| VWTortuga336 |
Nov 22 2015, 09:23 AM
Member ![]() ![]() Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
I know I've seen it posted before, but for the life of me I can't find it.
Can someone please let me know the temperature range on the stock oil temp gauge? I'm trying to decide if I can just use the stock gauge to watch the oil temp on my 2366, or if I need to get one that has "real" numbers on it. Thanks in advance. |
| sfrenck |
Nov 22 2015, 10:23 AM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
I found that when I tipped my gauge up, there was a range written at the very top.
| VWTortuga336 |
Nov 22 2015, 11:27 AM
Exactly what I was looking for, thanks!
So the "redline" starts at 316°F (IMG:style_emoticons/default/blink.gif) Looks like I should invest in a gauge with a little more resolution. Can I use the existing wiring and sender with an aftermarket VDO? |
| 914Sixer |
Nov 22 2015, 02:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Sender will need to match gauge scale. If you use the 911 300 degree scale you will need the 911 sender.
| VWTortuga336 |
Nov 22 2015, 02:53 PM
Looking again, my gauge is a different than yours. Here is a pic of mine, there aren't any temp numbers on mine.
| dangerranger01 |
Nov 22 2015, 02:55 PM
Member ![]() ![]() Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
| Highland |
Nov 22 2015, 05:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 559 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
| porschetub |
Nov 23 2015, 12:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Looking again, my gauge is a different than yours. Here is a pic of mine, there aren't any temp numbers on mine. ![]() I have been mucking around with these gauges for a while,I think the one you have reads to 150C,this is a pic of one I built; .Yours is unmarked in the upper part of the insert but i'am fairly sure it is 150C max and you can run a 100C sender with it. Now I have a 77 911 one which is more correct for my -6 conversion,300F and works with 150C VDO sender. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:37 AM |
