Stripped Gas Tank Threads |
cary |
Sep 12 2014, 09:36 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Working on replumbing my new fuel pump. So I decided to loosen the nuts that cinch down the fuel tank output pipes. Big one came off without a hitch. The return line, that's another story. The aluminum nut totally stripped out. Steel bung threads are embedded with aluminum.
Has anyone bought the M18 * 1.0 die or thread restorer and cleaned those threads before? Kind of an odd sized thread. Hate to give up on this tank. |
walterolin |
Sep 12 2014, 09:46 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Had the same problem, didn't want to buy a one time chaser (that's what plumbers call it). I took a dental pick and a wire wheel on my Dremel, and picked at the aluminum for a while. It eventually came clean.
Harpo |
Sep 13 2014, 05:13 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
My threads were damaged and I cleaned them up with a thread file. Took about 15 minutes but it worked like a charm
David |
cary |
Sep 13 2014, 08:50 AM
I'll pick up a new wire wheel on the way to the shop. Then I'll do some picking and see if I can get it.
Called Hall Tool. They have a die, but its $30. And they're not open on the weekends. |
Elliot Cannon |
Sep 13 2014, 09:31 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
If the outside threads are totaled, you can tap threads on the inside and use a different fitting.
Harpo |
Sep 13 2014, 06:52 PM
Depending on the OD of the die the second (return) fitting might to too close to thread the die on. A thread file will fit between the two fittings. One metric file has two ends and four sides per end yielding eight common thread pitches. A whole lot cheaper than 8 dies.
http://www.amazon.com/Allstar-Performance-...d/dp/B003BZLK6O |
cary |
Sep 13 2014, 07:55 PM
I have one of those. Won't fit up against the rib.
The wire wheel and the picks did pretty good. The thread file helped in a couple spots. I think if a had a steel nut I could finish it up ............. The aluminum one starts about 2 threads........... so i'm making progress. |
cary |
Sep 15 2014, 08:31 AM
Did a little more research. Looks like the M18*1.0 is the only spindle nut that Nissan/Datsun has ever used. Comes in a Dorman kit or in a five pack.
I think I'll still get the die if its narrow enough to fit between the threads and the flange. I still five more cars awaiting restoration.............. |
cary |
Sep 15 2014, 09:16 PM
Die was a no go. Way too big. We have about .33" of space to work with. It would have needed about about .75" for the die to make a complete turn.
Stopped at my go to hardware store (Winks) to look for a nut. No go. They only went down to M18*1.5. Ordered the Nissan spindle nuts at the flaps. Should be in first thing in the am. I'm going make a thread restorer with one of them. |
cary |
Sep 16 2014, 09:08 PM
Nuts did the job!
Cut a groove with a triangle file. Worked like charm. |
puffinator |
Oct 12 2014, 04:02 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
cary |
Oct 12 2014, 06:39 PM
I can do that ..................
Going work in the middle of the night. So I might run out to my shop in the afternoon. |
Kansas 914 |
Oct 13 2014, 09:38 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I can do that .................. Going work in the middle of the night. So I might run out to my shop in the afternoon. Can you confirm these are 18mm 1.0 threads? I need to do this as well. You might can make some decent money for these prepped with the "V" to cut threads for gas tanks. I would buy one. |
cary |
Oct 13 2014, 06:51 PM
Confirm : 18m * 1.0.
Might give it some consideration. But I'd need to buy a bigger V vile. And something to clean the threads with. When you start to tidy up the threads The main thing is to use oil cutting oil. Then only turn about a 1/4 to 1/3rd of a turn. Back it off. Clean it again. Rinse and repeat. |
Eric_Shea |
Oct 14 2014, 07:07 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE would you sell one of your nuts? (IMG:style_emoticons/default/blink.gif) I knew it would come to this. Andy... time to shut'r down. (IMG:style_emoticons/default/sad.gif) |
Kansas 914 |
Oct 14 2014, 07:10 PM
QUOTE would you sell one of your nuts? (IMG:style_emoticons/default/blink.gif) I knew it would come to this. Andy... time to shut'r down. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/lol-2.gif) |
r_towle |
Oct 14 2014, 07:25 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
QUOTE would you sell one of your nuts? (IMG:style_emoticons/default/blink.gif) I knew it would come to this. Andy... time to shut'r down. (IMG:style_emoticons/default/sad.gif) Sure, someone talks about selling a nut and Eric comes out of hiding. |
Eric_Shea |
Oct 14 2014, 07:33 PM
Not hiding. "still" at the shop. As you can see, I still have to vaccum. (IMG:style_emoticons/default/sad.gif)
sbsix |
Oct 15 2014, 03:44 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 451 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Eric, vacuuming and drinking beer do not mix.
Kansas 914 |
Oct 16 2014, 07:43 AM
Confirm : 18m * 1.0. Might give it some consideration. But I'd need to buy a bigger V vile. And something to clean the threads with. When you start to tidy up the threads The main thing is to use oil cutting oil. Then only turn about a 1/4 to 1/3rd of a turn. Back it off. Clean it again. Rinse and repeat. Thanks Cary. I am having a tough time sourcing these. Where did you get yours? Is there a Dorman number? |
Lo-Fi Version | Time is now: 31st May 2024 - 11:55 PM |
