| veekry9 |
Oct 13 2013, 06:45 PM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Hello World.
I posted 1st as a reply to Marcus C6. How difficult would it be to fabricate a transaxle that can carry the Ford 9" ring + pinion?I have viewed Currie's site and see no mention anywhere online of such a contraption. A ZF from a Pantera approaches the torque capacity, the original GT40's box was a Hewland race piece. (Edit#2:on research,a Colotti tx was used on the 289 mk1's,still in business.) http://www.colotti.com/ ![]() (Edit:Later a KarKraft tx was used,perhaps some production parts) Are there any foundrymen on the 914W site? And of course the latemodel Porsche TX's are works of art. Could there possibly be a demand for such a high load TX? vic |
| Mike Bellis |
Oct 13 2013, 07:04 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Why not just buy one of these? The R&D is already done...
http://mendeolamotors.com/trans-proto/inde...7&Itemid=29 |
| 914forme |
Oct 13 2013, 07:09 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
(IMG:style_emoticons/default/agree.gif) Or go with an Audi R10 unit.
| DBCooper |
Oct 13 2013, 07:37 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
What's the point of a ring and pinion that is so much stronger than any transmission that would go behind it? 930 not enough? How much power are you looking to handle, anyway?
| veekry9 |
Oct 14 2013, 06:36 PM
| jimkelly |
Oct 14 2013, 06:47 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pic
Attached thumbnail(s) |
| veekry9 |
Oct 14 2013, 07:15 PM
Wot duh fouk!!
lessee: SBC 400+cid headers,cam,750holley largerunner manifold. TH400 to a chain transfer case and then to 2!! center sections. The Mother of Invention. A ton of work that was likely alot of fun. How does it go? Loud fast scary whahoo! / (edit:06/09/16) The guy who built the gates beltdrive irs. Innovation,ingenuity and audacity. http://www.fiero.nl/forum/Forum1/HTML/087996.html (IMG:style_emoticons/default/biggrin.gif) / |
| jimkelly |
Oct 14 2013, 07:31 PM
| r_towle |
Oct 14 2013, 07:34 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Sick
| veekry9 |
Oct 14 2013, 07:48 PM
Yeah
I remember that car I call it the DragPanzer mit camo. 2speed PG? and finally to a DeDion axle in its last iteration.? |
| veekry9 |
Oct 14 2013, 08:06 PM
Why not just buy one of these? The R&D is already done... http://mendeolamotors.com/trans-proto/inde...7&Itemid=29 have done many yrs ago. they are indeed very nice. I'm thinkin along the lines lately of what Lamborghini did. Flywheel forward>trans between passengers> custom fab/billet/casting transfer case> driveshaft rearward to 9"custom transaxle. Its been done before though not in a backyard. |
| Dave_Darling |
Oct 14 2013, 08:40 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
That's an absurd amount of work.
Just get a Mendy transaxle and be done with it. One of the guys on the Bird Board had a tube-frame blown SBC racer with a Mendy. No problems. The 935s ran 800 HP through a four-speed 930 gearbox (with cooling). How much power were you interested in supporting? What kind of axles did you want to use to try to hold that power? --DD |
| messix |
Oct 14 2013, 10:31 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
if you intend on drag racing a 914...... well good luck!
irs isn't the most conducive to drag racing, to many moving parts at high torque loads [stubs to diff flanges]. to beef these up to stand the forces would be counterproductive to accelerating the rotating masses [the tires, wheels, halfshafts and the diff it's self. if you dead set try to fab what they use on t/f cars. clutch to torque shaft to diff. you would have to rely on clutch slip to aid the acceleration and launch. sounds stupid? yep! medi's cost $$$$ because they can stand the power and have been proven. but they can break just like anything else that gets abused with high instant torque loads. you want big power and no parts broken..... bring lots of $$$$$ |
| bulitt |
Oct 15 2013, 04:23 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Ferrari 512bb put the boxer 12 over the top of the trans with a geared transfer case on the rear. Very clean but big HP would snap the pinion. The 901 trans only weigh @75lbs so if you are looking at a 9" with a TH you will be adding a serious amount of weight to the r/e. Seems to me a used Camaro would have you down the track years ahead of what you're thinking. But if it's your dream then go for it !
Check this out- Patrick 914 |
| DBCooper |
Oct 15 2013, 06:47 AM
We've asked what horsepower and what application, with no answer. I don't think there is an answer, this is all just speculative hypothetical "what if's".
| SLITS |
Oct 15 2013, 09:58 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
SBC 400+cid
headers,cam,750holley largerunner manifold. With early double hump heads, 10.25:1 compression about 400 HP. Thats the combo I ran in my jet boat. |
| andys |
Oct 15 2013, 10:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Read this one held 1100HP. It has your 9"
Andys Attached image(s)
| bulitt |
Oct 15 2013, 12:45 PM
looks like a Tim Allen belt sander.
| Dr Evil |
Oct 15 2013, 01:26 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Hmmmm (IMG:style_emoticons/default/popcorn[1].gif)
| messix |
Oct 15 2013, 02:15 PM
that would stick out the back of a 914 and more than double the weight of a transaxle.
Lo-Fi Version | Time is now: 2nd April 2026 - 08:37 AM |
