> 914World Classifieds Rules
> FS: 5-lug parts, 911 front suspension, full boxster caliper conversion, *Prices Reduced*
bixs
post Aug 10 2011, 07:25 PM
I bought my 914 a few months ago and immediately started collecting parts for 5 lug conversion + 911 front suspension + boxster calipers. After working on the car extensively to get it moving around, I've had a change of heart on the current direction I'd like to take it. So here are all of the parts I collected on my garage shelf.
I accept Paypal and prefer it.
Will combine shipping when needed. If you would like to make an offer on a package deal or just single listings, send a PM. I will consider all reasonable offers.
Pictures here (ask for specific pictures and I'll add them):
http://www.flickr.com/photos/58832619@N04/...57627280877435/
two 16x6 and two 16x7 Boxster wheels $500 $475
-EXCELLENT condition. These fit my 914 with no spacers, your experience may differ depending on tire size.
-Old tires included, A LOT of tread, but can't recommend for long use. Was only planning on using for short term use, DOT date 2002.
-Tires are 205/55/16 and 225/50/16
-16x6 ET50 996.362.112.00
-16x7 ET40 996.362.114.00
L/R 911 3.5" Caliper spacing BOGE struts $350 $325
-Great condition. I was told that the inserts might need to be replaced, but I haven't tried them out.
-911.341.041.03
-911.341.042.03
two inner front bearings (SKF), two outer bearings (FAG), two seals (Elring Klinger)
-All brand new in box
$40 SOLD
x20 Aftermarket Alloy Lug nuts (Ralph Boothe) Satin finished - SOLD
Brakes
Used ATE 23mm Master Cylinder
$105 $95
Used Boxster Calipers, Fronts and Rears
-Comes with used pads/hardware, condition looks good but unknown
-986.351.421/422 (F)
-996.352.421/422 ®
$675 $625
Brand new 3.5" front to boxster caliper adapters
and brand new stock 914 to boxster caliper adapters
-Brand new from a914guy (Rich)
-Bolts still wrapped up
$400
Calipers + Adapters: $950
*Following rotors are to be used with boxster calipers
two Rear Rotors, 70-83 911 vented, 20mm wide
$60 $55 SOLD
strawman
post Aug 11 2011, 12:18 AM
Are you certain the torsion bars are 20mm and not the stock 18.8mm ones? If so, I will take 'em. I will PM you...
apexhound
post Aug 11 2011, 01:56 AM
I'll take the hubs and matching bearings.
PM sent.
bixs
post Aug 16 2011, 05:53 AM
Bump. If you are looking to get several pieces I am willing to take off quite a bit!
Just found out I need to rebuild my engine before I put it back it, and looking to get this stuff sold so I can spend more on this addiction (IMG:style_emoticons/default/screwy.gif)
bixs
post Aug 22 2011, 06:24 AM
Monday Bump! Prices Reduced
Harpo
post Aug 22 2011, 07:22 PM
Good evening
Do you have any photos the calipers you could post? are you willing to seperate and sell me the rears?
Thanks
David
QUOTE(bixs @ Aug 10 2011, 05:25 PM) *
-911.341.041.03
-911.341.042.03
L/R 911 930 A-Arms $150 $125
-Very beefy, great condition. See pictures
-Tears in ball joint boots from previous seller's removal
two 20mm front torsion bars for the 911 splines $50 $45
-fairly good condition, surface rust
two torsion bar adjusters 911 splines $30 $25
-good condition
Aluminum 911 crossmember $100 $90
81 911 sc steering tie rods $20 $15
81 911 sc front sway bar 20mm - undercar $15 $10
81 911 sc front hubs $115 $105
-studs in good shape, comes with center nut, comes with rotor nuts/bolts
$40
Brakes
$105 $95
-996.352.421/422 ®
$675 $625
$400
$60 $55
- Lo-Fi Version Time is now: 2nd April 2026 - 11:24 AM
