| kkid |
Jan 30 2010, 11:29 AM
Member ![]() ![]() Group: Members Posts: 362 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hello folks,
One of my projects for this year is to have a (IMG:style_emoticons/default/hissyfit.gif) LEAK (IMG:style_emoticons/default/hissyfit.gif) free battery. I have looked at Optima and Odyssey and I see many members here use Optima. But I am tempted to go to Braille since it weighs much lesser. I am currently looking at this particular one: http://www.braillebattery.com/index.php/batteries/b2317r/ So let me hear what you folks think. Any comment would be appreciated. (IMG:style_emoticons/default/pray.gif) |
| patssle |
Jan 30 2010, 11:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
| plymouth37 |
Jan 30 2010, 11:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
| tod914 |
Jan 30 2010, 11:56 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Looks like all the mounts require drilling :S.
| Chris Hamilton |
Jan 30 2010, 02:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
I've had a few batteries from Braille and not had very good luck with them. I would not recommend them. 2 x 6lbs ones stopped charging and a larger one cracked and started leaking.
I would also recommend that you check out Deka batteries as they have a few that look identical to the braille, I suspect braille is just taking those and relabeling them. I do however like the optima yellow top batteries. I have a few of those that have lasted more than 10 years, and only one failure out of the 7 that I've bought. |
| 70Sixter |
Jan 30 2010, 04:26 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
I've got the 17 lb version and so far so good. Since summer. Brass terminals and mountable on its side - which I did. No racing or tracking. But my CG probly went done an .001 mm or so. (IMG:style_emoticons/default/smile.gif)
Comes with plastic mount, or aluminum version for racing. About $80 for the metal secure mount IIRC. I don't have any electronics besides OEM radio. Bought mine from TireRack. |
| kkid |
Jan 30 2010, 06:31 PM
I've had a few batteries from Braille and not had very good luck with them. I would not recommend them. 2 x 6lbs ones stopped charging and a larger one cracked and started leaking. I would also recommend that you check out Deka batteries as they have a few that look identical to the braille, I suspect braille is just taking those and relabeling them. I do however like the optima yellow top batteries. I have a few of those that have lasted more than 10 years, and only one failure out of the 7 that I've bought. Thanks for the comment, Chris. How did all the crack and leak happen to your larger Braille? Hope those were covered by warranty. I might want to pass Deka since it's not popular among the 914 world. I would take the red top(35) if Optima. The yellow top is lighter and more compact than the other but I don't think it will clear the rain tray. How's yours? BTW, are you running a shop in Berkeley? |
| Chris Hamilton |
Jan 30 2010, 10:50 PM
I'm not sure how the crack happened, my friend had it mounted in his S2000.
You should be able to get the yellow top in any size they make the red top in ( including a nice small one that's like 30-35lbs ), and the yellow top is a deep cycle so you can't hurt it by running it down and charging it a bunch. Not running a shop, I just have a bunch of 914s and help my friends with theirs. My dad is a ( mostly ) retired race engine builder. btw you should come out to the first PCA autocross at Alameda on March 20th. I'll be co-chairing that one and it should be a great event. |
| rascobo |
Jan 31 2010, 01:01 AM
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
I have to agree with Chris. The Optima Yellow Top is vastly superior to the Red Top. Over the years I;ve gone through 3 or 4 of the Reds,they seemed to fail between 1 and 3 years (they don't much like to be charged), I got a Yellow Top five years ago and still going strong. I thought I'd have to sacrifice cranking power (running a GM 4.3V6), 15-20 yrs back there was a considerable difference but not anymore.
| kkid |
Feb 1 2010, 02:47 AM
I've got the 17 lb version and so far so good. Since summer. Brass terminals and mountable on its side - which I did. No racing or tracking. But my CG probly went done an .001 mm or so. (IMG:style_emoticons/default/smile.gif) Comes with plastic mount, or aluminum version for racing. About $80 for the metal secure mount IIRC. I don't have any electronics besides OEM radio. Bought mine from TireRack. Yeah, TireRack offers a great deal on this one. It comes with a mounting kit which is $19.99 if bought directly from Braille. I am still dreaming about having this one. Can you post the pic of the battery installed please? And amaze us how small it is. Thanks! |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:04 AM |
