| partwerks |
Nov 24 2013, 10:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Just to confirm what I have been told. To replace the TPS on the 2004 Subaru WRX, I just need to take the 2 screws out, and put the new one in, and end of story?
http://www.ebay.com/itm/New-Throttle-Posit...1ec&vxp=mtr |
| brant |
Nov 24 2013, 10:21 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I don't know on the subaru... someone will reply
but on other cars, replacing the TPS also involves adjusting it accurately with an OHM meter |
| AE354803 |
Nov 24 2013, 08:35 PM
Member ![]() ![]() Group: Members Posts: 238 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
You need to adjust it to read proper voltage for a given position.
I know on my 00 outback 2.5L n/a the factory service manual states to set it to 0.45 - 0.55 volts when throttle is fully closed (for Manual or auto trans). Probably the same for yours |
| edwin |
Nov 25 2013, 05:28 AM
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
That one will be simple. Bolt holes aren't slotted so it can only go in one spot
| Bulldog9 |
Nov 25 2013, 08:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Not sure of this particualr model, but my wife drives an 05 3.0R and the sensor was plug & play.
Disconnect battery, remove, replace, all was well. Used Subaru part, not advance auto. |
| partwerks |
Nov 29 2013, 07:32 PM
It does not have slotted holes.
The problem/bug that keeps lurking around it seems, is with the low idle. My mechanic had me put on a new IACV, and that didn't change anything, then he put some gizmo to check the air fuel ratio, and was lean, and so put on a new 02 sensor, and fixed that problem, and he told me to adjust the idle set screw in is all to bring it up, and so I don't know if I did the wrong thing, but sometimes when shifting into 2nd, and let out the clutch it would sort of want to buck, and so I got the bringt idea to replace the TPS, since it was relatively cheap, and/or maybe that is the problem, after I put the new one in?? He also sprayed carb cleaner around to see if there were any vacum leaks, and couldn't find any. I don't know if it matters, but I did not disconnect the battery, just took the screws out, and installed it. Didn't seem to do anything for the low idle, and now if you really stick your foot into it, it is as though you were turning off the key, but if you back off a bit, it will run normal, or don't crowd it, and so I don't know if I gained anything or not, but thought about putting the old sensor back in?? Is there a way to check to see if the old sensor is working with an ohm meter? If so, I could have my electrician check it out. |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:49 AM |
