> Speaker size for enclosures?
Davey Cracker
post Oct 19 2011, 12:59 AM
I just got some of the black plastic speaker enclosures that mount to the kick panels
and I need speakers for them.. Can anyone tell me what size speakers I should look for? The grills seemed to be shaped like a 6x9, but I think that size would be to large?
Thank you for any info,
Dave
ptravnic
post Oct 19 2011, 07:36 AM
QUOTE(Davey Cracker @ Oct 19 2011, 01:59 AM) *
Dave
If they are the stock enclosures, they fit 4x6. If you want to modify but still keep a rather stock look, a member vendor sells a fiberglass enclosure that mounts in the stock location but will allow for larger, but round, speakers.
Do a search and you'll find a ton. Here's the website: 914 Appearance & Performance
Good luck.
-pt
cobra94563
post Oct 19 2011, 09:22 AM
Chris
I put some inexpensive 5x7 but had to trim some of the frame of the speaker to get it to fit.
underthetire
post Oct 19 2011, 09:24 AM
I made a MDF adapter plate, painted it flat black and put some 4 1/2 panasonic 2 ways in. Lots of ways to skin that cat.
andys
post Oct 19 2011, 09:50 AM
The PO put in 5x7's. The holes didn't quite line up, so he used some sheet metal screws and managed to bugger-up the threaded brass inserts. From looking at speaker choices, it really depends on the stamped metal frame of the speaker. The 5x7's with a square'ish type frame will not fit, however the ones with the more rounded frame seem ok.
Andys
JmuRiz
post Oct 19 2011, 10:55 AM
I used some 4x6 Infinity Kappa plate speakers...seem to do the trick. I also have some of the 6.5" pods I have yet to install...probably because I usually just listen for things that sound wrong with my car, haha.
Valy
post Oct 19 2011, 11:22 AM
$50 and you're set.
See how I did it here
And you're lucky since the speakers are still available
http://www.ebay.com/itm/NEW-Clarion-SRC579...fc#ht_606wt_872
Davey Cracker
post Oct 20 2011, 11:36 PM
QUOTE(Valy @ Oct 19 2011, 10:22 AM) *
$50 and you're set.
Thank you for your responses everyone. (IMG:style_emoticons/default/beerchug.gif)
Valy, thanks for the info and link.. My question is how do they sound? I know it's pretty subjective, but I wonder if you get anything besides highs from them? Any mid/bass at all from them?
Also, do they have built in crossovers?
Thanks again!
Dave
cwpeden
post Oct 21 2011, 12:10 AM
Great White North, huh?
I know its off topic but I have a pair of these mounted under the front of the seats facing forwards. 8 years and they still sound good.
http://www.walmart.com/ip/Pioneer-TSX200-S...3#ProductDetail
Also have 4x6's in the kick panels but have ripped out the heater tubes and therefore took out those speakers.
Valy
post Oct 21 2011, 12:15 AM
QUOTE(Davey Cracker @ Oct 20 2011, 10:36 PM) *
$50 and you're set.
Thanks again!
Dave
There is a crossover between the twitter and the bigger speaker.
They sound very nice compared to anything else that I've seen. It has a metal membrane so it can push relatively nice bass, but remember that those are not subs.
I'm very impressed with their performance. Keep in mind that those were over $200 few years ago and go for cheap only because model change.
The problem with the car is that the wind will kill any sound system you may have.
I use my radio mainly for bluetooth with my phone and GPS and I can hear the GPS clearly at any speed. I can also hear the phone clearly but no one can hear me above 40-50mph.
I'm 100% sure that you won't find anything better than these for the stock grill, regardless of the price.
johannes
post Oct 21 2011, 02:35 AM
Club Porsche 914 France member since 2005
Region Association: France
See how I did it Here ... Every easy to find 4x6 speaker will fit with the help of a bit of cardboard.
http://www.914world.com/bbs2/index.php?showtopic=54611
Yes, it works !
underdog
post Oct 21 2011, 08:12 AM
QUOTE(Davey Cracker @ Oct 18 2011, 10:59 PM) *
Dave
The size is 4"x6".
andys
post Oct 21 2011, 09:57 AM
What's the screw thread size of the brass inserts in the plastic housing?
Andys
Davey Cracker
post Oct 21 2011, 11:57 PM
Thank you for all your help everyone.
- Lo-Fi Version Time is now: 2nd April 2026 - 12:07 PM
