| euro911 |
May 15 2015, 08:00 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Any updates, Mark?
| worn |
May 15 2015, 08:09 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| boxsterfan |
May 15 2015, 08:12 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Awesome on this high output alternator!! Perhaps electric heat is a possibility (giggle)!!
| McMark |
May 15 2015, 09:52 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Awesome on this high output alternator!! Perhaps electric heat is a possibility (giggle)!! Actually, I've already picked out a heater unit to try. It's 50amps, but with this alternator, that still leaves me 100 amps to spare! (IMG:style_emoticons/default/ohmy.gif) |
| euro911 |
May 15 2015, 10:58 PM
Yep, an electric heater's been on my list for a long time (IMG:style_emoticons/default/aktion035.gif)
| boxsterfan |
May 16 2015, 12:23 AM
Awesome on this high output alternator!! Perhaps electric heat is a possibility (giggle)!! Actually, I've already picked out a heater unit to try. It's 50amps, but with this alternator, that still leaves me 100 amps to spare! (IMG:style_emoticons/default/ohmy.gif) What's the estimate for how much HP that alternator is going to steal away? |
| Dtjaden |
May 16 2015, 10:29 AM
Member ![]() ![]() Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Hi Mark,
Electric heaters have been discussed before and usually the conclusion has been that they will not provide enough heat, but --- I decided to revisit the formulas for heat generation and temperature rise in a confined space. 600 watts = 2047 btu I estimated the 914 cabin space as 75 cubic feet. I also assumed it was poorly insulated. 2047 btu's will raise the temperature of that space between 25 and 30 degrees. This assumes that the cabin air is recirculated, not outside air being heated and directed into the cabin. So...I think this may have a chance of working out. If so, I may have to drive up to see you since my car has no heat (headers)! Darryl |
| sixnotfour |
May 16 2015, 01:08 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
I have used this one for two years ..works great...
has low / high switch http://dcthermal.com/catalog/sa12-5000-bru...ss-cabin-heater |
| boxsterfan |
May 16 2015, 04:46 PM
I have used this one for two years ..works great... has low / high switch http://dcthermal.com/catalog/sa12-5000-bru...ss-cabin-heater Got some pics of your setup? |
| Dtjaden |
May 16 2015, 07:40 PM
Just a caution on the heat output claims many of the Internet resellers make. Watts and BTUs are directly convertible units. One watt = 3.41 BTUs. A heater that draws 50 amps at 12 volts CANNOT produce than 2047 BTUs - not the 10,000 BTUs claimed by DCThermal.
That being said, as I stated in my post earlier, 2047 BTUs of heat generation will probably siffice for those of us that live in moderate climates. It would do little to warm a 914 in Minnesota but neither did the standard heat exchangers. Darryl |
| boxsterfan |
May 16 2015, 07:44 PM
Just a caution on the heat output claims many of the Internet resellers make. Watts and BTUs are directly convertible units. One watt = 3.41 BTUs. A heater that draws 50 amps at 12 volts CANNOT produce than 2047 BTUs - not the 10,000 BTUs claimed by DCThermal. That being said, as I stated in my post earlier, 2047 BTUs of heat generation will probably siffice for those of us that live in moderate climates. It would do little to warm a 914 in Minnesota but neither did the standard heat exchangers. Darryl Yeah, I'm in the Bay Area. Put in some seat heaters and minimal heat could work. I guess the big deal is can you get enough heat to defrost the windshield of needed. |
| McMark |
May 24 2015, 08:09 PM
Installed this today. Went just as smooth as expected, although I did need a smaller belt because this has a smaller pulley. Went with a 940mm unit. Made my own power cable with the new big-ass crimper I got. Didn't notice a damn bit of difference on my drive home, which is a good thing. That means everything is working like it should. Now time for electronic goodies like seat heaters.
| boxsterfan |
May 24 2015, 09:40 PM
| boxsterfan |
Aug 8 2015, 12:29 PM
Did you ever try your electric heat unit? Seat heaters are going to work for sure. And for mild climates, an electric heater that pushes even some meoderately warm air (mostly for a defrost of the window situation) is all that is needed.
| MSHax |
Aug 8 2015, 12:39 PM
Member ![]() ![]() Group: Members Posts: 55 Joined: 8-August 15 From: California Bay Area Member No.: 19,039 Region Association: Central California |
That's pretty cool! Back in the day I modified a 1 wire 150 amp GM alternator to fit in my 74 914. Worked great, but I decided to do a restore so that meant no GM parts. I'm a HUGE fan of the toys; seat heaters, power windows, remote start, etc. All that stuff adds up quickly. I have no intention of putting anything other than power locks, and keyless entry, in my 914, but I still want a higher output alternator. I'll wait until mine dies first (IMG:style_emoticons/default/tongue.gif)
| McMark |
Aug 8 2015, 12:44 PM
Not yet. After the move and I get settled in the new shop there should be way more time for these fun R&D side projects. It's one of the reasons I'm moving.
Lo-Fi Version | Time is now: 2nd April 2026 - 07:04 AM |
