> Fan Housing Flaps Question
lennyhope
post Aug 31 2012, 03:28 PM
Region Association: England
In the fan housing on a 914.....if the cooling flaps are in the dropped position, is cooling occurring or is it when the flaps are lifted?
luskesq
post Aug 31 2012, 03:57 PM
Take a look at this site, page down and I believe that will answer your question.
http://bowlsby.net/914/Classic/TechNotebook.htm
Keith
lennyhope
post Aug 31 2012, 04:00 PM
QUOTE(luskesq @ Aug 31 2012, 10:57 PM) *
Keith
Which article sorry?
gothspeed
post Aug 31 2012, 04:15 PM
'Lifted' is cooling mode .... (IMG:style_emoticons/default/sunglasses.gif) ....... with the little linkage rod 'tab' pulled up and towards the front of the car.
post Aug 31 2012, 04:30 PM
Resident German
They "fail" in the full cooling position. Meaning, if the thermostat is disconnected, the flaps will rest in the full cooling position.
For the passenger side, the flaps will be *down* and cover the oil-cooler which routs the max. amount of air to the oil-cooler.
On the drivers side, the flaps will be about horizontal giving max. airflow to the cylinders.
This arrangement is also the reason why cylinder 3 usually runs hotter than the others and the CHT is located on cylinder 3 for that same reason.
luskesq
post Aug 31 2012, 09:36 PM
QUOTE(lennyhope @ Aug 31 2012, 03:00 PM) *
Keith
Scroll down a bit (perhaps midway and you'll see two sections, first says "Air-cooling flaps: Cold engine position (minimum airflow over oil cooler)", the other for "warm"
Good luck
Keith
Dave_Darling
post Aug 31 2012, 09:42 PM
914 Idiot
Keith
Scroll halfway down the page, then scroll up a little bit. You'll see two pictures of an engine without the engine tin on it, showing the position of the flaps. One is in the "warmup" position, one is in the "it's already warm" position.
--DD
JeffBowlsby
post Aug 31 2012, 10:08 PM
JeffBowlsby
post Aug 31 2012, 10:09 PM
Air-cooling flaps: Warm engine position (maximum airflow over oil cooler)
post Aug 31 2012, 11:50 PM
Resident German
QUOTE(Jeff Bowlsby @ Aug 31 2012, 09:09 PM) *
I'm no T4 expert, but isn't that head with the CHT boss on the wrong side of the motor?
jcd914
post Sep 1 2012, 02:23 AM
QUOTE(SirAndy @ Aug 31 2012, 10:50 PM) *
Yea but if you make your own FI harness you can put the CHT on either side (IMG:style_emoticons/default/smile.gif)
Could be that both heads have the boss.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:36 AM
