| bandjoey |
Feb 7 2011, 04:48 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
On the other thread on Ethanol, several people said to use octane booster and Stabil.
If you use these.....POST how much of each and when you use these? Every tank, Once a Month, Etc. Also if you have a magic concoction you invented and are happy with...share the magic with us. (IMG:style_emoticons/default/idea.gif) Thanks from all of us. Bill |
| underthetire |
Feb 7 2011, 04:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Seafoam in the boat and bikes. I bottle in the boat. 914 is FI, so i don't worry about it.
| yeahmag |
Feb 7 2011, 05:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Stabil Marine to fight off the corrosion of effects of ethanol. That's it for a carb car.
| pete000 |
Feb 7 2011, 07:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I like Amsoil PI
| john rogers |
Feb 7 2011, 08:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I used to use a medicine cup of Marvel Mystery Oil with each tank in both the street 914 and the race car and never had any snot buildup issues in the carbs or FI system.
| URY914 |
Feb 7 2011, 08:35 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,067 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I use Marvel Mystery Oil in my DD truck at every fillup.
| Root_Werks |
Feb 8 2011, 11:55 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,929 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Stabil Marine to fight off the corrosion of effects of ethanol. That's it for a carb car. (IMG:style_emoticons/default/agree.gif) Use this in my carb'd Type3. I don't use anything in the FI 914, no need that I have seen. |
| mgphoto |
Feb 8 2011, 12:01 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Marvel Mystery Oil, 4 oz in the tank at each fill up and 6 oz added to the oil at change time.
338,000 miles and counting. Mike |
| bandjoey |
Feb 8 2011, 12:21 PM
| avidfanjpl |
Feb 8 2011, 04:16 PM
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I add 2 oz of marvel mystery oil to every Brad Penn oil change at 3k and adjust the valves. I dump 4 oz in every other tank of 91 octane, and Stabil in every 4th tank.
I swear the engine sound quieter when I add the Marvel. Sahara Beige Steve taught me that, and it is marvelous stuff. NPI John |
| underthetire |
Feb 8 2011, 04:19 PM
Mystery oil is great stuff, however it's not a storage solution any longer. The fuel will still separate just as fast as without it. Even the Stabils/seafoams/ whatever will only prolong it. Just the way it is now.
| '73-914kid |
Feb 8 2011, 05:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Shot glass of Marvel Mystery oil in every tank of gas.. I've never had any issues with fuel creating a varnish on the carbs after over a years of daily driving..
| bmtrnavsky |
Feb 8 2011, 09:16 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
I put 4oz of marvel mystery oil to my fuel at each fill up and 2oz to each brad Penn oil change.
Same routine on my model A Ford. On my toyota I run sea foam occasionally in the fuel, oil, and intake via the power brake vaccine line. What line would you use to do this on the 914? First time I did it my cars blew white smoke for days, but they ran much quieter after I was done. |
| Black22 |
Feb 8 2011, 09:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I used to use Marvel Mystery Oil when rebuilding my pneumatic tools. I just put some in my 914 for the first time and it was NOTICEABLY quieter after one trip around the block!!! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/piratenanner.gif) Also put a shot of Stabil in the tank.
| mgphoto |
Feb 9 2011, 03:36 PM
Marvel Mystery Oil, 4 oz in the tank at each fill up and 6 oz added to the oil at change time. 338,000 miles and counting. Mike Do you add it to the oil just before changing the oil running or shut down, 100 miles early, etc?? Thanks Hello, Reduce the regular lubricant by 6 oz and use 6 oz of Marvel Mystery, I burn a 1/2 pint of oil every 1500 miles, top it off at fill ups. |
| 914Sixer |
Feb 9 2011, 08:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Octane Booster from dollar store. I bottle to each tank. $1 per bottle
| TheCabinetmaker |
Feb 9 2011, 08:41 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I just use real gas. One of the advantages to living in Okiehoma.
| Rocky |
Feb 9 2011, 09:54 PM
From the cockpit ![]() ![]() Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
Marvel Mystery Oil in the 914, the BMW boxer, on my bicycle chain, guns the dogs food.... you name it! Good as WD 40!
| yeahmag |
Feb 10 2011, 11:12 AM
| orange914 |
Feb 10 2011, 11:22 AM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
techron additive checked out good, i didn't see marvel on the list??? |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:30 AM |
