Heater cable vent bolt, Heater cable vent bolt |
simonjb |
May 13 2018, 04:24 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Need some help/advice
I managed to lose one of the small bolts that has a hole through it so that the heater cable wires can connect to the lever Do I try to make one - or are these available ? I can't seem to find the part number. |
mgphoto |
May 13 2018, 09:32 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
They are called barrel nuts, it's the same nut on the accelerator cable, at the throttle body.
They are still available. Sorry my mistake, I though you were referring to the heat exchanger end. The ventilation switch is a single part, according to the parts book. You may have to find a used one. |
simonjb |
May 14 2018, 07:32 AM
mgphoto |
May 14 2018, 03:59 PM
simonjb |
May 14 2018, 07:17 PM
I found it on eBay and then googled it
Lo-Fi Version | Time is now: 16th June 2024 - 07:15 PM |
