| PanelBilly |
Mar 1 2015, 06:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I went to install the shafts today and noticed that the bolts I have are too small (diameter). They are the right size for the transmission side. Aren't they the same?
| 914Sixer |
Mar 1 2015, 07:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Both sides should be the same M8X48mm
| Tom |
Mar 1 2015, 07:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Billy,
All of the CV bolts are the same. Could you maybe have put the bolt in one of the pin holes? That is one reason why I had wanted to do mine by removing the whole axle to include the stub axle. I had heard of others having line up issues with getting the pins in fully before being able to start the bolts with the stub axle already in the bearing housing. Try starting one or two of the bolts right in the stub axle to make sure the bolts are the right size. Tom, Made it home OK, traffic was pretty light! (IMG:style_emoticons/default/smile.gif) PS: I left my Haynes manual on the rear trunk. (IMG:style_emoticons/default/sad.gif) Just keep it safe for me until we get together again. |
| Steve |
Mar 1 2015, 08:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Did someone do a five lug conversion and use 911 stubs? My stubs and transmission flanges are M10 (108mm CV's both sides).
| PanelBilly |
Mar 1 2015, 09:41 PM
They are diffinately bigger. I had the 5 lug conversion done by Eric Shea. Eric you out there?
| PanelBilly |
Mar 1 2015, 10:05 PM
Just found my original paperwork from PMB and it says 911. Now will my 914 CV's still work?
| JRust |
Mar 1 2015, 10:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Just found my original paperwork from PMB and it says 911. Now will my 914 CV's still work? No they will not. You need 911 axles. 944's I think will work too but seems like there is more to it. You just need to get the 911 flanges for the tranny. They are a direct replacement so no biggie there. I think the early 911 axles are a little shorter than 73 on. Hopefully someone else will chime in |
| Mike Bellis |
Mar 1 2015, 10:25 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Best prices for new axles is here. You will need to measure the correct length.
http://www.pacificcustoms.com/porsche-930-...moly-axles.html |
| Steve |
Mar 1 2015, 10:46 PM
Check the classic threads section to look through the axle threads.
http://www.914world.com/bbs2/index.php?act=SF&s=&f=5 I am running early 911 stuff with 108mm CV's, stub axles and flanges. Swayaway makes the axles that work with the bigger CV's. All covered in the above classic threads. |
| PanelBilly |
Mar 1 2015, 11:32 PM
Guess I'm going to be selling my powder coated axles with new cv's greased up and ready to install. Got new bolts and schorr's too
| Larmo63 |
Mar 2 2015, 12:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
maybe you need 914-6 stub axles?
| sixnotfour |
Mar 2 2015, 02:45 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
looks like 108's
use 944 stubs/CV and keep your axles and trans end cv http://www.914world.com/bbs2/index.php?sho...486&hl=axle Attached image(s)
| SirAndy |
Mar 2 2015, 11:38 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you need 911 axles. 911 axles are too short for any 914 ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:39 AM |
