| mlindner |
Aug 18 2017, 11:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,749 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
My cost was only a few hundred for cement and around $60 for a rented cement saw (it was brand new....cut the cement like butter). It took a weekend to cut, remove cement, frame up and pour. Its a great lift....but better yet its the greatest 4 x 8 foot work bench you'll ever have. Mark
| euro911 |
Aug 18 2017, 12:24 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
I also have a BendPak mid-rise. It's currently positioned in the driveway near the back of my house, however, if I ever decide to replace the cracked concrete in my garage, I'll probably do the pit and an accessible trench for utilities.
If you're worried about the tile, you could position a couple 2x6 slats on the floor before lifting the car (IMG:style_emoticons/default/idea.gif) |
| Cairo94507 |
Aug 18 2017, 05:37 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Thanks so much guys. I really appreciate all of the feedback. I contacted a couple other vendors with different lifts and so far the BendPak is in number one position.
Yeah, I will measure my car (next weekend when I get my next "visitation" at Kent's) and make sure I position the pit/lift so it clears everything. I will be trenching to the electrical panel and adding a dedicated circuit just for the lift. If I get the choice of going 220 I will do that. If not, 110 is fine. My 4-post was 110 and worked great-it was a lot heavier too. I will add a empty 2" conduit pipe that goes in the wall, then in the ground and to the lift just for any possible future stuff I might want there. I know I will be running a dedicated air line to lift to release the locks. So I might also stub out an air fitting in the pit too so I can plug in right there with out having to drag a hose across the floor. I am trying to think of all of this so that I do it right the first time. The floor with be a PE5 (I think that is how it is rated) grade porcelain. That is the highest grade they have and the best for this type of application. If you have not been to Garage Journal and seen Dakota's thread re his floor, you should check it out https://www.garagejournal.com/forum/showthr...=porcelain+tile. Additionally, he has a separate thread all about tiling your garage and what one should know if you go down that road. http://allgaragefloors.com/porcelain-garage-floor-questions/ I gave my contractor the green light to book the job and do it. I hoe he will be able to get to it in the next 30 days. |
| euro911 |
Aug 18 2017, 06:22 PM
I don't know Jack ... (IMG:style_emoticons/default/rolleyes.gif)
... but there's a video of his nifty garage https://www.youtube.com/watch?v=/uOuwPyeMJGY |
| Cairo94507 |
Aug 18 2017, 09:05 PM
Definitely my inspiration and goal for my lift. I love his 911 too.
| kahluver |
Aug 18 2017, 11:49 PM
Newbie ![]() Group: Members Posts: 49 Joined: 3-October 14 From: Huntington Beach, ca Member No.: 17,973 Region Association: Southern California |
Tile works fine if installed correctly. If it's good enough for these guys, it's good enough for me.
(IMG:http://www.914world.com/bbs2/uploads_offsite/autostoneusa.com-17973-1503121750.1.jpg) |
| euro911 |
Aug 19 2017, 02:04 AM
Tile or not ... would love to have a garage like that (IMG:style_emoticons/default/drooley.gif)
Lo-Fi Version | Time is now: 2nd April 2026 - 11:56 AM |
