4 Pages V < 1 2 3 4 >
> front trunk springs, both versions
funk
post Jun 8 2017, 08:01 PM
Post #21
a set for me to please. Can't pay till july? I hope that's OK
ValcoOscar
post Jun 8 2017, 10:18 PM
Post #22
Garage Life
I'm in as well...
orthobiz
post Jun 9 2017, 04:37 AM
Post #23
I would like a set. But the spring rate is important...A few of years ago I was at Brad Mayeur's with severely sagging springs. He took a bunch of springs he had on hand and kept replacing mine until we had a pair that held the hood up in the third (last) notch.
So, I don't know what original spec is, but if the supplied spring you gave did not match the original you could wind up (hey, a spring term!) with a sagging replacement spring.
Otherwise, I'm in for two pairs! Great idea!
Paul
Jasfsmith
post Jun 9 2017, 06:42 AM
Post #24
I'm in for two sets.
James Smith
Mark Henry
post Jun 9 2017, 07:37 AM
Post #25
that's what I do!
QUOTE(McMark @ Jun 8 2017, 03:21 PM) *
I'd take a set in hopes of making the hood sit higher.
I hate the gas strut conversion! Especially on the front. I really don't see the benefit compared to a stock spring/torsion setup.
AND
Gas struts definitely wear out faster than springs.
I've been hit in the head too many times because of failing gas struts.
IMPO on the rear trunk of a 914 they are in the way.
I'll have to look at mine, not a big deal but I know it doesn't open the last inch or so.
live free & drive
post Jun 9 2017, 07:43 AM
Post #26
I'd be I for a set as well.
914-300Hemi
post Jun 9 2017, 08:04 AM
Post #27
I'm in a for a set.
peteyd
post Jun 9 2017, 09:46 AM
Post #28
I put in a PO for the springs. They will give me a sample set, then I will test fit them. If the spring rate is correct I will give the go ahead. 4 weeks out, so when they are ready I will update this thread with pictures.
Pete
rmdinmd
post Jun 9 2017, 02:10 PM
Post #29
I would be interested in a set as well.
maf914
post Jun 10 2017, 05:55 AM
Post #30
Not a Guru!
I am in for a pair if this happens. Thanks, Pete.
914Sixer
post Jun 10 2017, 08:29 PM
Post #31
Never pulled a set of springs off any car that I could use for replacements. A very needed product.
23e Heure
post Jun 11 2017, 04:07 AM
Post #32
Busy overtaking 911s
Region Association: England
Yes please for one set! (If you would be willing to ship to UK).
Kansas 914
post Jun 11 2017, 08:45 AM
Post #33
I am in for at least one set.
peteyd
post Jul 31 2017, 02:42 PM
Post #34
The springs are ready.
http://www.restoration-design.com/store/product/PP336S
Mblizzard
post Jul 31 2017, 03:14 PM
Post #35
Ordered!
Now I can get it fully up!
bandjoey
post Jul 31 2017, 03:29 PM
Post #36
bandjoey
Can you make a new body for say, $10k? (IMG:style_emoticons/default/biggrin.gif)
peteyd
post Aug 1 2017, 07:20 AM
Post #37
Here is a little video on instagram of the springs in action.
https://www.instagram.com/p/BXQKR92AVKr/?ta...sign1&hl=en
Morrie
post Aug 1 2017, 01:20 PM
Post #38
I looked at the instagram video and can't tell what hook you have the springs on. Ideally it would be on the lightest tension (closest to dash) or close to it so if they do wear with time there is some adjustment?
peteyd
post Aug 1 2017, 01:48 PM
Post #39
QUOTE(Morrie @ Aug 1 2017, 11:20 AM) *
The springs in the video are in the middle position. I had them on the lightest tension and they held up the hood, but they didnt "pop" the hood up like the middle position did.
These springs will have to go through another couple thousand expansions to loose the spring rate. This is what the spring manufacturer told me.
Pete
Ed_Turbo
post Aug 1 2017, 01:54 PM
Post #40
Anyone know a good tool to stretch and place these springs? Maybe like a coil spring compressor just use it in reverse?
- Lo-Fi Version Time is now: 2nd April 2026 - 11:55 AM
