3 Pages V  1 2 3 >
> What weighs 13.5lbs, is for a 4-lug car, and is a 15x7 wheel?
PeeGreen 914
post Dec 18 2011, 08:11 PM
So many months back I made a trade for some custom wheels. Well, they are all done and I have them (IMG:style_emoticons/default/piratenanner.gif)
I painted the centers and weighed them. They came in at 13.5lbs. What does a 5 lug Fuchs weigh?
scott_in_nh
post Dec 18 2011, 08:21 PM
Sweet!
More details and closer pictures please!
Krieger
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) WOW! That is going to look so nice. What kinda tiers you have in mind?
smontanaro
post Dec 18 2011, 08:29 PM
I Googled for Porsche wheel weights and came up with this chart.
PeeGreen 914
post Dec 18 2011, 08:47 PM
So this is 1.5lbs heavier than a 5-lug Fuchs (IMG:style_emoticons/default/smile.gif) Tires that will be mounted are 225 45 RA1s
NORD
post Dec 18 2011, 08:59 PM
Jon
Where those polished and who did the polish? I've been sanding on mine
and that is alot of work. (IMG:style_emoticons/default/santa_smiley.gif)
PeeGreen 914
post Dec 18 2011, 09:01 PM
They are Mahle centers but polished aluminium hoops
NORD
post Dec 18 2011, 09:07 PM
I see that
I've got a set that I'm just trying to do the rim then I'll paint
just the centers like Panasports silver wheel paint. (IMG:style_emoticons/default/santa_smiley.gif)
Yours do look great! next time we meet you'll have to tell
me how much you have in them without the wife finding out.
PeeGreen 914
post Dec 18 2011, 09:10 PM
QUOTE(NORD @ Dec 18 2011, 07:07 PM) *
I see that
I don't have anything into them as it was part of a trade (IMG:style_emoticons/default/wink.gif)
However, what I traded for them was a rather rare part. (IMG:style_emoticons/default/blink.gif)
Socalandy
post Dec 18 2011, 09:14 PM
Its got to be Yellow!!!
(IMG:style_emoticons/default/drooley.gif) very nice!!!
rick 918-S
post Dec 18 2011, 09:58 PM
Hey nice rack! -Celette
16" X 7"
jcambo7
post Dec 18 2011, 10:41 PM
Dang! 140 lbs? (IMG:style_emoticons/default/poke.gif)
audio_file
post Dec 18 2011, 10:53 PM
Those are gorgeous!
smontanaro
post Dec 19 2011, 05:16 AM
I'm sure I'm being dense here, but I thought these were one-piece wheels. How do you get centers from one and different hoops? Is it just (IMG:style_emoticons/default/sawzall-smiley.gif) then (IMG:style_emoticons/default/welder.gif)?
PeeGreen 914
post Dec 19 2011, 09:55 AM
I'm not sure how it is done but basically just remove the center and use it in an aluminium hoop. All of which is beyond my abilities.
post Dec 19 2011, 10:21 AM
QUOTE(PeeGreen 914 @ Dec 18 2011, 06:47 PM) *
and 3.5 lb's heavier than Dan Gurney AKA American Racing
QUOTE(NORD @ Dec 18 2011, 06:59 PM) *
Jon
It's actually pretty easy. If you want to do the part of the rim where the stem is you will have to dismount the tire. Otherwise, just jack up one rear wheel (chock the front ones for safety) then start the engine and put it in 2nd gear. While the tire is spinning place the "wet sandpaper" over the area you desire to polish, working from 1200 grit thru 2000 grit. Follow up with polishing compound and then a finish compound. You will need a rubber backed sanding pad to hold the sandpaper in place or you will toast your finger tips as all this friction will = heat.
I see that
Paint the rims first then follow above instructions. Takes about 10 min's per rim.
charliew
post Dec 19 2011, 10:35 AM
I polished and sanded the empi style wheels on my sons bug using a airtool with a scotchbrite roll and disks and then 400-1000 and 2k paper then polish with the mothers stuff. Afterwards I painted the centers. Of course with the tires off. I'm sure the wheel mounted on the car running in gear will work though but be sure and put a jack under the arm to support it up, not in the full down position.
914werke
post Dec 19 2011, 10:44 AM
the Gurney / American Racing wheels are 5.5 wide not 7
PeeGreen 914
post Dec 19 2011, 12:17 PM
QUOTE(76-914 @ Dec 19 2011, 08:21 AM) *
Unless you can show proof of this I'm going to call BS.
7TPorsh
post Dec 19 2011, 12:26 PM
7T Porsh
QUOTE(76-914 @ Dec 19 2011, 09:21 AM) *
Jon
I see that
Hmmm. I never would have thought of using the car itself as a lathe.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 09:11 AM
