> Resealing the rear glass
JPA914
post Apr 10 2016, 07:59 PM
Just got done doing this. I used the 3/8" butyl from Napa that seems to be recommended most often (part# MS 4196). Has anybody else who has used this ended up with a gap between the glass and engine lid seal? I pressed the glass in as far as it would go, but I think maybe this butyl is too thick and prevents the glass from seating as far back as it should (IMG:style_emoticons/default/confused24.gif)
PancakePorsche
post Apr 10 2016, 09:52 PM
I think 3/8 would be way too thick. thickness of seal should not really exceed 1/8 after install. I believe I used 1/4 and put it in on a warm day to get good 50% minimum squish.
dangrouche
post Apr 10 2016, 10:00 PM
dangrouche
I have used 5/16"
Valy
post Apr 10 2016, 10:25 PM
I used 3/8. No issue.
JPA914
post Apr 11 2016, 08:56 AM
QUOTE(Valy @ Apr 10 2016, 11:25 PM) *
I'm glad it worked for you. In my case, however, it's simply too thick. No way to avoid a gap where water can collect between the glass and the engine lid seal.
Jett
post Apr 11 2016, 09:02 AM
I used 3/8" and had to heat the tape to get the seal. I used a heat gun and kept pressing until it hit the seal.
JPA914
post Apr 11 2016, 09:41 AM
QUOTE(Jett @ Apr 11 2016, 10:02 AM) *
Thanks, I'll give that a try.
tomrev
post Apr 11 2016, 12:16 PM
You can also get a tube of the black poly sealant, at a glass shop. (same stuff modern windows are installed with). I have used that on the last 914 windows I resealed, with great results, and the ability to press the window nice and snug in position. Tape it in with some masking tape, and let her set for a day.
Mikey914
post Apr 11 2016, 12:43 PM
The rubber man
Pretty much covered in detail and I still stock the butyl and spacer blocks.
http://www.914world.com/bbs2/index.php?sho...p;hl=rear+glass
Chord
http://shop.914rubber.com/searchquick-subm...?keywords=butyl
Blocks
http://shop.914rubber.com/914-Windshield-s...ck-914-WSSB.htm
The real key is making sure both surfaces are clean.
JPA914
post Apr 11 2016, 01:27 PM
QUOTE(Mikey914 @ Apr 11 2016, 01:43 PM) *
Chord
Blocks
Thanks, is this butyl 3/8" or is it thinner? And what's up with step #3 in the instructions? Connect each end of the butyl to a battery?!?!?
SA-914
post Apr 11 2016, 07:16 PM
The battery was used in the original wired install. It had a wire in and when you connected it to the battery, it would melt the seal.
I just installed my window using 914rubber, and have the same problem.... It's close, but I gave up. It will have to do. Used a heat gun and large block to try to spread the load, but still have a small gap. I also have what seems to be excessive butyl on the outside.
Mikey914
post Apr 11 2016, 07:36 PM
The rubber man
If you have heat issues. You may want to use the urethane.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:55 AM
