| Mikey914 |
Nov 18 2016, 01:55 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
PMs sent to all -
The CHT GB closed, but I If you bumped the thread You should have got the code. It's possible I missed you, but I'll take care of you (IMG:style_emoticons/default/biggrin.gif) Mark |
| brant |
Nov 18 2016, 02:04 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Mark,
I need to get a set of these gaskets if the GB is still open thank you brant |
| jesse7flying |
Nov 20 2016, 01:52 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None
I'm in for a set. Sent you a PM, but not sure you got it .Thanks
Jesse |
| smg914 |
Nov 20 2016, 02:49 PM
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,987 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
I'll take a set for the creamsicle which is currently missing these gaskets.
Can these gaskets be replaced/installed without removing the heat exchangers? I'm thinking the allen screws might make it possible without removing them. |
| toadman |
Nov 20 2016, 04:10 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
I would like one set of these seals in silicone, please.
| Mikey914 |
Nov 21 2016, 01:10 AM
PMs sent to all so far.
| buck toenges |
Nov 21 2016, 12:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 554 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None
I am a bit confused you have 3 different prices for these. You have 2 different numbers which I believe are for 2 different sizes and another price of $20.00 for a pair(?). Would you please elaborate?
Thanks, Buck |
| Mikey914 |
Nov 21 2016, 12:10 PM
I have 3 different listings
one for the 021256325A gasket alone http://www.shop.914rubber.com/021256325A-H...m?categoryId=-1 One for the 021256326A gasket alone http://www.shop.914rubber.com/021256326A-H...m?categoryId=-1 And the one that should have been in the PM I sent with the code for all that bumped the thread - The Kit with screws http://www.shop.914rubber.com/021256325A-0...m?categoryId=-1 The discount code only works on the kit. |
| plas76targa |
Nov 21 2016, 06:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
Mike Please count me in for one "Iimpvved kit"). Send a PM cost details. Thanks, Matt This is an "improved" kit that uses a slightly softer high temp silicone to seal the cover plate that joins the blower housing to the sheet metal portion of the heat exchanger on the bottom. I have included 4 allen head screws with washers. These allow you to get good tension on the screw, and to remove easily without destroying the screw. I can provide as cork if you prefer at the same cost, but This should be a reusable gasket that is now inexpensive! Compare to 021256325A and 021256326A These go where the sheet metal attaches to the blower. The ones I removed were pitiful. Most are missing completely. http://shop.914rubber.com/021256325A-02125...m?categoryId=-1 |
| Shadowfax |
Nov 21 2016, 07:03 PM
Show us the meaning of haste ![]() ![]() ![]() Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States
Please put me down for one also, Mark. Thanks!
P.S. Any way to combine this order with your upcoming Black Friday specials? |
| smg914 |
Nov 27 2016, 04:50 PM
Can these gaskets be replaced/installed without removing the heat exchangers? I'm thinking the allen screws might make it possible without removing them. I will answer my own question. Yes, these gaskets can be replaced without removing the the heat exchangers. The passenger side is a piece of cake. The drivers side is a little more difficult but the allen head screws really make the job much easier. |
| jim_hoyland |
Nov 28 2016, 05:56 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Just saw this today.. I want a set too.
BTW: I showed my local Porsche mechanic your 1.8 Throttle Body gasket; he really liked it ! |
| Mikey914 |
Nov 28 2016, 11:01 PM
PjMs sent to all
| euro911 |
Dec 14 2016, 06:54 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Mark, I just saw this ... I was in AZ working on the new house and not on the board very much (IMG:style_emoticons/default/dry.gif)
I'd like to get two sets of these gaskets ... Too late for the discount? (IMG:style_emoticons/default/confused24.gif) I really need to go to the site and see what other great new items you've released recently (IMG:style_emoticons/default/type.gif) |
| MartyYeoman |
Dec 14 2016, 11:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,546 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California
Mark,
Please count me in for a set if still available. Thanks, Marty |
| Mikey914 |
Dec 14 2016, 11:46 PM
Ok. Merry Christmas
Just dropped these on sale on the site http://shop.914rubber.com/021256325A-02125...m?categoryId=-1 |
| euro911 |
Dec 15 2016, 01:26 AM
Thanks Mark ... I just sent in an order for a bunch of little goodies (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/santa_smiley.gif) |
| MartyYeoman |
Dec 15 2016, 01:52 PM
Ordered and PayPal sent. (IMG:style_emoticons/default/pray.gif)
| Mikey914 |
Dec 15 2016, 02:10 PM
Left it open til Christmas for those that missed it.
| barefoot |
Dec 15 2016, 04:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
This is an "improved" kit that uses a slightly softer high temp silicone to seal the cover plate that joins the blower housing to the sheet metal portion of the heat exchanger on the bottom. Compare to 021256325A and 021256326A These go where the sheet metal attaches to the blower. The ones I removed were pitiful. Most are missing completely. http://shop.914rubber.com/021256325A-02125...m?categoryId=-1 What we really need are the meal cover plates that hold these seals. Most S tubes you can find are missing the caps. |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:04 AM |
