They "fail" in the full cooling position. Meaning, if the thermostat is disconnected, the flaps will rest in the full cooling position.
For the passenger side, the flaps will be *down* and cover the oil-cooler which routs the max. amount of air to the oil-cooler.
On the drivers side, the flaps will be about horizontal giving max. airflow to the cylinders.
This arrangement is also the reason why cylinder 3 usually runs hotter than the others and the CHT is located on cylinder 3 for that same reason.
