| Winfield |
Feb 3 2009, 03:58 PM
Newbie ![]() Group: Members Posts: 10 Joined: 3-July 07 From: Warren, New Jersey Member No.: 7,868 Region Association: North East States |
Anyone out there have experience rebuilding weber carbs? I'm thinking of doing this as a winter project but have never attempted it before. My only reference so far is John Passini's book. These are 44mms. I haven't been able to find any info on line and I don't want to screw this up. Thanks in advance for any tips. (IMG:style_emoticons/default/confused24.gif)
| Eric_Shea |
Feb 3 2009, 04:39 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
When I did my 40IDA's I just kept three of those heavy duty paper Chinette bowls in front of me. For you it would be two. Fairly elementary when you look at them one bowl at a time.
Get the Weber book. Amazon. |
| degreeoff |
Feb 3 2009, 04:40 PM
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
I agree nothing to it ...easy if you have ANY mechanical skilzzzzzzzz
Just don't take the shafts out! |
| Winfield |
Feb 3 2009, 04:53 PM
When I did my 40IDA's I just kept three of those heavy duty paper Chinette bowls in front of me. For you it would be two. Fairly elementary when you look at them one bowl at a time. Get the Weber book. Amazon. Thanks, I just went on their site. There are several to choose from. Which do you recommend? Verlon Braden's, Des Hammill or the Haynes? Or buy them all? |
| Ericv1 |
Feb 3 2009, 05:46 PM
Member ![]() ![]() Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
When I did my 40IDA's I just kept three of those heavy duty paper Chinette bowls in front of me. For you it would be two. Fairly elementary when you look at them one bowl at a time. Get the Weber book. Amazon. Thanks, I just went on their site. There are several to choose from. Which do you recommend? Verlon Braden's, Des Hammill or the Haynes? Or buy them all? I have the Haynes and it came in handy. Rebuild one at a time because they're mirror images. If you forget where a piece went, look at the carb that's still together. |
| IronHillRestorations |
Feb 3 2009, 11:09 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Yea, don't take the butterflys off either.
| bperry |
Feb 4 2009, 12:43 AM
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
I like this book. Has useful setup and tuning information too.
Weber Technical Handbook Also, do 1 at a time so you have 1 to look at when you put it back together. If you have the rebuild kit it is usually pretty obvious where the parts go. Here is a set of photos that might help (assuming you have IDFs) IDF setup --- bill |
| VaccaRabite |
Feb 4 2009, 10:11 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
The Weber Tech Book is the one that you want. It is very comprehensive, though I have found it to be kinda poorly laid out and not well indexed. Most of the other Weber books will mention an IDF carb, but thats about it. Even the one with the picture of a bunch of IDFs on the cover (on a Chevy Small Block) only mentions them in passing (dammit!) Most of the stuff is for the sidedraw carbs and progressives. Theory will work, but won't help much for rebuilding. Zach |
| maf914 |
Feb 4 2009, 10:25 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
I have found the Haynes Weber Manual helpful for rebuilding and tuning.
Lo-Fi Version | Time is now: 2nd April 2026 - 07:05 AM |
