| audio_file |
Sep 9 2016, 11:49 AM
Member ![]() ![]() Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
Finally about to get the green car on the road! I'm in the middle of purchasing the final bits I'll need to finish her up, one of those things is the "t-bar" looking mount for the full Triad system I've got- mounts to the transmission where the boomerang would normally be and then uses hose clamps to attach to the muffler to give the whole system some support. My pre-owned system didn't come with that piece, so I'll need to fab something up, anybody have a picture or measurements for that piece?? Here's the only view of it I can find....
Thanks! ![]() |
| DRPHIL914 |
Sep 9 2016, 11:59 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
not sure I follow what you are doing, the muffler should mount directly to the heat exchangers or header system with a gasket between the two flanges, then the stock boomerang muffler support will attach to the muffler and HE on each side and that is your support to the header/H.E. and muffler- no other bracket or hose clamps - I have a Triad and SS HE(back dated 74 system)
| audio_file |
Sep 9 2016, 12:02 PM
Philip, when using the 4-1 headers from triad (eurorace style) the boomerang bar doesn't get used, there is a different method of supporting the exhaust system and that's what I need to see/buy/fabricate...
| DRPHIL914 |
Sep 9 2016, 12:07 PM
gotcha! maybe someone else will chime in then. the stock set up was easy, and even the Tangerine racing set up still has the same flanges on the headers........ if I were getting a header system that would be the one- but 2 things I love about the triad, the sound, and 2. the cost!!! had mine for 5 years now, still like new!
good luck, post some larger pictures, im wondering what the header and the muffler look like with out the stock flanges that normally are used to attach one to the other |
| audio_file |
Sep 9 2016, 12:13 PM
Here's the setup (IMG:style_emoticons/default/piratenanner.gif)
And the only larger pic I can find, from another thread here... (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-13409-1473444828.1.jpeg) |
| rhodyguy |
Sep 9 2016, 12:23 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What does Dave suggest?
| audio_file |
Sep 9 2016, 12:47 PM
Dave doesn't build the headers anymore from what I understand, and says he never really found a "good" bracket setup...
I've found eurorace brackets that they sold to go with their headers, but only to use with a megaphone, not sure it'll really do what I need it to do with the Triad. http://www.gt-racing.com/porsche-914-europ...-part-914-4-ba/ |
| rhodyguy |
Sep 9 2016, 04:16 PM
The 75-76' brackets are the widest and might give you enough to bend the ends rearward to fab something up.
Cable spacing so it doesn't burn up looks like a hassle. |
| carr914 |
Sep 9 2016, 06:59 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,990 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'll take a picture of mine in the morning - it's about time for a Drive! (IMG:style_emoticons/default/driving.gif)
| audio_file |
Sep 9 2016, 08:31 PM
Thank you sir! (IMG:style_emoticons/default/beerchug.gif)
| carr914 |
Sep 9 2016, 08:56 PM
| carr914 |
Sep 10 2016, 10:05 AM
I'll take a picture of mine in the morning - it's about time for a Drive! (IMG:style_emoticons/default/driving.gif) Sorry, I misunderstood - I don't have the Full Triad exhaust. I've got S/S Exchangers going into a Triad Exhaust |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:39 PM |
