 PM) *
What kind of JL Audio sub is that? W1? W3? I went to the JL Audio website and the specs for an 8W3 work with the dimensions Morph posted up above (0.30 ft2 volume and 4.63" mounting depth). I had a pair of 12W3v2's in my last car in a sealed box. Was very impressed with the sound quality and clarity, I'd like to stick with W3's if possible.
RoadGlue
post Jun 11 2008, 01:21 AM
Post #45
The 8W1v2-4 looks like it's a perfect match for the box, though it's not part of the W3 series that you're looking for:
http://www.crutchfield.com/App/Product/Ite...ofer&tp=111
# 8" 4-ohm subwoofer
# metallic-finish polypropylene cone with nitrile-butylene rubber surround
# power range: 35-150 watts RMS
# peak power handling: 300 watts
# frequency response: 28-250 Hz
# sensitivity: 83.86 dB
# top-mount depth: 3-13/16"
# sealed box volume: 0.375 cubic feet
GringoLoco
post Jun 11 2008, 01:36 AM
Post #46
QUOTE(RoadGlue @ Jun 11 2008, 12:21 AM) *
No thanks, I'm sticking with dual voice coils. If I can't get a W3 to work, I'll look at other brands that have an 8" DVC speaker that will. But the more I look at the spec sheet and enclosure requirements on the JL Audio site, the more I'm pretty sure an 8W3 will work. It has the proper mounting depth, volume requirements, etc. The only thing that might not work is if the MDF used isn't thick enough (if the box was designed for a 50watt SVC speaker, there wouldn't be any point in using beefy MDF). That wouldn't be a design problem though, just special order the box with thicker wood. The 8W3v3 only needs 0.30 cubic ft of volume while the 8w1 needs 0.375... weird. The 8w3v3 does need more mounting depth, but still less than the specs Morph posted. Should be good.
RoadGlue
post Jun 11 2008, 01:43 AM
Post #47
Just out of curiosity, why do you want to stick with dual voice coils? Where do you think the big advantage is there for this application? I'm not saying the W1 is better than the W3, but do the differences in design justify the differences in price and power requirements?
Also, the box is fiberglass, not mdf.
GringoLoco
post Jun 11 2008, 05:03 AM
Post #48
QUOTE(RoadGlue @ Jun 11 2008, 12:43 AM) *
I just want more sound. I don't want to go through the expense and work just to get a little low end fill, might as well go big and get some bass out of it (I tend to get used to things quickly and then go overboard, lol). I'm used to 2 12" W3's, I just don't think I'd be satisfied with an 8" W1. Of course, I had my W3's in the trunk of a mid-sized car, and not right next to my feet, so that's going to make a difference that I should account for. I should probably go somewhere and actually HEAR a W1, but I'm just not that optimistic about them. The other thing about DVC subs is you have more options (bridge amp down to 2 ohms, for instance). As for price, 8W3's really aren't that expensive. I'd happily pay a few bucks more for better sound. The W1's probably sound nice, but I'd rather run my system at 30% of its capability than 80% of its capability. An overbuilt system turned down sounds better than a lower powered system turned up.
So.Cal.914
post Jun 11 2008, 08:11 AM
Post #49
"...And it has a front trunk too."
QUOTE(RJMII @ Jun 10 2008, 10:32 AM) *
Make a taller and larger dia. ring spacer. Port the encloser to reliever preasure
and get movement on coil.
Ported enclosures actually have more turbulence/pressure in them. They also require a lot more volume than their sealed counterpart.
The sub off to the left, and James' original designs are actually very good designs. (acoustically speaking)
Thats interesting, I have travel plugs for my Altec 'Voice of the Theater's'. If I forget to take them out of the ports the sound is muffled and reduced until the plugs blow out of the enclosure.
You wouldn't happen to have a link to this info would you?
Allan
post Jun 11 2008, 08:48 AM
Post #50
Teenerless Weenie
This is the combo I was thinking of:
JL Audio 8W0 Sub
and a JL Audio A1200 amp
I can get everything I need to install for under $250.00
Any thoughts?
