| 914World |
Jul 22 2011, 01:55 PM
Member #1 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None
If you have a 914 that needs parts, I most likely have them. I will be having a parts sale tomorrow, the 23rd between 9 and 1.
The sale will be held at: 401 Rt 35 Red Bank NJ 07701. (look for the white sign with red lettering that reads "landscaping equipment sale") All parts are in great like new condition. I have no pictures so please do not email me asking for pictures, and I will not be available today to show anyone the parts stash before the sale. Prices are fair and firm. The list is laid out as follows: Item #... Part Description... Quantity... Price 1 Transmission 3 $400 2 Targa Tops 4 $75 3 Front Bumper 1 $250 4 Rear Bumper 1 $250 5 Rear Hood 1 $300 6 Alloy Wheels 4 $125 7 Alternators 2 $50 8 Front Fender 2 $75 9 Passanger Door 1 $200 10 Left Rear Quarterpanel 1 $125 11 Wiper Motor Assembly 2 $75 12 Headlight Motor 6 $50 13 Front-End Assembly 1 $500 14 Front Valance Pan 2 $50 15 Rear Valance Pan 2 $40 16 Regulator Plate 4 $45 17 Starter Motor 3 $75 17 Starter Motor 3 $75 18 Steering Rack 1 $200 19 Inner Door Panel 2 $40 20 Steering Wheel 2 $50 21 Door Handles - Outer 2 $40 22 Steering Column - w/Key 1 $75 23 Voltage Regulator 3 $15 24 Armrest Plastic Tray 2 $25 25 Armrest Cover - Drivers Side 2 $20 26 Instrument Gauge Panel Holder 1 $15 27 Pedal Assembly 1 $100 28 Fog Light Lamps 1 $60 29 Headlight Relays 0 $15 30 Fuel Tank Sending Unit 4 $50 31 Side View Mirrors 2 $125 32 Plastic Headlight Covers 3 $15 33 Fuel Tank Overflow 2 $20 34 Brake Fluid Resevouir w/Cap 1 $20 35 Rear Interior Back Bulkhead 2 $75 36 Sunvisors 6 $30 37 Front Bumber Strip 1 $175 38 Headlight Switch 4 $50 39 Fog Light Switch 3 $15 40 Hazzard Flasher Switch 3 $35 41 Drivers Door Pocket - Arm Rests 2 $25 42 Steering Wheel Horn Pad 2 $40 43 Interior Rollbar Trim 2 $10 44 Front Hood Latch - Lock/Catch 3 $20 45 Tachometer 3 $50 46 Bumper Support -> Dog-Bone Mounts 6 $20 47 Middle Seat Cushion 2 $25 48 Door Stops 4 $50 49 Lower Dashboard Panels 4 $45 50 Fuse Box Panel 2 $25 51 Headlight Motor Covers 4 $15 52 Spare Tire Trunk Board 2 $25 53 Turn Signal Relay 2 $20 54 Ash Tray 1 $25 54 Ash Tray 1 $25 55 Headlight Cover Trim 4 $15 56 Front Hood Latch - Upper 2 $25 57 Rear Trunk Latch - Lower 2 $15 58 Gear Shifter 2 $15 59 Expansion Tank 2 $55 60 Rear Liscense Plate Lite 2 $15 61 Engine Cover Latch 1 $25 62 Foot Well -> Right Side 3 $15 63 Rear View Mirror 2 $100 64 Engine Lid Drip Pan 2 $50 65 Front Hood Hinges 4 $10 66 Non-Fog Light Grilles 1 $5 67 Interior Light Assembly -> Clear 3 $10 68 Engine Mount Bar 1 $50 69 Rear Glass - Heated 1 $50 70 Rear Glass - Plain 1 $30 71 Sun Visor Brackets 2 $20 72 Turn Signal Indicator/Switch 1 $50 73 Speedometer 2 $70 74 Fuel Gauge 2 $30 75 Rear Hood Hinges 4 $15 76 Oil Cap 1 $8 77 Inner Door Latches 2 $15 78 Emergency Brake Handle 1 $25 79 Rear Trunk Cups 2 $10 80 Ignition Coil 1 $10 81 Rear Trunk Lock - w/o key 2 $35 82 Engine Lid Grill -> Both Sides 2 $15 83 Engine Lid grill -> Main 3 $25 84 Seat -> No Bottom 1 $95 85 Seat -> Bottom 3 $25 86 Rubber Shock Caps -> Rear 5 $5 87 Window Cranks 2 $10 88 Flasher Relay 2 $30 89 Headlight Relay -> High/Low Beam 2 $20 90 Door Vent Window 3 $15 91 Door Window 2 $50 91 Door Window 2 $50 92 Front Parking Light Assembly w/o Lens 2 $25 93 Black Plastic Wheel Caps -> Set of 4 4 $5 94 Front Bumper Guards 4 $35 95 Heat Control Lever w/Red Knob 1 $17 96 Side Marker Lights -> w/o Lens 2 $10 97 Targa Top -> Plastic Holding Clips - Rear Trunk 3 $10 98 Wiper Arms -> no blades 2 $20 99 Targa Roof Latch in Roll Bar 2 $20 100 Inner Door Handle Cover Plates - BlackPlastic 2 $5 101 Engine Lid Lock 1 $10 102 Door Butt Stricker 1 $10 103 Gas Cap 4 $10 104 Defrost/Air Vent Console Controls 1 $25 106 Interior Door Handle Armrest -> Passenger Side 2 $30 107 Windschield Pillar Post Interior Trim 2 $30 108 Targa Top Rear Clip 2 $10 109 Right Rear Tail Light Assembly - w/o Lens 1 $65 110 Horns 3 $10 111 Cover Tray Under Steering Rack 1 $25 112 Headlight Eyebrows 4 $10 113 Front Trunk Latch 1 $10 114 Headlight Carrier 6 $25 115 Rear Trunk Light 2 $15 116 Front hood Lock Cable w/o Key 1 $50 117 Center Console Base Plate 1 $30 118 Glovebox Door 1 $25 119 Adjustable Seat Track 1 $20 Come and see what you might need for your 914!
Lo-Fi Version | Time is now: 2nd April 2026 - 11:56 AM |
