| Davey Cracker |
Oct 19 2011, 12:59 AM
Newbie ![]() Group: Members Posts: 3 Joined: 2-August 11 From: Ca Member No.: 13,384 Region Association: None |
I just got some of the black plastic speaker enclosures that mount to the kick panels
and I need speakers for them.. Can anyone tell me what size speakers I should look for? The grills seemed to be shaped like a 6x9, but I think that size would be to large? Thank you for any info, Dave |
| ptravnic |
Oct 19 2011, 07:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None
I just got some of the black plastic speaker enclosures that mount to the kick panels and I need speakers for them.. Can anyone tell me what size speakers I should look for? The grills seemed to be shaped like a 6x9, but I think that size would be to large? Thank you for any info, Dave If they are the stock enclosures, they fit 4x6. If you want to modify but still keep a rather stock look, a member vendor sells a fiberglass enclosure that mounts in the stock location but will allow for larger, but round, speakers. Do a search and you'll find a ton. Here's the website: 914 Appearance & Performance Good luck. -pt |
| cobra94563 |
Oct 19 2011, 09:22 AM
Chris ![]() ![]() Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I put some inexpensive 5x7 but had to trim some of the frame of the speaker to get it to fit.
| underthetire |
Oct 19 2011, 09:24 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I made a MDF adapter plate, painted it flat black and put some 4 1/2 panasonic 2 ways in. Lots of ways to skin that cat.
| andys |
Oct 19 2011, 09:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
The PO put in 5x7's. The holes didn't quite line up, so he used some sheet metal screws and managed to bugger-up the threaded brass inserts. From looking at speaker choices, it really depends on the stamped metal frame of the speaker. The 5x7's with a square'ish type frame will not fit, however the ones with the more rounded frame seem ok.
Andys |
| JmuRiz |
Oct 19 2011, 10:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
I used some 4x6 Infinity Kappa plate speakers...seem to do the trick. I also have some of the 6.5" pods I have yet to install...probably because I usually just listen for things that sound wrong with my car, haha.
| Valy |
Oct 19 2011, 11:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
$50 and you're set.
See how I did it here And you're lucky since the speakers are still available http://www.ebay.com/itm/NEW-Clarion-SRC579...fc#ht_606wt_872 |
| Davey Cracker |
Oct 20 2011, 11:36 PM
$50 and you're set. See how I did it here And you're lucky since the speakers are still available http://www.ebay.com/itm/NEW-Clarion-SRC579...fc#ht_606wt_872 Thank you for your responses everyone. (IMG:style_emoticons/default/beerchug.gif) Valy, thanks for the info and link.. My question is how do they sound? I know it's pretty subjective, but I wonder if you get anything besides highs from them? Any mid/bass at all from them? Also, do they have built in crossovers? Thanks again! Dave |
| cwpeden |
Oct 21 2011, 12:10 AM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I know its off topic but I have a pair of these mounted under the front of the seats facing forwards. 8 years and they still sound good.
http://www.walmart.com/ip/Pioneer-TSX200-S...3#ProductDetail Also have 4x6's in the kick panels but have ripped out the heater tubes and therefore took out those speakers. |
| Valy |
Oct 21 2011, 12:15 AM
$50 and you're set. See how I did it here And you're lucky since the speakers are still available http://www.ebay.com/itm/NEW-Clarion-SRC579...fc#ht_606wt_872 Thank you for your responses everyone. (IMG:style_emoticons/default/beerchug.gif) Valy, thanks for the info and link.. My question is how do they sound? I know it's pretty subjective, but I wonder if you get anything besides highs from them? Any mid/bass at all from them? Also, do they have built in crossovers? Thanks again! Dave There is a crossover between the twitter and the bigger speaker. They sound very nice compared to anything else that I've seen. It has a metal membrane so it can push relatively nice bass, but remember that those are not subs. I'm very impressed with their performance. Keep in mind that those were over $200 few years ago and go for cheap only because model change. The problem with the car is that the wind will kill any sound system you may have. I use my radio mainly for bluetooth with my phone and GPS and I can hear the GPS clearly at any speed. I can also hear the phone clearly but no one can hear me above 40-50mph. I'm 100% sure that you won't find anything better than these for the stock grill, regardless of the price. |
| johannes |
Oct 21 2011, 02:35 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
See how I did it Here ... Every easy to find 4x6 speaker will fit with the help of a bit of cardboard.
http://www.914world.com/bbs2/index.php?showtopic=54611 Yes, it works ! |
| underdog |
Oct 21 2011, 08:12 AM
Member ![]() ![]() Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
I just got some of the black plastic speaker enclosures that mount to the kick panels and I need speakers for them.. Can anyone tell me what size speakers I should look for? The grills seemed to be shaped like a 6x9, but I think that size would be to large? Thank you for any info, Dave The size is 4"x6". |
| andys |
Oct 21 2011, 09:57 AM
What's the screw thread size of the brass inserts in the plastic housing?
Andys |
| Davey Cracker |
Oct 21 2011, 11:57 PM
Thank you for all your help everyone.
Lo-Fi Version | Time is now: 2nd April 2026 - 07:37 AM |
