| yellow75 |
Apr 19 2017, 07:19 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
I have been trying to track down a leak in my transaxle. New seal and O ring in speedo angle drive. needed that but it didn't fix the drip.So I cleaned the trans with brake clean and took it out for a drive. Gear oil seems to be coming from the front part of the gearbox where it meets the engine case and coming out the vent hole at the bottom of the bell housing case. Given all that, I'm thinking the input shaft seal is leaking. Am I on the right track? Any other usual suspect places that it could be coming from?
| 76-914 |
Apr 19 2017, 08:36 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Yep, your on the right trail. It is easily removed w/o splitting the trans. (IMG:style_emoticons/default/beerchug.gif)
| yellow75 |
Apr 19 2017, 12:40 PM
same as a VW? Is trans removal a one man job?
| porschetub |
Apr 19 2017, 02:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
same as a VW? Is trans removal a one man job? Easier than a VW,top starter bolt is a bitch to get at till you drop the trans down a bit before blocking the motor up. Get on to it soon before the leak ruins your clutch disk,make sure you replace the throw out lever cup bush and the sliders for your bearing. I made a wooden base for my jack and strapped the trans to it....then its a one man operation. |
| Ferg |
Apr 19 2017, 02:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Depending on how dirty it is source of leak can be confusing.
Before you drop it make sure it's not an easier fix like the output shaft seals. |
| saigon71 |
Apr 19 2017, 03:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
The leak from the bell housing is most likely the input shaft seal.
I started losing a lot of tranny fluid from that area last year. Not wanting to take the car off the road, I kept driving it. The leak sprayed on my brand new Sach's clutch, causing it to burn out in about 4000 miles. It's not a bad job. I put a screw in the old one and slide hammered it out. Used a piece of PVC to drive the new one in. |
| yellow75 |
Apr 19 2017, 08:10 PM
OK you have given me faith. I have good tools and a hydraulic floor jack. Also have a furniture dolly. Do I have to loosen the motor mounts as well or will the motor sag enough, (supported of course) to pull the trans out? I suppose the muffler has to go as well. HE's can stay as I see it. I may just do the clutch TO bearing and pressure plate while i'm in there. the car has 68K original miles so it may be due. Hate to take it out twice. I will re-seal the whole gear box while it's out as well I think.
| Dave_Darling |
Apr 19 2017, 09:47 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Loosen the motor mount bolts, it reduces the strain on the rubber part of the mounts when you tilt the motor. Remove the muffler, but the exchangers can stay.
--DD |
| falcor75 |
Apr 19 2017, 09:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
Loosen the motor mount bolts, it reduces the strain on the rubber part of the mounts when you tilt the motor. Remove the muffler, but the exchangers can stay. --DD Thats how I did mine. Remember to stock up on new driveshaft seals and M8 Schnorr washers before you put it back in there again. |
| euro911 |
Apr 19 2017, 10:51 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
You might contact Mark Heard (914Sixer) to see if he still has any OEM German input shaft seals left.
While you're in there, might not be a bad idea to remove the flywheel and replace the motor's rear main seal too (with a Sabo brand) http://www.ebay.com/itm/Sabo-029105245-Eng...1KG&vxp=mtr GoWesty recommends this brand and there are many happy campers (literally) benefiting from them. and a new flywheel O-ring (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:53 PM |
