4 Pages V < 1 2 3 4 >
> Sheet metal replacement, how to installs, new video Aug 13/14
peteyd
post May 14 2013, 12:11 PM
Post #21
Installation of the frame stiffener
https://www.youtube.com/watch?v=IVrmUHRfbCs
Luke M
post May 15 2013, 09:18 AM
Post #22
Hi Pete,
We ( being my brother & I ) received all of the new metal to do the repairs on our cars. It was a fast order to receive even with all the tins. I must say a job well done at your end. I have a question on the stiffener kit install. Can they be installed w/o having to cut off a portion of the rear lower fenders ?
I plan on doing the install within the next month.
Thanks for adding the videos.
TIA.
moparrob
post May 15 2013, 09:28 AM
Post #23
Subscribed. (IMG:style_emoticons/default/popcorn[1].gif)
Jon H.
post May 15 2013, 07:26 PM
Post #24
QUOTE(bandjoey @ May 3 2013, 04:56 PM) *
At the end it needs to move to the Restoration thread area.
Is this Rotisserie simply a roll the entire cage over on its side and upside down or is there something I can't see?
Waiting on the next edition!
How 'bout showing us the presses in action - how you make the parts?
and yes to complete bodies!
Here's how the front trunk is done.
Front trunk
Jon
cary
post May 15 2013, 08:07 PM
Post #25
Man, Pete your fast .................. LOL.
Nice work ................
r_towle
post May 15 2013, 09:32 PM
Post #26
Custom Member
Well done.
Might want to put the frame stiffener overlay on your website....I can't find it.
D your guys make the piece up front on the long that goes over the long and under the front fender?
Rich
peteyd
post May 16 2013, 06:16 AM
Post #27
QUOTE(r_towle @ May 15 2013, 07:32 PM) *
Well done.
Rich
Here is the part on the web
http://www.restoration-design.com/mm5/merc...duct_Code=P346R
If you are referring to the lower box shape piece that is part of the hinge post, we dont make a replacement piece for there yet. The boxy shape piece that is part of the stiffener up front we make and that fits right over the original.
peteyd
post May 16 2013, 06:21 AM
Post #28
QUOTE(Luke M @ May 15 2013, 07:18 AM) *
Hi Pete,
TIA.
I cut off the lower fenders on my personal car as well. It would be tight in there if you didnt cut some away. It would be much easier for sure to cut away the lower fender, but you should try anyways. It wouldnt hurt to make the attempt.
Chris H.
post May 16 2013, 02:26 PM
Post #29
Sorry for the ignorance but are the frame stiffeners an alternative to the "Engman kit" or would you do both? It depends on the application I'm sure.
peteyd
post May 17 2013, 06:30 AM
Post #30
QUOTE(Chris H. @ May 16 2013, 12:26 PM) *
I'd say that it would be an alternative. Having both would probably be overkill.
peteyd
post Aug 12 2013, 01:27 PM
Post #31
We just completed replacing the front and rear floor pans as well as the seat mount reinforcement pieces and the peddle cluster bracket.
I will have another installation video up shortly, but here are a few photos of the process.
Here is the prep work before drilling out the spot welds.
After the spot welds are drilled we have to chisel off the edges of the pan.
You can see all the rust that is hiding between the pans, so when someone tells you their car is "100% rust free" you know thats BS.
Test fitting the front pan.
Holes punched in the pans for rosette welds
Boths pans and jack points being test fit with butt weld clamps in the middle. The seat mount reinforcements have been spot welded in and the peddle cluster bracket was located with the peddle cluster. The holes were drilled then the bracket was spot welded in also.
Heres the finished product.
peteyd
post Aug 13 2013, 08:24 AM
Post #32
Here is our latest installation video...
enjoy
https://www.youtube.com/watch?v=3kMOMNhxg-A
peteyd
post Aug 28 2013, 08:09 AM
Post #33
We have updated the YouTube channel with another video of a rear trunk installation.
We also have made the rear trunk reinforcement that lays over the transaxle cross member mount. This new part is P335A
check it out and enjoy!
https://www.youtube.com/watch?v=GBmJkP8I_rI
solex
post Aug 28 2013, 09:35 AM
Post #34
This is great, i really need to do something about my floor next. Thank you
peteyd
post Sep 20 2013, 08:19 AM
Post #35
We put together another video for your viewing pleasure.
Adam demonstrates the installation of the seat hinge risers and the hinges.
If your interested in the cooling gel used in the video, it is a wurth product. Spray it on a nearby location and that area will not heat up. There are some youtube videos demonstrating it in use. Pretty amazing stuff actually.
wurth welding spray
https://www.youtube.com/watch?v=PWgt8AaqnUI
Sleepin
post Sep 20 2013, 09:45 AM
Post #36
I agree with most on here that this came along just in time! I am doing a passenger side floorpan replacement very shortly!
To fix this mess:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-8357-1379692068.1.jpg)
Does Restoration design make anything for the cowl/fender seam? My passenger side is also in bad shape.
peteyd
post Sep 20 2013, 10:17 AM
Post #37
Currently we dont have any repair piece for that seam. If you have rust in there, it probably goes deeper.
You might want to get a piece from a donor car. Make sure you get all the rust or else you will see rust coming to the surface again in a couple years.
worn
post Sep 20 2013, 12:47 PM
Post #38
QUOTE(peteyd @ Sep 20 2013, 08:17 AM) *
I am curious why you had the car painted at the outset, since obviously it will need to be at least partially painted at the end again. Was it for contrast in the videos?
peteyd
post Sep 20 2013, 01:26 PM
Post #39
QUOTE(worn @ Sep 20 2013, 10:47 AM) *
We painted the car green so it would stand out at shows and swap meets. It also works well for contrast as you said.
Yes it will need to be painted again in the end, but this is more of a demonstration car and will most likely remain a bare shell for quite some time.
peteyd
post Feb 27 2014, 08:39 AM
Post #40
We have shot a few more videos of the green 914, but I wanted to put this video up first.
A day in the Life of Restoration Design.
https://www.youtube.com/watch?v=C6CEx0UB8FM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:26 AM
