| cbuehling |
Mar 31 2013, 10:22 PM
Newbie ![]() Group: Members Posts: 17 Joined: 20-July 12 From: United States Member No.: 14,703 Region Association: Northern California |
I have some high beam issues on my 74 2.0L I have not been able to figure out... when I push/pull the turn signal switch I can hear the relay click on first engage but the switch doesn't click into the high beam position nor does the high beam signal light in the dash turn on, nor do the high beams turn on.
I've checked the relay, it seems to work fine, cables should be connected correctly as it used to work in this setup. Regular headlights / fog lights work fine, one thing to note is as soon as the key is turned my headlights are on w/o them being up (never looked into that more closely) Also, when I use the turn signal switch to go left on first engage I always hear some relay click, but the turn signals always work fine. I've also thought about the possibility that maybe my high beams are always on and I just can't turn them off, they do seem a bit brighter than what I remember from before. Any ideas? Thanks a lot, Clemens. |
| Mike Bellis |
Mar 31 2013, 10:28 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Relay can go bad and still click.
| cbuehling |
Mar 31 2013, 10:36 PM
Relay can go bad and still click. That's totally possible, my check was purely based on checking resistance which seemed pretty low around 15ohm, and a click when I put 12v on the other two connectors. Something like this should do it, right: http://www.ebay.com/itm/USED-ORIGINAL-GENU...253&vxp=mtr |
| Mike Bellis |
Mar 31 2013, 11:15 PM
Looks like it may work. There is a plastic cam inside the relay. It's triggered by a solenoid. As the cam wears, it will not toggle the contacts, even though the solenoid still works (clicks).
| Chris Pincetich |
Apr 4 2013, 09:50 AM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I need to buy one of these relays ASAP - my headlights can't get HIGH
(IMG:style_emoticons/default/smoke.gif) I see a new one that is black, part # 111 941 583 seems to be OEM Porsche (but maybe EMPI??) I see a used one that is silver, part # 321 941 583 I see a new EMPI part, black, part # 111 941 583 (EMPI is not OEM, is it??) I've bought off-brand electrical parts before and they were not 100% so want to get one that is correct and w best chance of long-life. WHICH ONE is best?? Also - I have the H4 upgraded headlights and found this other relay on Pelican Parts High Power Headlamp Relay Brand: Wehrle, part # 141-951-253-B-M206 What about this one? Is it in addition to the others or instead of??? What's up w Pelican not having the regular 914 headlight relay?? I am driving the 914 a lot on curvy roads w lots of wildlife and want those high-beams to work at night (IMG:style_emoticons/default/beerchug.gif) |
| cbuehling |
Apr 5 2013, 07:57 PM
I need to buy one of these relays ASAP - my headlights can't get HIGH (IMG:style_emoticons/default/smoke.gif) I see a new one that is black, part # 111 941 583 seems to be OEM Porsche (but maybe EMPI??) I see a used one that is silver, part # 321 941 583 I see a new EMPI part, black, part # 111 941 583 (EMPI is not OEM, is it??) I've bought off-brand electrical parts before and they were not 100% so want to get one that is correct and w best chance of long-life. WHICH ONE is best?? Also - I have the H4 upgraded headlights and found this other relay on Pelican Parts High Power Headlamp Relay Brand: Wehrle, part # 141-951-253-B-M206 What about this one? Is it in addition to the others or instead of??? What's up w Pelican not having the regular 914 headlight relay?? I am driving the 914 a lot on curvy roads w lots of wildlife and want those high-beams to work at night (IMG:style_emoticons/default/beerchug.gif) I ended up buying exactly the one I posted above and just installed it, works great. Was indeed just a broken relay. Thanks a lot for the help. |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:39 PM |
