> How to restore glass
sixaddict
post Aug 5 2009, 09:42 AM
Newly painted car has glass with apparent water spots that seem permanent. There must be a trick........So how can I revitalize glass so it looks as nice as the paint. Thanks,
Terry
Heeltoe914
post Aug 5 2009, 02:58 PM
Great Question ????
Krieger
post Aug 5 2009, 10:21 PM
I just went through this with a side window I just bought. I tried all the common ones like vinegar CLR, something else I bought at the supermarket. I tried something like turtle wax. Nothing worked. I got a product called AMAZ clean and green water stain remover at Ace Hardware. It is a mild abrasive. It took 4-5 applications and a ton of elbow grease to get them off, but it worked.
turboman808
post Aug 6 2009, 11:51 AM
I bought a glass cleaning system from griots. It does a pretty good job but if it's got serious pitts in it you might not be able to repair it.
I was able to remove etching from dirt and the wipers.
70Sixter
post Aug 6 2009, 12:16 PM
Eastwood has a polishing kit.
http://www.eastwood.com/home
Katmanken
post Aug 8 2009, 01:27 PM
You haven't seen me if anybody asks...
Ya sure those spots are water?
If you splash Ospho deruster or another strong acid on glass, it will etch it.
jimmybryan
post Aug 8 2009, 03:33 PM
Hello Terry,
Fellow noob Jim here. Years ago I sold a product for that, Phantom Chrome and Glass Clnr, I'm no longer afilliated but I did a quick search and found it here, you may find it closer to home if you do a more detailed search .........
http://www.highwayshine.com/dbID/459.html;
It was basically jewler's rouge and alcohol, I can attest to it's ability to polish normal glass surfaces but never tried it on anything that was etched.
I think I'd first try a fresh razor scraper (like your mechanic uses to remove inspection stickers) to decide if it's a surface deposit or etch. If it's on the surface I've also heard of using #0000 steel wool with soapy water. Just don't use scotch brite pads (don't ask me how I know (IMG:style_emoticons/default/huh.gif) ).
sixaddict
post Aug 18 2009, 01:02 PM
Some great help here....Thanks !! Sorry just realized I posted this in the wrong forum.....I will report results.
TOT
sixaddict
post Aug 25 2009, 03:46 PM
Great results !
I took the cheapest route to see if it would work. i.e Trying JimmieB's suggestion for Phantom Chrome and Glass cleaner but had to resort to 0000 steel wool
( which is secondary instruction if cloth doesn't work). Tried on rear window and it did a good job. The glass is sparkling answering my proverbial question....how did he get those windows so clean. Went to highway shine web site ....pretty painless.
Thanks again to all who contributed........Spending so much on this baby I decided to try cheap angle and finally got to one that worked.
TOT
PRS914-6
post Aug 26 2009, 08:42 AM
Excellence Magazine Project 914 3.6
Group: Retired Members
There is a product called Nothin's Better and at least out west you can find it at auto parts stores and hardware stores. It's inexpensive and works great. It's a powder you use on a damp cloth. I have even used it to clean entire shower doors with my electric buffer. Great product for the money.
Sleepin
post Aug 26 2009, 09:18 AM
I have heard recommendations of using Bartenders Friend. It is similar to AJAX but less abrasive.
underthetire
post Aug 26 2009, 11:03 AM
QUOTE(esses62 @ Aug 25 2009, 08:35 PM) *
Just use oxy clean and a sham wow (IMG:style_emoticons/default/happy11.gif)
Hey, found a use for that Sham-Not-So-Wow ! They soak up spilled coffee under your feet AWESOME. (IMG:style_emoticons/default/headbang.gif)
Drums66
post Aug 26 2009, 03:45 PM
914 Rudiments
QUOTE(sixaddict @ Aug 25 2009, 02:46 PM) *
Great results !
TOT
00 fine steel wool! (IMG:style_emoticons/default/idea.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 07:21 AM
