| TheCabinetmaker |
Nov 23 2015, 02:28 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
If'n it were me, I would just pull the tranny and replace the seal, out the tranny back in, unless you wanted to pull the engine anyways in prep from the rebuild. (IMG:style_emoticons/default/agree.gif) And then my post above applies. You must have missed the part about the rear main thrust bearing being damaged. It needs to be replaced. The crank is walking, and eating the rear of the bearing where the 3 end play shims reside. I've seen it before. I can hear the crank moving fore and aft. |
| euro911 |
Nov 23 2015, 03:39 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
(IMG:style_emoticons/default/sad.gif) ... (IMG:style_emoticons/default/dry.gif)
| rgalla9146 |
Nov 23 2015, 09:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Did I miss the part about what engine it is ?
4 or 6 cyl ? Any chance you have blocked crankcase ventilation ? IF a 4 cyl., your crank end play is so great that the seal is being pushed out of the case ? !!! With the seal out you can re-set the end play no ? |
| r_towle |
Nov 23 2015, 09:12 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Why do you think this happened?
Bearing failure? |
| colingreene |
Nov 24 2015, 12:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 752 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Possible the shim stack might not have been right?
| TheCabinetmaker |
Nov 24 2015, 01:26 PM
| r_towle |
Nov 24 2015, 07:08 PM
Did you build the motor?
| TheCabinetmaker |
Nov 24 2015, 07:15 PM
| r_towle |
Nov 24 2015, 08:05 PM
| TheCabinetmaker |
Nov 24 2015, 08:11 PM
| r_towle |
Nov 30 2015, 11:11 PM
Soooo
Did you get it done? |
| TheCabinetmaker |
Dec 1 2015, 02:46 AM
Sure rich. I removed the drive train, split the case, replaced the mains, put it back together, and the car is on the road.
For my next miracle I'm gonna walk on water. (IMG:style_emoticons/default/finger.gif) |
| euro911 |
Dec 1 2015, 03:41 AM
| r_towle |
Dec 3 2015, 07:55 PM
Sure rich. I removed the drive train, split the case, replaced the mains, put it back together, and the car is on the road. For my next miracle I'm gonna walk on water. (IMG:style_emoticons/default/finger.gif) You asked if you could swap it to the 1.8 in a weekend. That was the question. Just asking if you pulled it off. As for your wise ass comment, a four day weekend, it could have been done...all of it (IMG:style_emoticons/default/biggrin.gif) |
| TheCabinetmaker |
Dec 3 2015, 08:03 PM
I already figured out that was what you meant rich. I guess I can be a little slow sometimes. I actually got my truck running and legal so it became not so important. The car is setting in my shop till work load says I have time.
| Spoke |
Dec 3 2015, 08:27 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I just went from 1.8L with FI to 2056 with carbs. Love the additional power. I couldn't imagine the letdown going from 2056 back to a 1.8L. (IMG:style_emoticons/default/sad.gif)
| r_towle |
Dec 3 2015, 08:28 PM
Oh no....put it on Jack stands to give it a proper resting place till you "get to it" like the rest of us.
| TheCabinetmaker |
Feb 9 2016, 07:14 AM
Up date. I've been driving the old truck while redoing the engine. Actually had all the necessary gaskets, and bearings on the shelf. Only had to purchase new Hastings rings. It was indeed the end play set incorrectly. Destroyed the trust bearing, and the #3 main was also showing some wear. Got to it just in time. Had crank and cam polished, and heads refreshed. Engine has been ready for a month, but just had no time. Customers waiting on their new kitchens. Yesterday was the day! Rolled the engine under the car 2:30 yesterday and fired it up at 4:30. Then drive it home at 8:00.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i290.photobucket.com-666-1455023648.1.jpg) |
| CatDaddy60 |
Feb 9 2016, 07:34 AM
Member ![]() ![]() Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
Up date. I've been driving the old truck while redoing the engine. Actually had all the necessary gaskets, and bearings on the shelf. Only had to purchase new Hastings rings. It was indeed the end play set incorrectly. Destroyed the trust bearing, and the #3 main was also showing some wear. Got to it just in time. Had crank and cam polished, and heads refreshed. Engine has been ready for a month, but just had no time. Customers waiting on their new kitchens. Yesterday was the day! Rolled the engine under the car 2:30 yesterday and fired it up at 4:30. Then drive it home at 8:00. (IMG:http://www.914world.com/bbs2/uploads_offsite/i290.photobucket.com-666-1455023648.1.jpg) Way to go! My first car a 68 bug was purchased with serious end play, I feel your pain, good job catching it when you did mine cost a set of cases and more than a few "told you so's" from my Dad. That was a few cars and years ago but we laugh about it now. |
| rhodyguy |
Feb 9 2016, 08:15 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Super! But you make the rest of of us slackers look worse than we already are. Nice collection of saw horses. I used to have a set made from 2x6s that was 6' tall.
Lo-Fi Version | Time is now: 2nd April 2026 - 09:34 AM |
