> vapor lines, if I want to replace them what do I use?
worn
post Feb 4 2014, 10:58 AM
When I was stripping the tub I wasn't as respectful to the vapor lines running under the rockers from engine to tank as I might have been. Also I am not sure where they all are (no smiley for what an idiot).
At any rate they seem to be a PVC material that is either supposed to be kind of stiff or has hardened with the age. They look black, and I suppose they may have started that way. Other than that they look like tygon tubing.
I can find no replacement source. I probably won't have space for the catalytic converter in the 3.2, but I see no reason not to use this device for reducing emissions. But what should I use?
Great thing is that this group will find me an answer (of some sort). Thanks so much!
SLITS
post Feb 4 2014, 01:20 PM
"This Utah shit is HARSH!"
Thin wall, flexible plastic tubing. Only carries air and fuel vapors under minimal pressure.
Tygon hadn't been invented yet! (IMG:style_emoticons/default/poke.gif)
flash914
post Feb 4 2014, 01:24 PM
I work on large trucks and I would look at air brake line. Gordon
boxsterfan
post Feb 4 2014, 02:12 PM
914's are kewl
Some people just use rubber hose. You might be able to use some irrigation hoses from your local home depot.
DRPHIL914
post Feb 4 2014, 02:20 PM
Dr. Phil
sorry for the highjack but somewhat related, is this why the tank can build up pressure or vaccum? is it the lines being blocked or the charcoal canister? ive read where the charcoal needs to be replaced too,
btw the airlines from a truck seem like a good idea.
SLITS
post Feb 4 2014, 02:44 PM
QUOTE(Philip W. @ Feb 4 2014, 12:20 PM) *
The tank is vented via the charcoal canister and expansion chamber. As you know, fuel will vaporize with heat. The fumes are supposed to be taken back to the air cleaner to be burned in the engine.
If you draw a vacuum (negative pressure) on the tank, the vent has been capped off.
The small hose from the filler neck connects to the expansion chamber which in turn is connected to the charcoal canister. On my car I run the vent hose to the bottom of the car ... yeh! I'm not "green".
The charcoal can become saturated with fumes and lose it's effectiveness. I thought by placing it in an oven it can be made good again, but it can be replaced.
post Feb 4 2014, 10:27 PM
I think I posted this a while back. If you can't find it pm me, I'll find the link. I just moved my canister back to the engine and ran a 1/4" alum tube from the tank back to the canister. It mounts on the R side Top engine. Much easier than running 2-12mm hoses.
ruby914
post Feb 4 2014, 11:03 PM
Polyethylene Ice Maker supply line
http://www.lowes.com/ProductDisplay?partNu...w&cId=PDIO1
toolguy
post Feb 5 2014, 01:25 AM
low pressure drip irrigation supply line
euro911
post Feb 5 2014, 04:07 AM
Like Ron, my hose dumps out below the firewall. If my charcoal canister is still good, one of these days I'll get around to installing it. Where can one get new pellets for them?
topatrout914
post Feb 5 2014, 07:00 AM
Trout
QUOTE(euro911 @ Feb 5 2014, 05:07 AM) *
You can find activated carbon in most pet supply stores. It's really cheap. The hard part would be getting the canister opened up a sealed back up I would think.
DRPHIL914
post Feb 5 2014, 07:15 AM
Dr. Phil
QUOTE(topatrout914 @ Feb 5 2014, 08:00 AM) *
i cant remember where it was or when it was posted but while searching this a while back i ran across a thread someone did on replacing the charcoal, and it seems like it wasnt that hard. I was going to test the lines first by blowing some compressed air thru there to see if the lines are clogged first (or broken), and replace as needed, but since the car is almost 40 years old, i would say its a good idea to just replace the charcoal no matter what. i guess i will add this to my list of "things to do" , i need another one of those like a hole in the head (IMG:style_emoticons/default/wacko.gif)
rhodyguy
post Feb 5 2014, 07:23 AM
i found pellets for REAL cheap at amazon. plastic canisters can be opened, not so sure about the metal ones. i recently hooked up the evap system in a 74' with carbs. stock location was the rear of the engine bay. one line from the single fitting on the fan shroud and the small line that runs thru the center tunnel to the canister. no lines in the dr side long.
MMW
post Feb 5 2014, 07:26 AM
Why not use hard nylon fuel line? Easily available at auto parts stores & cheap also. Comes in many diameters & rolls of different lengths.
http://www.autozone.com/autozone/accessori...ier=839137_0_0_
- Lo-Fi Version Time is now: 2nd April 2026 - 12:19 PM
