| lennyhope |
Jul 5 2014, 01:06 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
My 1.7 FI is suddenly running rich. I have not changed anything i am aware of. I sometimes have a lose injector plug but that's it. Any suggestions where to start troubleshooting?
| Bob L. |
Jul 5 2014, 01:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I would check all the vacuum hoses. Next would be injectors, The seals and the injector itself. Don't forget the cold start injector.
| mepstein |
Jul 5 2014, 01:44 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Mine ran very rich when I forgot to plug in the cold start injector. Drove ok but the exhaust was wet with gas
| Java2570 |
Jul 5 2014, 01:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Take a look at this webpage: http://members.rennlist.com/pbanders/DJetParts.htm
You could have an MPS (Manifold Pressure Sensor) that has a leaky diaphragm, that would cause you to run very rich. Or an open CHT (Cylinder Head Temperature) sensor could cause a rich situation. The website linked has a lot of troubleshooting and parts information that could help diagnose this rich issue. |
| lennyhope |
Jul 5 2014, 03:37 PM
Doh! Where is the cold start injector??
| Java2570 |
Jul 5 2014, 03:59 PM
Cold start injector is attached to the air plenum....see picture:
| Cap'n Krusty |
Jul 5 2014, 05:10 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
| Cap'n Krusty |
Jul 5 2014, 05:12 PM
Take a look at this webpage: http://members.rennlist.com/pbanders/DJetParts.htm You could have an MPS (Manifold Pressure Sensor) that has a leaky diaphragm, that would cause you to run very rich. Or an open CHT (Cylinder Head Temperature) sensor could cause a rich situation. The website linked has a lot of troubleshooting and parts information that could help diagnose this rich issue. Won't start with an open CHT. I would persue the MPS and the hose connecting it to the intake plenum. The Cap'n |
| lennyhope |
Jul 6 2014, 02:36 PM
Thanks......ALL great info. I check the tightness of all th ehoses etc and it ran well. Took the car for a 6 mile trip and ran fine. Tick over a little low upon return though....
Lo-Fi Version | Time is now: 2nd April 2026 - 06:27 AM |
