| cvoros |
Mar 20 2009, 12:57 AM
Member ![]() ![]() Group: Members Posts: 52 Joined: 24-February 09 From: Huntsville, Texas Member No.: 10,086 Region Association: Southwest Region |
Wondering who knows what rim widths and offsets I can squeeze under the fenders of my 75 2.0L. I have the 4 lug Fuchs at the moment and have been contemplating 5 lug conversion.....but also have been thinking about flares. So I'd like to hear what I can fit in there - stock fenders and what kind of meat flares will accomodate. I like the look with wider rear tires, and want to squeeze as much room out of of the wheel well as possible.
Seeing alot of Fuchs 5 lugs on eBay, etc. as usual and I like the dished ones. Are the replicas any good? i.e. these - http://cgi.ebay.com/ebaymotors/Porsche-All...A1%7C240%3A1318 I obviously wont decide on wheels until I decide whether its getting flares or not but just want to know what I should be on the lookout for. TIA |
| SLITS |
Mar 20 2009, 07:33 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I just put 15 X 7 Cookie Cutters w/ 195/65 tires on. Real close on driver's side of a narrow body rear, but clears.
| jim_hoyland |
Mar 20 2009, 09:20 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Wondering who knows what rim widths and offsets I can squeeze under the fenders of my 75 2.0L. I have the 4 lug Fuchs at the moment and have been contemplating 5 lug conversion.....but also have been thinking about flares. So I'd like to hear what I can fit in there - stock fenders and what kind of meat flares will accomodate. I like the look with wider rear tires, and want to squeeze as much room out of of the wheel well as possible. Seeing alot of Fuchs 5 lugs on eBay, etc. as usual and I like the dished ones. Are the replicas any good? i.e. these - http://cgi.ebay.com/ebaymotors/Porsche-All...A1%7C240%3A1318 I obviously wont decide on wheels until I decide whether its getting flares or not but just want to know what I should be on the lookout for. TIA This seller has been around for a while now and all the feedback is positive. If there were issues, I think you would see it there; I don't recall any negatives on the seller on this board. |
| type2man |
Mar 20 2009, 10:53 AM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I tried 16x7's on the back of my 74 and was able to do so with a 205/50/16. Personally, I wouldnt buy aftermarket alloys, they are heavier and have no resale value. For the same price or less you can find early ones and refurbish them yourself.
| Racer |
Mar 20 2009, 07:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I'm sure there are a buch of threads but I'll try to summarize that the real issue is the rear fender.
Widths that "should" fit with little to no work: 5.5" 6.0" 6.5" With a little more work: 7" 8" (ok, some will day this is a LOT of work (IMG:style_emoticons/default/wink.gif) ) With Flares.. up to likely 10" The fronts will fit 7"s easily before flares are really needed. With flares.. 9" The issue with replicas is the unkown quality. For street driving they should be fine. For something where repeated g-forces and heat come into play (like track driving) i would stay away from them. While appearance always plays into this, a stock motored car running 205-50-15s has MORE than enough grip, especially given modern tire technology. Porsche Fuchs offsets, iirc 6" - 23.3mm 7" - 23.3mm 8" - 23.3mm (for the 1986 951 part numbered wheel) 8" - 10.6mm (for the 911 part numbered wheel) 9" - 15mm "late" offset Porsche wheels, are in the 50-60mm range. |
| cvoros |
Mar 21 2009, 04:08 AM
I tried 16x7's on the back of my 74 and was able to do so with a 205/50/16. Personally, I wouldnt buy aftermarket alloys, they are heavier and have no resale value. For the same price or less you can find early ones and refurbish them yourself. Guess I just havent seen many originals for under $300, although I dont need them right away so I have time to look around for a good deal. |
| cvoros |
Mar 21 2009, 04:16 AM
Racer, thats great info! Exactly what I was looking for. Much appreciated!
My biggest dilemna is thinking about tearing up my current 2.0L. Its in decent enough shape that it would almost be a shame to modify it that extensively. Would be nice to find one already "molested" but chances are something with a bigger motor/flared already will likely be set-up with wider tires. Thank you (IMG:style_emoticons/default/biggrin.gif) |
| Racer |
Mar 21 2009, 05:47 PM
I would say keep it stock or find one already built the way you would like. No point in molesting another one (IMG:style_emoticons/default/wink.gif)
| 914junkie |
Mar 21 2009, 06:23 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 14-December 08 Member No.: 9,848 Region Association: None |
Before I went to a widebody, I had 16X7 Fuchs with 225/50/16's all the way around on the stock body but it was tight. 225/45/16's should fit better but still a little tight. Prolly have to pull em slightly. Maybe 215's? 205's no prob.
| cvoros |
Mar 31 2009, 07:57 AM
Racer : I am starting to lean that way I think. I would hate to tear up a good (mostly) stock 914. Besides going widebody I have contemplated a WRX transplant as well but I'm sure there's a widebody 6, WRX, V8 set-up how I would ultimately like to have done that someone is/will be ready to part with.
http://www.camp914.com/cars/orange1-16-08.html WOULD'VE BEEN PERFECT! Junkie : I have the 4lug Fuchs currently with 205/55/15's with 1 3/4" clearance up front and 3/4" rear. It looks OK but I like a little meatier tire. |
| Joe Ricard |
Mar 31 2009, 09:19 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Racer, thats great info! Exactly what I was looking for. Much appreciated! My biggest dilemna is thinking about tearing up my current 2.0L. Its in decent enough shape that it would almost be a shame to modify it that extensively. Would be nice to find one already "molested" but chances are something with a bigger motor/flared already will likely be set-up with wider tires. Thank you (IMG:style_emoticons/default/biggrin.gif) I'll be putting the yellow car pictured in my avatar for sale soon. it fits a 15 x 10 rim with 285 wide tires. ALL AROUND. |
| Shade Tree |
Mar 31 2009, 09:54 AM
Member ![]() ![]() Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I tried 16x7's on the back of my 74 and was able to do so with a 205/50/16. Personally, I wouldnt buy aftermarket alloys, they are heavier and have no resale value. For the same price or less you can find early ones and refurbish them yourself. Guess I just havent seen many originals for under $300, although I dont need them right away so I have time to look around for a good deal. The deals are out there. I bought two 15X6 fuchs in real nice shape for $10 each about a month ago and last weekend I bought the other two wheels plus a 911 front suspension, a used front spoiler and a complete set of heater parts for $300. The guy doesn't appear to have any full sets of wheels....maybe some 16's but if you only need one or two, I can give you a phone number. edit: almost forgot. I got a passenger long in the deal too! |
| gothspeed |
Mar 31 2009, 10:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I just bought a very clean 1973 with near perfect body ............ and yes I will be cutting it up and putting steel flares on it (IMG:style_emoticons/default/biggrin.gif)!!!
It would have been nice to find one already done but controlling the quality level oneself is very gratifying ..... (IMG:style_emoticons/default/w00t.gif) !!! |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:59 PM |