GringoLoco
post Jun 11 2008, 10:22 AM
Post #51
QUOTE(Headrage @ Jun 11 2008, 07:48 AM) *
JL Audio 8W0 Sub
Any thoughts?
The W0's are supposed to be great speakers, and I've personally punished a set of JL Audio's with great results (not W0's though). I think W0's are discontinued, but you should be able to find them left over stock somewhere. Or as RoadGlue mentioned, 8W1's should be a perfect match for that enclosure, and they're a current model so they might be easier to find. Personally, I'm a little eccentric, and want more thump, so I'm gonna find a way to get an 8w3 to work.
wilchek
post Jun 11 2008, 12:38 PM
Post #52
not sure which one I used it was almost 2 years ago. It was around 100 if that helps. It is all black and has JL on the face
messix
post Jun 11 2008, 02:24 PM
Post #53
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
i've got a rockford 8" single v/c running off 80 watts and it puts out and good thump not a boom, you don't hear much outside the car but it's very good inside as far as listening to music.
it sounds good with rock,country, but not rap/hiphop bass boomer stuff.
Allan
post Jun 11 2008, 10:14 PM
Post #54
Teenerless Weenie
QUOTE(messix @ Jun 11 2008, 01:24 PM) *
it sounds good with country
(IMG:style_emoticons/default/icon8.gif) Where's my electrical gloves?
I gotta slap you with them. (IMG:style_emoticons/default/laugh.gif)
thomasotten
post Jul 2 2008, 10:04 PM
Post #55
Is the subwoofer box available? I didn't see it on Ebay or the website. How much is it?
morph
post Jul 2 2008, 11:40 PM
Post #56
we released this part in the fall of 05. and i built it for a few people for a year b4 that.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=150266503985
here is a link for you
james
ConeDodger
post Jul 3 2008, 01:49 AM
Post #57
Apex killer!
QUOTE(morph @ Jul 2 2008, 10:40 PM) *
james
James,
You really need to find a way to take a good picture of that installed. I waited a couple years before buying it because I had trouble imagining it installed. Of course, if I just lifted my carpet it would have come to me.... But think about it. You and Heidi could have starved man!!! (IMG:style_emoticons/default/biggrin.gif)
RJMII
post Jul 3 2008, 02:06 AM
Post #58
Jim McIntosh
QUOTE(So.Cal.914 @ Jun 11 2008, 08:11 AM) *
Paul,
You know, I have read so many books on audio systems and have been reading online tutorials from (Kicker, JL Audio, Soundstream, etc) for the past 13 or so years, that I've forgotten where I've got most of the information. I wish I had a link for you, it's some pretty interesting stuff.
If I could get L.E.A.P. to work on my computer again w/out having to figure out what is up with my registry this time, I'd be more than happy to send some comparison charts to you.
You can PM me about your travel plugs and ports if you'd like, so we can stay on topic here about morph's nifty enclosures. (I hope nifty is on okay descriptor word, I like what has been done with them.)
GringoLoco
post Jul 3 2008, 03:39 AM
Post #59
james
That looks nice! The question I have, is do you think it would stand up to a JL Audio 8W3? The volume is right, and the mounting depth is right. I just don't have any experience with 'glass enclosures, and know that MDF will shake apart if you don't use thick enough stuff. If it'll handle the pressure an 8W3 puts off, could I special order one without the speaker at a lower price?
james2
post Jul 3 2008, 07:53 AM
Post #60
I have one of these-
http://www.bossaudio.com/main/649
(IMG:http://www.bossaudio.com/main/wsc_content/pics/mediabox/medium/11734605391.jpg)
Keep in mind these in no way compare in quality to what some are selling, but they do work surprisingly well. I had one under the seat of a 77 Cutlass, and provided enough sound pressure to where I could feel the bass.
Cheap also, only about 130 bucks.
I was hoping to find room under the dash in my 914 for it.
QUOTE(messix @ Jun 7 2008, 09:29 PM) *
QUOTE(effutuo101 @ Jun 7 2008, 01:18 PM) *
I have heard of a new "flat" sub woofer. Anybody using them?
smallest i've seen is a 10". too big from the box morph makes, not enough cubic inches.
- Lo-Fi Version Time is now: 2nd April 2026 - 10:44 AM
