| partwerks |
Mar 10 2014, 03:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I wonder which form would be better?
http://www.amazon.com/DEI-050220-Boom-Mat-...dening+material or http://www.amazon.com/FatMat-Self-Adhesive...dening+material |
| Tedman5 |
Mar 10 2014, 03:37 AM
Member ![]() ![]() Group: Members Posts: 122 Joined: 25-January 08 From: Lebanon, PA Member No.: 8,627 Region Association: North East States |
I used Fat Mat in mine. I chose it because it was cheaper in price and basically the same thing.
How much material are you looking for? I may have enough left over from the large roll I purchased. |
| CptTripps |
Mar 10 2014, 06:53 AM
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest |
What you're showing is an apple and an orange.
You'll need a LOT of that spray to make it effective. I'm not sure it'll ever be what you're looking for either. I bought something like this. eBay Sound Deadening Material Also: You'll use it up a lot faster than you think. 50sq ought to be enough, but you can get 100' for the same price as your link above. |
| boxsterfan |
Mar 10 2014, 08:56 AM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
For anybody that has completed soundproofing their teener, how did it turn out for you? How much reduction in noise (measured or seat of the pants feeling)?
| Mark Henry |
Mar 10 2014, 10:34 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The stuff CptTripps posted works OK, just as good as the more expensive stuff like Fatmat. OK...but not great.
What I have found works the best (and is dirt cheap) is spray contact cement and closed cell foam rubber floor mats. Closed cell will not absorb water. https://www.google.ca/search?q=closed+cell+...920&bih=979 I shit you not, for floors you could embed this in rocker guard, but it is a PITA as you have to weight it till it drys. |
| 914pipe |
Mar 10 2014, 06:30 PM
Say......TEEEEEEEN!!!!! ![]() ![]() Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
| rsrguy3 |
Mar 10 2014, 07:39 PM
Member ![]() ![]() Group: Members Posts: 136 Joined: 4-April 09 From: Utah Member No.: 10,234 Region Association: None |
Used it on dads 56 Ford years ago and it works and is cheap. The trick is it needs to be warm to stick well. I recommend using 3m contact on the metal first.
| martinef1963 |
Mar 10 2014, 08:54 PM
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Has anyone had any experience with GT Mat?
www.gtmat.com |
| malcolm2 |
Mar 10 2014, 09:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
On a hot summer day, won't your car smell like tar? |
| Shindog1961 |
Mar 11 2014, 12:09 AM
Member ![]() ![]() Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
Several people in hot climates like Phoenix and South Texas report no odors.
| rsrguy3 |
Mar 11 2014, 05:15 AM
Unlike the original tar the Peel and stick is beutle based same as dyna mat.
| saigon71 |
Mar 11 2014, 05:24 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
I wanted a quiet cabin (by 914 standards). I am running a stock d-jet engine.
I went with rattle trap, a thicker version of Fat Mat from the same manufacturer. Bought 50 sq ft from an ebay seller. That was plenty for the floor, longs and inner firewall. Also installed an aftermarket sound pad from 914rubber.com on the engine side of the firewall. I haven't ridden in many 914's, so I can't draw any comparisons...but for me it was a good solution. |
| bandjoey |
Mar 11 2014, 11:01 AM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
New cars use2msterials for sound proofing. Rubber and foil. I'm not the engineer but I'm told it has to do with not just sound blocking (penetration) but also metal vibration creating additional noise.
I used 2layers of Lowes peel and stick rubber roofing material. Thin and about 12" wide rolls. That Was covered with A/C silver foil tape. No odors. 2nd summer and still stuck and in good shape. It definately quieted down the noise. Inexpensive alternative to Dynomat. (IMG:style_emoticons/default/driving.gif) |
| effutuo101 |
Mar 11 2014, 12:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Lizardskin sound and thermal reduction. followed by fat mat on the floors and in the doors.
we will see once I hit the road... http://www.lizardskin.com/ |
| wes |
Mar 12 2014, 01:10 PM
wes ![]() ![]() ![]() Group: Members Posts: 1,600 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California
Im not one of those that needs a total stock car, that is Id like a bet more comfort and to bring it somewhat up to date wile still looking sort of stock so one of the things Im ready for is a quitter interior. Im wondering what happens to the value of your car once you have glued the sound deadener to the interior of your car as it sounds as though its pretty much going to be a real job for anyone to ever take it off in the future. So has any one any Idea of what happens to the value, dose it help or hinder?
| CptTripps |
Mar 12 2014, 01:56 PM
So DOES any one HAVE any idea of what happens to the value, DOES it help or hinder? I'll take a crack at that... Unclear. It's all a matter of taste and preference. The material we're using now is a TON better than what they used in the 70s when these cars were being built initially. It also depends on who you're selling it to. My last car was a 73' that I did a pretty decent job of restoring all the way. I covered the entire interior with Herculiner, and then primed/painted, and covered that with Dynamat. Added about 15lbs to the whole car, but I think it helped the sound a bit, and certainly the water resistance of everything. If you're building a car solely for resale...you probably shouldn't do it. |
| wes |
Mar 12 2014, 02:32 PM
Thanks, sounds like most other areas of the car, a bit more usable but not enough change to destroy the car except for the serious collector.
Ha Ha,, Part 2 if I was building for just for resale Id be screwed a long time ago as Im not really keeping track off $$ but Im pretty sure I past the value mark before the rust and paint was done! |
| jrrhdmust |
Mar 14 2014, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None |
I like second skin audio, following the sounddeadenershowdown.com methodology. It worked well in a 2000 F250 Diesel and a 67 Cougar. I used just dynamat in a 71 Superbeetle and it sucked.
| boxstr |
Mar 14 2014, 10:00 AM
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I have used the peel and seal roof patch material, same as the other more exspensive products. Same thing just no name brand stenciled all over the backing.
Try it you will be glad you did, so will your wallet. Craig at CAMP |
| 7TPorsh |
Mar 14 2014, 10:09 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I bought some matting awhile ago and found out after I gt it that it is almost impossible to cut and trim.
Is this Peel and Seal easy to shape? |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:50 AM |
