3 Pages V < 1 2 3 >
> Tapered Fuel Hose, No longer availabe at Pelican Parts
pete000
post Aug 6 2014, 11:18 PM
Post #21
I noticed Sierra Madre lists them as NLA now too...
Might go this route...Pretty close to 8 & 10mm
Phoenix914
post Aug 7 2014, 05:09 AM
Post #22
That looks like a nice piece, and cheaper than a MB cigar hose.
ChrisFoley
post Aug 7 2014, 06:16 AM
Post #23
I am Tangerine Racing
That Jegs piece is perfect.
Phoenix914
post Aug 7 2014, 06:22 AM
Post #24
QUOTE(Racer Chris @ Aug 7 2014, 08:16 AM) *
Looks like it might do the trick until I'm ready to upgrade the whole system to your SS lines. They're on my radar - maybe I can start campaigning for them around Christmas!
ChrisFoley
post Aug 7 2014, 07:45 AM
Post #25
QUOTE(Phoenix914 @ Aug 7 2014, 07:22 AM) *
If they had been readily available a few years ago I might have never started making our adapters.
However, one advantage of my piece is that I can bend it into a 90 or a 180, which improves the hose layout in some installations
stinkindiesel
post Aug 19 2014, 03:45 PM
Post #26
Has anybody identified a suitable fuel filter with 3/8" inlet and outlet? This would save trying to round up a weird hose or adapter. After all, you usually need this when replaciing the filter anyway...
Looks like a Wix 33033 might get you there?
Gary
Kansas 914
post Aug 19 2014, 07:51 PM
Post #27
QUOTE(stinkindiesel @ Aug 19 2014, 03:45 PM) *
Gary
I used to buy mine from Brad at 914ltd.com. He doesn't list it anymore but it was a Wix 33274. Summit racing has them for $5.
http://www.summitracing.com/parts/wix-3327...CFQaCMgodnAEAXA
pete000
post Aug 19 2014, 09:07 PM
Post #28
Fram makes an all metal filter with the 3/8 (10mm) fittings on both ends.
Model G15 at a whopping four bucks !
http://www.summitracing.com/parts/frm-g15
Dave_Darling
post Aug 19 2014, 09:09 PM
Post #29
914 Idiot
QUOTE(stinkindiesel @ Aug 19 2014, 02:45 PM) *
One of the standard 914 fuel filters basically has this--the same size inlet as outlet. This is the one where you need the "converter hose", because the center tunnel line is larger than the filter inlet.
The other one has the big inlet and the small outlet. With this one, you just run the larger hose from the center tunnel line to the large filter inlet.
--DD
mapguy
post Aug 19 2014, 11:01 PM
Post #30
Freelance Generalist
Awesome!
That Wix unit is just the ticket! About to get the SS lines from Chris for my ride while engine/trans are out getting freshened. This takes care of the reducer hose.
You guys rock! (IMG:style_emoticons/default/aktion035.gif)
stinkindiesel
post Aug 20 2014, 07:47 AM
Post #31
[/quote]
[/quote]
Yep, the WIX 33274 is the correct one that has the 8mm inlet and 10mm outlet and needs the reducing adapter hose. I have one of those sitting right here. The old one I pulled out of the car looks identical to the 33274, except it has 8mm inlet and outlet. Wish the part number was visible, but it's worn off. It's a Mahle, but that's all I can make out.
BTW, I looked up the Fram G-15 cross on the WIX web site. It does indeed cross to a 33033. Looking more closely at the specs, though, I see the WIX 33033 rated at 20 microns and the Fram G-15 at 10 microns. I think the Fram G15 is the winner! If you happen to be at one of those FLAPs that kind find their own a$$ without looking it up on their computer, just ask them for a fuel filter for a 1973 BMW 2002.
Gary
bandjoey
post Aug 20 2014, 07:55 AM
Post #32
bandjoey
Bought one like the wix. Don't remember the brand. Check before u buy since mine had the flow backwards. Have to loop the hose to use it. Flow is in on the small end. Out is large end. Autozone sells plastic filter with screw in tips - 3 sizes per kit. I used one for over a year successfully. Finally bought tangerine adaptor. Wish it were about 4" shorter but it does the job with no worry about leaks.
ChrisFoley
post Aug 20 2014, 08:30 AM
Post #33
QUOTE(stinkindiesel @ Aug 20 2014, 08:47 AM) *
33274 is the filter for the late (75-76) fuel system.
It has a 8mm inlet and 12mm outlet.
33003 has 9.5mm inlet and outlet.
33002 has 8mm in and out.
AFAIK Wix doesn't have one with a 9.5mm inlet and 8mm outlet.
stinkindiesel
post Aug 20 2014, 12:22 PM
Post #34
QUOTE(Racer Chris @ Aug 20 2014, 09:30 AM) *
Thanks Chris. That makes sense. I just know the 33274 was "just right" and "too big." I hadn't actually measured the connections. The 33003 and 33033 are essentially the same, with the 33003 being plastic and the 33033 being metal. Same filter element inside.
Phoenix914
post Nov 18 2014, 10:06 AM
Post #35
Has anybody used this WIX filter? The description says 7 mm on both ends.
http://vwparts.aircooled.net/Universal-Fue...031-p/33031.htm
They are cheap and available at a local FLAPS for under $5. Anything has to be better than the square plastic ones.
ChrisFoley
post Nov 18 2014, 11:25 AM
Post #36
QUOTE(Phoenix914 @ Nov 18 2014, 11:06 AM) *
Wix 33002 is a better choice. 8mm inlet and outlet, same size as other fittings in the 914 system.
Phoenix914
post Nov 18 2014, 01:15 PM
Post #37
QUOTE(Racer Chris @ Nov 18 2014, 12:25 PM) *
Crap, well I just bought one on my lunch break. I was thinking since many of the fuel hoses are 7mm, then this would be a good filter.
If I can't make this one work, I will try the 33002. It's even cheaper!
One of the points that sold me on the 33031 was the application chart on the O'Reilly Auto Parts website (where I bought the filter). The 1970 914-6 was listed, so that was good enough for me. At lease the flow rate should be acceptable.
dcheek
post Nov 18 2014, 02:34 PM
Post #38
VW uses a similar hose. I ordered one for one of my cars. I don't remember where it is used, or where I got it. I have to check my files. Give me a day or two and hopefully I can come up with it.
Dave
Mikey914
post Nov 18 2014, 11:59 PM
Post #39
The rubber man
I personally don't like Wix. I had a problem with flow rate being restricted on my 951 and triggering the oil bypass after about 500 miles. Fortunately I was near the dealership and only had to have the oil changed to fix the problem. Got out with less than $100 bill. For the 914, maybe not as much of an issue, but after that the engineering was a question in my mind.
dcheek
post Nov 19 2014, 03:27 PM
Post #40
This is the one I used on my Rabbit a while back. It looks a little shorter and you would have to confirm the diameters. It might be worth a look:
http://www.ebay.com/itm/like/351224921678?lpid=82
Dave
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 08:53 AM
