QUOTE(veekry9 @ Oct 21 2013, 08:00 PM)
Allo.
After some searching about,I rediscovered
the thread about an LS/Audi conversion.
(LS1 Conversion, A Retrospective Build Thread)
By andys
Doh!Correction.
Different thd,different car.no find,more searching later.
by the way, andys,immaculate work.
And Lo and Behold,the Audi O1E also has the iron
gearcase,much like the 944/951/968.
Other than destructive testing,how could I determine
the load capacity of the respective boxes?
Of all the candidates,the Audi O1E appears the most
readily available.
https://www.youtube.com/watch?v=6LMr3OBe2fc..._detailpage#t=5Using a 944/951 TX behind a LS V8.
The Original GT40 used a Hewland or Colotti T37 TX
then later 7L's a custom KarKraft T44 as a small production.
The problem looking for a solution is the same as then,
in 64-65.
http://www.gt40s.com/forum/gt40-tech-engin...aft-t-44-a.htmlThe entire purpose is of course,not exploding your TX on the
application of full throttle or any random time.
http://www.rbttrans.com/about.htmlFor those who require V8 Torque capabilities.
Finally found the pix of the thd to which I was referring.
Click to view attachment Click to view attachmentThought about this mod some time ago,even took pix of it.
To,like,you know,modify.
Click to view attachmentI'm really liking this out of the box solution to the Need for"big fat tires
and everything".Looking at the front fenders you can see he's making room
there too.Somewhere on a drive I have the Gimped look I tried to make the
914 all growed up.You know,like,with round,sloped headlamps,ala 911/928/968.
I'll post it when I find it in the labrinth of the artdrive.Note:This is only for those
who suffer no queasyness when hacking into a 914's unibody when rusted.
Typically,both the front and rear get the "treatment"and effort is made to blend
the resultant discontinuity with the doors,because messing with the doors is taboo.
When the factory tacked the gt flares on,it was simply an effort to expedite the
tire installation for homogulation rules.A stylist/designer may have had a subtley
different take on it.A good example might be the Goodrich 924Turbo LeMan cars.
Coming soon.
By the way,How does this look to you all?
Click to view attachment A few minutes work with the Gimp.
