| shane |
Nov 3 2016, 07:15 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
I'm sure this gets asked every so often , but I'm trying to figure out what primer, base and clear to get for a re-spray, no bare metal. Something that looks good and not way expensive. The color is going to be Baja red. And a good online place to buy from. Thanks in a advance for any help with this.
| Chris914n6 |
Nov 3 2016, 08:14 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Go to a local paint store. The free advice is worth the little extra cost.
The counter guy I talked to still paints his own stuff and actually recommended a mix match of brands based on my color and clear (UV) needs that was known to be good and not based on the cheapest or priciest. |
| altitude411 |
Nov 3 2016, 08:38 PM
I drove my 6 into a tree ![]() ![]() ![]() Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains
Head over to the bird site. Fantastic paint and bodywork forum. Lots of info and 962porsche is the resident guru. (IMG:style_emoticons/default/beerchug.gif)
http://forums.pelicanparts.com/paint-bodyw...scussion-forum/ |
| saigon71 |
Nov 4 2016, 08:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
Agreed on buying from a local paint shop. Much easier to handle any problems and get advice.
Have you considered using single stage paint? I had mine shot in acrylic enamel over the existing paint years ago. It's holding up very well and still looks good. |
| worn |
Nov 4 2016, 09:46 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Head over to the bird site. Fantastic paint and bodywork forum. Lots of info and 962porsche is the resident guru. (IMG:style_emoticons/default/beerchug.gif) http://forums.pelicanparts.com/paint-bodyw...scussion-forum/ Speaking of the bird - and not to really hijack the thread - Is it my imagination or has the bird taken a bit of a nose dive? No longer are there product descriptions very often poor pictures, the wiring diagrams aren't in evidence any more, etc. I know that the seller of overcooked SUVs threatened them when they used photos from the PRTs, but this seems broader. The cheap way is to set up a forum and get a reputation for the advice given by itself. BTW - I wanted original and went with DCC. But I did go to bare metal with epoxy DT-40 and then K36 primer. All in the same paint family. I so love epoxy primer!! You know you can use it as a sealant to block off the old paint. |
| Chris914n6 |
Nov 4 2016, 01:32 PM
The sun trashes red dyes faster than all the others. Otherwise I don't have an issue with single stage for a low budget makeover.
| worn |
Nov 4 2016, 02:12 PM
| PancakePorsche |
Nov 5 2016, 11:43 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Epoxy primer/sealer and single stage polyurethane. PPG is good all around for the price.
| Chris914n6 |
Nov 6 2016, 12:15 PM
The sun trashes red dyes faster than all the others. Otherwise I don't have an issue with single stage for a low budget makeover. Yeah, that is what my paint guy told me. But red it started with... Then spray a good clear over it. I think my guy liked the ProSpray clear as best band for the buck. |
| Wdunster |
Nov 7 2016, 07:06 AM
Panel beater ![]() ![]() Group: Members Posts: 173 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
Go to a PPG Jobber(auto paint supplier) and get the shop line products. 2k primers base and the euroclear. Very in expensive but will look great and hold up way longer than a single stage. Also very repairable if damaged later.
Good luck. |
| Mikey914 |
Nov 7 2016, 10:15 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I've used PPG been quite happy with results.
| mgp4591 |
Nov 8 2016, 03:02 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,908 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
Is there a self etching primer that works well with existing paint if it's properly prepared?
| Mark Henry |
Nov 8 2016, 05:38 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
For base primer I've always felt PPG epoxy is one, of if not the best primer/sealers.
I don't paint much now, but I've had good results with PPG paints even their lower tier line and also on the cheap end DuPont Nason is excellent. I won't use the real cheap no name brands. Chromacoat you can no longer get, never have tried the water based paints. IIRC scooter really likes Spies-Hecker, high end paint. Black DuPont Nason is what use for chassis parts, great stuff, wears like iron. I've even brushed it on with decent results. Nason is originally a truck/fleet paint. |
| Wdunster |
Nov 8 2016, 05:57 AM
For base primer I've always felt PPG epoxy is one, of if not the best primer/sealers. I don't paint much now, but I've had good results with PPG paints even their lower tier line and also on the cheap end DuPont Nason is excellent. I won't use the real cheap no name brands. Chromacoat you can no longer get, never have tried the water based paints. IIRC scooter really likes Spies-Hecker, high end paint. Black DuPont Nason is what use for chassis parts, great stuff, wears like iron. I've even brushed it on with decent results. Nason is originally a truck/fleet paint. (IMG:style_emoticons/default/agree.gif) the PPG epoxy is an excellent product. When I was in restoration we used the epoxy on raw steel chassis and frames. It sticks extremely well. The inexpensive stuff is better than it used to be. I would try to stick with something that is covered by the paint companies lifetime warranty. That typically means the UV protection is better and will hold up to sunlight. |
| Dave_Darling |
Nov 8 2016, 05:07 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
... No longer are there product descriptions very often poor pictures, the wiring diagrams aren't in evidence any more, etc. I know that the seller of overcooked SUVs threatened them when they used photos from the PRTs, but this seems broader. The wiring diagrams are still there, but it's more of a hunt for them. They're under the parts diagrams now, which still require a hunt to find. The other stuff is probably symptomatic of a business expanding fairly rapidly and not able to put as much care into things as they had been originally. Or at least, that's my guess. --DD |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:55 AM |
