2 Pages V < 1 2
> Trouble shooting injectors
Dave_Darling
post Jul 31 2018, 10:22 AM
Post #21
914 Idiot
Do you have a "noid light"? Or some other light that can react to very short power pulses? If so, plug that into an injector plug to see if the electrical signal is getting there when the starter cranks.
The MPS is the hand-grenade thing with one hose and a four-wire plug going to it that sits below the battery. The trigger points are in the base of the distributor, with the three-wire plug down in front of it.
Again, check all of the wires, plugs, and hoses. Make sure nothing has come loose.
--DD
Chris914n6
post Jul 31 2018, 03:42 PM
Post #22
Jackstands are my life.
Next step is to trigger the injectors manually under pressure, jumper wires to the battery. I like to use gator clips on the injectors and tap, just tap, the battery post repeatedly.
A volt meter will pick up on the pulses from the ecu, but just barely as they don't react fast enough. A test light would work better, specially if it's LED. I'll need to read up on trigger testing, it's old tech in my world.
Fresh gas is the best cleaner of old gas. They will clean themselves with use, but not like new clean like the ultrasonic cleaning does.
Considering one of the members blew a hole in his piston on a freshly rebuilt motor from the injector spraying a stream instead of a mist, might be worth it to get them cleaned anyways.
LanceW3544
post Jul 31 2018, 05:56 PM
Post #23
I was able to manual test the injectors. Directly powering them from the battery they all spray great! where to dig next?
ECU?
Relays?
Tirggers?
Thank you everyone for your time and participation. Very grateful
Chris914n6
post Jul 31 2018, 07:38 PM
Post #24
Most likely injector trigger.
https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot
Dave_Darling
post Jul 31 2018, 09:11 PM
Post #25
914 Idiot
Again, check all of the wires and hoses to make sure they are plugged in.
--DD
LanceW3544
post Aug 1 2018, 05:42 AM
Post #26
QUOTE(Dave_Darling @ Jul 31 2018, 09:11 PM) *
--DD
Thanks for the reminder Dave. (IMG:style_emoticons/default/smile.gif) I believe that I do have them all plugged in but lets go step by step and make sure. Here I image one is the back of the Dizzy which should have a plug with three wires
Here are the grounds for the injectors. I was fearful of their connections So I have made them a new ground here.
Here is an image of the intake pipe which has a vacuum line that runs over the piece that connects to the Dizzy.
Then the last picture is to the hand grenade looking thing that attaches to the passenger rear fender wall.
What else should I be checking?
mgphoto
post Aug 1 2018, 09:01 AM
Post #27
"If there is a mistake it will find me"
Pump keeps running after the 2 second interval means someone fiddled with the relays on the relay board.
LanceW3544
post Aug 1 2018, 09:17 AM
Post #28
QUOTE(mgphoto @ Aug 1 2018, 09:01 AM) *
All three relays are there. Are each of them interchangeable?
mgphoto
post Aug 1 2018, 09:27 AM
Post #29
QUOTE(LanceW3544 @ Aug 1 2018, 08:17 AM) *
They are interchangeable but they must align correctly, the pins will fit and you may get some function.
The relays will fit in the socket several different ways but only one is correct.
Dave_Darling
post Aug 1 2018, 09:36 AM
Post #30
914 Idiot
QUOTE(LanceW3544 @ Aug 1 2018, 04:42 AM) *
Make sure those are plugged in solidly.
Check the CHT connector. It's near the #3 spark plug; a single wire comes out of the engine tin and goes into a plastic box connector. Sometimes the connection gets broken but the wires still go into the box.
Do you know if the ECU is getting power? You can remove the ECU and check its connector for power on the correct pins. You could also turn the key on and then grab the throttle and open it. If you hear the injectors click (it will be about 10 times), then you know the ECU has power and can send it to the injectors. If you don't hear them click, it's not definite that the ECU isn't getting power, but it shows something isn't allowing the injectors to open at all...
--DD
LanceW3544
post Aug 2 2018, 03:21 PM
Post #31
pulled all the relays which I have done before and firmly pushed them all down. For some reason this time something was different. I put about 20 miles on it thus far. Run but bucks a low RPM.
Thank you everyone for your help. You all have been great!
Chris914n6
post Aug 2 2018, 03:39 PM
Post #32
Sounds like common corrosion. Give all the connectors a good cleaning.
Bartlett 914
post Aug 2 2018, 04:28 PM
Post #33
QUOTE(LanceW3544 @ Aug 2 2018, 04:21 PM) *
Are you talking the round relays on the relay board? Move them around to different positions. This will help rule out bad relays. They can develop bad contacts internally. I have seen small particles of rust that can interfere with the relay coil / armature motion
TheCabinetmaker
post Aug 4 2018, 12:26 PM
Post #34
I drive my car everyday
One of those relays powers the injection system. The 4 pin connector on the rear drivers side of the board will leave the injection inop if it's not plugged in.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 06:26 AM
