> Fire wall liner, heavy @ dirty
80cap
post Jan 24 2016, 07:54 AM
Is the heavy rubber like fire wall liner necessary or does dynomat or
similar sound mat just as good?
Thanks Brian (IMG:style_emoticons/default/confused24.gif)
dflesburg
post Jan 24 2016, 08:34 AM
we use hood liner in the engine bay and dyno mat in the passenger compartment in our cars and it is good.
I don't like it on the floor surfaces as it can trap water, we put it on the underside of the floor mats....
80cap
post Jan 24 2016, 08:39 AM
What is hood liner?
Brian
Garland
post Jan 24 2016, 09:26 AM
Restoration Fanatic
Here's a factory pad. I'm debating what to use to attach it with. I'm thinking something other then glue, any ideas?
cary
post Jan 24 2016, 10:47 AM
Here's what 914 Rubber sells.
http://shop.914rubber.com/Fireall-backpad-foil-914FWF.htm
Mikey914
post Jan 24 2016, 12:12 PM
The rubber man
I also have the rubber aircraft firewall material precut at $120 a pop (just not listed as we just completed another run. I would use Velcro to attach as you can easily remove later.
80cap
post Jan 24 2016, 12:13 PM
The 914 rubber pad goes on the engine side.
The one pictured above is the interior pad.
That is the one I'm referring to.
Brian
saigon71
post Jan 24 2016, 02:16 PM
I went with Rattle Trap on the inside (similar to dynomat but slightly thicker) and a firewall pad from 914 rubber on the engine side. Gives a comfortable sound level in the cabin.
r_towle
post Jan 24 2016, 04:15 PM
Custom Member
QUOTE(Garland @ Jan 24 2016, 10:26 AM) *
That rubber piece does two things
It blocks a specific set of sound frequencies.
It blocks noisy vibration if firmly attached to the firewall.
So, how you attach it will determine how good it works.
Noise is both sound frequencies and sound vibration....
Velcro (the 3m command strips are very strong) may be a choice that could work.
Dave_Darling
post Jan 24 2016, 04:18 PM
914 Idiot
Early 914s and 914-6es did not have the pad on the engine bay side of the firewall. Its primary purpose any more seems to be to hold water against the wall, promoting rust. Mine is long gone.
--DD
Garland
post Jan 24 2016, 04:28 PM
Restoration Fanatic
Went ahead and glued it on, used 3M super 77 both surfaces. Wanted It to lay down flat, some areas required a little heat to level out. Even found the part number.
r_towle
post Jan 24 2016, 05:07 PM
Custom Member
Cool, that will work.
dflesburg
post Jan 24 2016, 05:20 PM
hood liner is like dyno mat but thermal and thicker. google it
dflesburg
http://www.amazon.com/Dynamat-11905-Hoodli...r/dp/B00069QLVC
Larmo63
post Jan 24 2016, 11:51 PM
I took Dave's advice, and just now ripped all that shit off of the firewall in the black car. Removed, vacuumed, and cleaned up in there. That is all the fiber pad really does, is make the firewall inside the engine compartment rusty, and cause you to haul around extra dead weight. What a POS.
Mikey914
post Jan 25 2016, 12:15 AM
The rubber man
Sorry, thought you were talking about the engine side
I did replace mine with dynamat. Lighter and more sound deadning.
- Lo-Fi Version Time is now: 2nd April 2026 - 08:53 AM
