> How many turns on a lug not for saftey?, put on 7mm spacer..only get 6 full turns
jim912928
post Nov 7 2004, 04:57 PM
Ok...I've got the silver 914 with the boxster rims. For a short time (so I could drive it some)...I put the 6" wheels in the back and the 7" wheels in the front (I'm running 205 50 16"'s. Backspacing worked great this way. This weekend I went to work on getting the 6" rims in the front and the 7" rims in the back. Rears fit perfect and the fronts, as expected..sit in some. I put some 7mm spacers on the front to pull them out alittle. Now I only get 6 full turns on the lug nuts from first thread catch to full torque down at 97 ft/lbs. Is this too few turns to be safe?
My alternatives are...add longer wheel studs or get two 7" rims to match the rears (7X16" boxster rears with the 40mm offset fit perfect front and rear). I do have a line on 2 7" rims so that isn't a problem.
Thoughts?
davep
post Nov 7 2004, 05:01 PM
914 Historian
The rule of thumb is to get an engagement depth equal to the thread diameter. I'd guess you are a little shy.
Katmanken
post Nov 7 2004, 07:08 PM
You haven't seen me if anybody asks...
I'm goin through this trying to put Mercedes alloys on my Vanagon.
They say ya need 7 to 7.5 full turns so yes, you are a little shy.
However, found this place with lotsa longer 14mm x1.50 ball seat lug nuts. I think the alloy teener bolts have a 38mm long shank if my memory serves. Tried them and they were still too short. You might try 40''s or 43's/
http://www.pure-motorsport.com/products/ca...php/CA=47/PA=10
Ken
Joe Bob
post Nov 7 2004, 07:10 PM
Longer studs are an easy solution.....
post Nov 7 2004, 07:11 PM
Resident German
QUOTE(jim912928 @ Nov 7 2004, 03:57 PM)
i wouldn't run it.
get a set of 70mm studs. they're easy to come by and fairly cheap.
that'll give you plenty of thread ...
(IMG:style_emoticons/default/cool.gif) Andy
Eric_Shea
post Nov 7 2004, 07:19 PM
PMB Performance
PCA Rules say 14mm needs to be threaded (they actually say, as mentioned earlier, depth = width of stud, which is 14mm)
I put 7mm spacers on the back of the RS Clone and I restudded. It's funny, it's only about 1/4" but...
J P Stein
post Nov 7 2004, 07:55 PM
Irrelevant old fart
IIRC, 9 turns is what you want. I restudded.
jim912928
post Nov 7 2004, 08:19 PM
I figured 6 was light...thanks all!
Joe Bob
post Nov 7 2004, 08:29 PM
Use an open head lug nut as a guide. If you catch all the threads on that....yer golden. (IMG:style_emoticons/default/biggrin.gif)
jim912928
post Nov 7 2004, 08:57 PM
Mike...just ran out and did that...stud makes it through the rounded portion of the nut but stops at the boxed end of the nut...so, only about half way.....so, that answers that for me!
Thanks
Joe Bob
post Nov 7 2004, 09:09 PM
Sounds like ya need longer studs then,,,,easy....remove the ebrake assembly and pound them out. Install the new ones and use a spacer, open headed nut and air tool. Last few turns will more than likely require a breaker bar and muscle.... (IMG:style_emoticons/default/rolleyes.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 07:03 AM
