| r_towle |
May 29 2013, 09:29 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
> Time for a neck brace You mean chassis brace. I can hear some spot welds crying already. (IMG:style_emoticons/default/smile.gif) -Steve Funny you say that, I am welding up parts of my car and after ten years, about 6 of which it lived in slicks....there are more than a few cracks on the longs and other odd areas... Just roaming around and inspecting everything, seam welding as needed... |
| J P Stein |
May 29 2013, 10:12 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
seam welding as needed... That would be from one end to the other. (IMG:style_emoticons/default/biggrin.gif) BTW, Rich, don't I owe you a 914 cutout thingy? |
| r_towle |
May 29 2013, 10:33 PM
At some point, yes.
I would love the thingy...figured you changed your mind |
| Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Nope, don't need to. McMark is building me a trailer ... Speed limit is 55 MPH with a trailer (here in CA, at least). (IMG:style_emoticons/default/sad.gif) Bridge tolls are higher, too, I think. The roof rack might be worth thinking about. --DD |
| r_towle |
May 29 2013, 10:35 PM
Nope, don't need to. McMark is building me a trailer ... Speed limit is 55 MPH with a trailer (here in CA, at least). (IMG:style_emoticons/default/sad.gif) Bridge tolls are higher, too, I think. The roof rack might be worth thinking about. --DD Don't you allow a truck to pull a trailer that is pulling a boat? If so, 55 is a good speed limit. |
| Elliot Cannon |
May 30 2013, 12:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Nope, don't need to. McMark is building me a trailer ... Speed limit is 55 MPH with a trailer (here in CA, at least). (IMG:style_emoticons/default/sad.gif) Bridge tolls are higher, too, I think. The roof rack might be worth thinking about. --DD Don't you allow a truck to pull a trailer that is pulling a boat? If so, 55 is a good speed limit. I believe it has to be a "fifth wheel" trailer and you also need to up-grade your drivers license. |
| Axel |
May 30 2013, 01:41 PM
Newbie ![]() Group: Members Posts: 17 Joined: 15-May 13 From: Lenexa, Kansas Member No.: 15,875 Region Association: Upper MidWest |
Looks heavy. (IMG:style_emoticons/default/dry.gif) Nope, it's actually really light ... (IMG:style_emoticons/default/aktion035.gif) Nice to see somebody else has one of those tail racks. I was beginning to think mine was the only one. |
| SirAndy |
May 30 2013, 01:51 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Speed limit is 55 MPH with a trailer (here in CA, at least). Correct me if i'm wrong, but i believe that is only true if you're towing the trailer with a truck. From what i have read, if i pull a small single axle trailer behind the 914 the same speed limit should apply as without the trailer. (IMG:style_emoticons/default/idea.gif) |
| Trekkor |
May 30 2013, 09:02 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
http://www.dot.ca.gov/hq/traffops/signtech.../specs/R6-4.pdf
55 when towing anything... VC Sec. 22406 http://www.dmv.ca.gov/pubs/vctop/d11/vc22406.htm A trailer is defined as a vehicle by the Cal DMV. KT This post has been edited by Trekkor: May 30 2013, 09:08 PM |
| Dr Evil |
May 31 2013, 09:39 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
They charge you per axle. A car towing a trailer is still a car+trailer(# of axles). There is a sign as you pull up. And yes, you are limited to 55mph (been harassed in CA for that one).
Lo-Fi Version | Time is now: 2nd April 2026 - 09:36 AM |
