| jdlmodelt |
Jan 6 2013, 05:01 PM
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
Okay. I am working my way thru all the electrical connections putting this 72 back together. I have the signal lights, headlights, brake lights working but I can't get the tail lights to go on with the head lights. I have two remaining wires on each tail light that I have not connected. one is the backup lights the other the markers for night time. I have not be able to get either of the two working yet. The front marker lights work when the head lights are on. Is there a common place to look for discontinuity for the rear tail lights?
I took her out for a short 1 mile drive. barely got into 4th gear. she is really spunky. I like the power. My county roads are still iced up and I can't really put my foot in it yet. J |
| Tom |
Jan 6 2013, 05:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Fuse #9, 8 amp. Check for good fuse and good connection.
Tom |
| jdlmodelt |
Jan 6 2013, 06:10 PM
| JawjaPorsche |
Jan 6 2013, 06:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Pull fuse box cover and look to see if any fuses are broken or not seated correctly. If the cover is missing, it is extremely easy to dislodge them when you get in and out.
| jdlmodelt |
Jan 6 2013, 06:49 PM
Pull fuse box cover and look to see if any fuses are broken or not seated correctly. If the cover is missing, it is extremely easy to dislodge them when you get in and out. Haha! I don't have a fuse cover! I'll look closer to see if I have a burned fuse. I don't see any loose wires under there either? |
| steuspeed |
Jan 6 2013, 06:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Look in your cars glove box manual.
Or here: http://www.pelicanparts.com/914/technical_...rical_fuses.htm Pictograms are on the clear fuse box cover which is usually lost/broken. |
| jdlmodelt |
Jan 7 2013, 07:34 AM
Look in your cars glove box manual. Or here: http://www.pelicanparts.com/914/technical_...rical_fuses.htm Pictograms are on the clear fuse box cover which is usually lost/broken. Do the tail lights tie in with a spade connector somewhere with the front marker lights? If so...where could I look for that? I hope not up under the tiny little dashboard. (IMG:style_emoticons/default/headbang.gif) |
| jbyron |
Jan 8 2013, 11:28 AM
Jamie ![]() ![]() Group: Members Posts: 155 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest |
Since #9 also includes cigarette lighter, perhaps check to see if you're getting power there?
Lo-Fi Version | Time is now: 2nd April 2026 - 12:19 PM |
