| bryans914 |
Mar 2 2018, 03:12 PM
Newbie ![]() Group: Members Posts: 12 Joined: 18-May 12 From: Laguna Niguel, CA Member No.: 14,449 Region Association: Southern California |
(IMG:style_emoticons/default/WTF.gif)
Need source for 962 style lower A arm for coil over on 914-6. I attached a pic. Need to replace 8 ea 16" Fuchs/barrels with 18" inexpensive steel or mixed material race wheels. The Fuchs are breaking with 450/500bhp. Sources? Attached thumbnail(s) |
| burton73 |
Mar 2 2018, 03:41 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Are you Fuchs real or copies? Fuchs are used on Turbo Carrera’s
Bob B |
| mepstein |
Mar 2 2018, 03:58 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| rgalla9146 |
Mar 2 2018, 04:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Fuchs barrels ?
Are your wheels built up from Fuchs centers ?.....then they're not Fuchs anymore. High horsepower is breaking front suspension.....and wheels on a 914 ? |
| jmitro |
Mar 2 2018, 05:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
one of these should be more than enough:
http://www.rebelracingproducts.com/914products.html https://www.elephantracing.com/porsche/914/...system-for-914/ |
| infraredcalvin |
Mar 3 2018, 01:39 AM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,737 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
You may want to stop hitting the gators on track...
You’re local to me, would love to see more pics of your car... |
| bryans914 |
Mar 3 2018, 01:18 PM
Are you Fuchs real or copies? Fuchs are used on Turbo Carrera’s Bob B They are Fuchs centers in 10.5" and 12.5" x 16" barrels. Two damaged, six ok., want to go to same in 18" due to used time supply, 16" tires are somewhat limited too Hoosiers. Will sell if I find 18s. |
| jd74914 |
Mar 3 2018, 01:21 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Do you have a better picture of that control arm? It looks pretty easy to fabricate from scratch...
| bryans914 |
Mar 3 2018, 01:34 PM
Fuchs barrels ? Are your wheels built up from Fuchs centers ?.....then they're not Fuchs anymore. High horsepower is breaking front suspension.....and wheels on a 914 ? Centers, see above. POC Drivers and mechanics say these old Fuchs centers are breaking. My right rear went, car spun 180,snagged pit wall and slapped pit wall hard. Broke bell housing in 4 places, bent rear reinforced swing arm, both axles punched clean holes in the CV joints caps. Front arm was bent by wrapped front wheel. I need a source for the 962 style lower A arm. So right rear and right front suspension damage, and no cage damage. I have a rear swing arm from this site and a new reinforcement kit. |
| bryans914 |
Mar 3 2018, 01:39 PM
| sixnotfour |
Mar 3 2018, 01:44 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
there is several version of fuch 3 piece centers, one guy in Ca makes them pretty thin at the joint area cross section, I never buy that type..
| bryans914 |
Mar 3 2018, 02:09 PM
You may want to stop hitting the gators on track... You’re local to me, would love to see more pics of your car... Randy Beck built up the car, I've had it 24 years, last complete rebuild, cage replace, body, twin turbo, twin plug, 3.3L, and recently Steve Parker did some venous fabrication and sorted out the EMS, etc. It weighs 1700lbs wet, I'm185. Attached thumbnail(s) |
| bryans914 |
Mar 3 2018, 02:19 PM
| bryans914 |
Mar 3 2018, 02:24 PM
one of these should be more than enough: http://www.rebelracingproducts.com/914products.html https://www.elephantracing.com/porsche/914/...system-for-914/ Thanks! I saw some steel wheels on #75 914, V8, on YouTube. I will get on the sites you sent. |
| bryans914 |
Mar 3 2018, 02:33 PM
Fuchs barrels ? Are your wheels built up from Fuchs centers ?.....then they're not Fuchs anymore. High horsepower is breaking front suspension.....and wheels on a 914 ? Centers are Fuchs, barreled are mixed BBS and other, so 3 piece. Wheel broke, spun counter clockwise and smacked pit wall hard. |
| bryans914 |
Mar 3 2018, 02:38 PM
Are you Fuchs real or copies? Fuchs are used on Turbo Carrera’s Bob B And 935's, rally cars, ect. Fuchs, centers, 3 piece. Want 18", 10 and 12 wide steel race wheels. Also need source for front lower A arm, 962 type for coil over. |
| Larmo63 |
Mar 3 2018, 04:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
There are basically two really good choices with clickable links above. Elephant racing makes the most
exotic (expensive) version, then there is the Rebel Racing set too. These of course require coiler set-ups, as you know. Good luck, and we need a LOT of pictures. |
| Mueller |
Mar 3 2018, 05:00 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
http://www.diamondracingwheels.com/index.p...detail?Itemid=0
They show 18" diameter Set of Fikse wheels on eBay for a Porsche right now in that 18x10 and 18x12 size https://www.ebay.com/itm/Porsche-Fikse-Prof...uEAAOSw8stZ38J2 |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:38 PM |
