Difference between 110mm and 108mm |
chad newton |
Aug 30 2013, 07:04 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
What is the difference between 110 and 108 stub axles and transmission stubs? Educate me guys. One us us has some parts for me but says they are 110mm 4 bolts 2 pins.
r_towle |
Aug 30 2013, 07:27 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
2mm
cwpeden |
Aug 30 2013, 07:35 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Sound like Type 1 vs. Type 4?
Wasn't there a thread about something like this a while ago? |
chad newton |
Aug 30 2013, 07:50 PM
r_towle |
Aug 30 2013, 08:02 PM
Tangerineracing.com
Pmbperformance.com Go read |
ChrisFoley |
Aug 31 2013, 08:55 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
2mm Hah, I just don't want to buy stuff that will not work. Did any porsche come with 110 stub axles and axle shafts. Chad, I think that 108mm 911 cvs have six 8mm bolts and the 110 mm 911 cvs have four 10mm bolts + pins. The associated stub axles and trans output flanges can't be mix matched. |
chad newton |
Aug 31 2013, 10:43 AM
2mm Hah, I just don't want to buy stuff that will not work. Did any porsche come with 110 stub axles and axle shafts. Chad, I think that 108mm 911 cvs have six 8mm bolts and the 110 mm 911 cvs have four 10mm bolts + pins. The associated stub axles and trans output flanges can't be mix matched. Ok, so if I have 110 stubs and out put shafts theoretically everything could be converted over right? What about hubs and bearings do they stay the same then. |
Luke M |
Aug 31 2013, 11:24 AM
Senior Member Group: Members Posts: 1,374 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
You would use the 911 early 69-73 5 lug hub or the later 74-89 hub eccentric type with a spacer (I believe it's 5 mm). Either way the 914 wheel bearing stays the same.
I just checked the stubs and flanges for you Chad. A late (911 carrera) inner 108 mm cv joint bolts right up (w/o the cap) to the flanges/stubs that we have been talking about. I'm not sure if the earlier 108 mm will fit. I do not have one to check this but I would think as long as it's the 10 mm mounting bolt type it should work. The over all height of the 110 mm trans flange vs the 914 is 5 mm taller. Otherwise other measurements are the same. If you do a search on the Pelican site I believe that the 110 mm stubs & flanges are from a early 911 turbo. pics attached.. Attached image(s) |
Mike Bellis |
Aug 31 2013, 11:40 AM
I've never heard of 110mm. (IMG:style_emoticons/default/confused24.gif)
I have 100mm I have 108mm I used to have 94mm My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts. |
Luke M |
Aug 31 2013, 12:15 PM
I've never heard of 110mm. (IMG:style_emoticons/default/confused24.gif) I have 100mm I have 108mm I used to have 94mm My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts. I just checked a few threads on the bird board. Looks like the 110 mm flange is used with a 108 mm cv joint. It could be that the flanges and stub axles run a few mm's larger then the cv joints it self which is causing all of the confusion. So based on that I have 108 mm stubs and trans flanges then. |
chad newton |
Aug 31 2013, 12:33 PM
Awesome, I think I got it figured out now. Thanks for everyone's help.
Mark Henry |
Aug 31 2013, 12:42 PM
I've never heard of 110mm. (IMG:style_emoticons/default/confused24.gif) I have 100mm I have 108mm I used to have 94mm My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts. I just checked a few threads on the bird board. Looks like the 110 mm flange is used with a 108 mm cv joint. It could be that the flanges and stub axles run a few mm's larger then the cv joints it self which is causing all of the confusion. So based on that I have 108 mm stubs and trans flanges then. (IMG:style_emoticons/default/agree.gif) No such thing as a "110mm flange" it is a "flange for a 108mm CV with coarse splines". You do have to watch out for the 108mm early flange (these are off of 1969 and earlier) and are for the weak diff with the tit bolts. They seem to bolt up but are dimensionality incorrect. Half way down this page of Eric's post I tell you exactly what new CV's work and there are links to the bird with more info on CV's http://www.914world.com/bbs2/index.php?sho...91963&st=20 |
Lo-Fi Version | Time is now: 1st June 2024 - 05:59 PM |
