| 911quest |
Jan 8 2009, 07:45 PM
Member ![]() ![]() Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
Here is my work in progress a P258c for seting pinion depth.
| Dr Evil |
Jan 8 2009, 07:46 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Here is my work in progress a P258c for seting pinion depth. Ooooooo, interesting (IMG:style_emoticons/default/smile.gif) |
| Todd Enlund |
Jan 8 2009, 07:59 PM
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,252 Joined: 24-August 07 From: Reed (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
| r_towle |
Jan 8 2009, 08:12 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| scotty b |
Jan 8 2009, 08:17 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
some guy on E-bay seveal years ago. I really don't remember who he was. Wish I did, they are very well done. I have gotten some nice bead roller dies and a KILLER hammer from hoosier pattern ( sells on e-bay ). |
| r_towle |
Jan 8 2009, 08:20 PM
I want a plasma cutter...my head hurts thinking about cutting all the plate steel...
Did you end up putting any bracing inside the english wheel frame? Rich |
| scotty b |
Jan 8 2009, 08:24 PM
Yeah most likely overkill as I used 3/8 plate for the outside but I wanted to make sure it didn't flex. Yes German overengineering at werk. Thank my grandparents........
| RJMII |
Jan 8 2009, 11:53 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
(IMG:http://inlinethumb26.webshots.com/43161/2593686280101286046S425x425Q85.jpg)
I took two rear rotors, and two threaded rods and fashioned a spring compressor for the rear shocks. A washer and a nut at each end, and then a couple of turns on one, then a couple of turns on the other... back and forth between the two threaded rods keeping them moving at a constant rate as to keep the pressure even across the brake rotors. |
| wertygrog |
Jan 8 2009, 11:57 PM
wertygrog ![]() ![]() Group: Members Posts: 429 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
here's a super flat 22mm wrench for tensioning a 944 timing belt...made out of a spare e brake handle lol. (IMG:style_emoticons/default/drunk.gif)
| zambezi |
Jan 9 2009, 01:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Heres an engine stand I built for storing and running our 356 engines. Would also work for vw engines, just change the starter if its 12Volt. There is a Harley oil tank converted for a fuel tank in the differential space of the trans, and where the gear sets would be is the fuel pump and filter. LED lights on top of the trans are for oil pressure and ignition (so as not to leave the key in the on position if not running the engine).
| Bartlett 914 |
Jan 9 2009, 08:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Heres an engine stand I built for storing and running our 356 engines. Would also work for vw engines, just change the starter if its 12Volt. There is a Harley oil tank converted for a fuel tank in the differential space of the trans, and where the gear sets would be is the fuel pump and filter. LED lights on top of the trans are for oil pressure and ignition (so as not to leave the key in the on position if not running the engine). Very nice! The lower frame looks like it may have come from an old engine hoist. |
| michelko |
Jan 9 2009, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
My Engine Test stand
![]() and the tool to check fuellevel in zenith carbs ![]() (IMG:style_emoticons/default/smilie_flagge6.gif) |
| aircooledtechguy |
Jan 9 2009, 11:25 AM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Here's my engine run stand and the starter box. The stand fits into my engine stand and uses a VW bus bell housing and starter. I welded up an aluminum 1 gallon fuel tank that's plumbed through an electric pump and pressure regulator.
(IMG:http://images.thesamba.com/vw/gallery/pix/408348.jpg) (IMG:http://images.thesamba.com/vw/gallery/pix/408347.jpg) The starter box just has a oil pressure light and ignition switch and start button. I added a friction throttle so I can hold the RPM I want w/o standing in one place during break-ins. I need to have a mobile box that allows me to cut power and move with me during break-ins as I check for leaks and such because I work alone at my shop. I'd like to re-do it some day and add oil pressure, tach and a CHT gauges. (IMG:http://images.thesamba.com/vw/gallery/pix/408350.jpg) |
| Todd Enlund |
Jan 9 2009, 12:50 PM
| andys |
Jan 9 2009, 02:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
I've got several custom jigs and fixtures, but as far as tools go this is the cheapest, most used, and get the most comfort level from knowing the car won't readily slip off the jackstands.
Andys Attached thumbnail(s) |
| MrKona |
Jan 9 2009, 03:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Here's my transaxle driveshaft holder tool. Keeps the drive shaft from turning so that you can loosen the castle nut without having to engage two gears at once. Scrap metal, JB Weld, and the serrated inner piece from an old clutch disk. (picture was taken on an empty case, no driveshaft on this one.)
Replaces Porsche tool #P37. Haven't ever used it, but someday... Attached image(s)
| roadster fan |
Jan 9 2009, 04:16 PM
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
I've got several custom jigs and fixtures, but as far as tools go this is the cheapest, most used, and get the most comfort level from knowing the car won't readily slip off the jackstands. Andys (IMG:style_emoticons/default/aktion035.gif) I'm gonna make me some of those this weekend....Brilliant! Jim |
| roadster fan |
Jan 9 2009, 04:37 PM
Here is one that I made after having to remove the rear brake calipers and reset the venting clearance about a dozen times. It is just an old flea market wrench and socket welded together so it is easy to hold the ouside adjuster allen bolt while tightening the 13mm nut. I use my ratchet with the allen socket but I have also used a regular "L" shaped allen wrench also.
There is probably a way the pros use but I came up with this. ![]() Jim |
| 914dave |
Jan 9 2009, 05:15 PM
914 Addict ![]() ![]() ![]() Group: Members Posts: 740 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States
![]() ![]() Here's the rotisserie pix's Attached image(s)
| J P Stein |
Jan 9 2009, 07:34 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Wanna check backlash on the R&P of your 901? Hold the crank when installing rods?
Lo-Fi Version | Time is now: 2nd April 2026 - 06:43 AM |
