| cha914 |
Jan 14 2003, 05:55 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
sorry, I got confused...when you said thickness, I thought you ment width of the disk...
Yea, I will start on those tonight probably... |
| Mueller |
Jan 14 2003, 06:12 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Back in the old days when I ran poly bushings instead of these really neat and surprisingly good deal needle bearings, LOL
I cut the groove with a Dremel as well, this is the bit to use, IMHO (IMG:http://www.widgetsupply.com/dremel/cutter-burr/carbide/round/D-AD15.jpg) |
| Bleyseng |
Jan 14 2003, 07:41 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Nice pic! Thanks, you sell those too??
Geoff (IMG:style_emoticons/default/beer.gif) |
| Brad Roberts |
Jan 14 2003, 07:44 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
| cha914 |
Jan 14 2003, 09:13 PM
hang in there mike...maybe in a year I will be giving you a call (IMG:style_emoticons/default/tongue.gif)
Thanks for all the help...let the games begin... Tony |
| Gint |
Jan 14 2003, 11:08 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
This is what it looks like when you get it all out and bead blasted.
A weekend huh? Could happen if your goals aren't to CW the whole thing and you don't have problems. Took me 2 months. But that's just me. Jp's older'n me, but I probably work slower. |
| cha914 |
Jan 15 2003, 12:21 AM
That looks real nice ginter...but mine are going to be rather brown and black...as long as they are functional it works for me...this is my car to learn on...
however, I am tired of learning how to fix it...I want to start learning how to drive it...after this weekend, or two, I will have taken everything off the car. So it will be time to have some fun with it. Tony |
| Jeroen |
Jan 15 2003, 02:57 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
wow! nice clean up!
did you have all that powdercoated, or is it DIY (por15 or something like it)? good job! Jeroen |
| Gint |
Jan 15 2003, 10:32 AM
I bead blasted it and powder coated it all right in my garage. Some pics here.
| gklinger |
Jan 15 2003, 11:33 AM
doh! ![]() ![]() Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
QUOTE(Brad Roberts @ Jan 14 2003, 04:24 PM) Just make a spiral path down the inside of them with something resembling a Dremel tool. I use a air grinder and carbide tip. Takes about 10 minutes per bushing. It really helps keep the grease in them. I remember seeing on the PP board a post from someone who had done this, as well as drilling and tapping for zerk fittings. Is this necessary? It sounds like a good idea from the future maintenance aspect, but I'm wondering if it's worth it. If you did this, could you just pump a good grease in there, or would the special poly grease be preferred? Garry |
| Brad Roberts |
Jan 15 2003, 01:08 PM
Hi Garry,
I think the zert is going a little far. I personally goop them up real well before assembly. The problem is: if you dont have some kind of groove in them, all the goop slides out when you slide them onto the control arms. When you purchase them, they come with a very very sticky grease. I heard from another list that the sticky stuff is the stuff used by pool companies for swimming pool seals. I buy the grease in a large tub instead of using the tiny packets that they send. I end up getting double the grease in my bushings from the start. Welcome to the board. Good question. B |
| Gint |
Jan 15 2003, 07:12 PM
Brasshole, :sweet:
Where do you get the tub 'o grease? I need mass quantities for the Jeep bushings as well. |
| Dave_Darling |
Jan 16 2003, 11:57 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
| Gint |
Jan 16 2003, 08:56 PM
You know Dave, I read your reply and thought about it for all of 5 seconds....
(IMG:style_emoticons/default/tongue.gif) |
| Brad Roberts |
Jan 17 2003, 05:04 AM
Ginter,
I'll get the name of the stuff during the day (today) Bump this to the top so I can see it. B |
| brant |
Jan 17 2003, 10:00 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
bump...
| Gint |
Jan 17 2003, 01:49 PM
| Gint |
Jan 17 2003, 04:47 PM
'nother bump
| Brad Roberts |
Jan 17 2003, 05:34 PM
The tubs are so large (with no markings) I cant even locate the last place I bought it from. Hang in there..Tony and I have been working on this since lunch.
B |
| Jeroen |
Jan 17 2003, 05:52 PM
Hmmm... two guys looking for a heavy-duty lubricant
Scarry thought (IMG:style_emoticons/default/biggrin.gif) Cheers, Jeroen |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:54 AM |
