| mskala |
Oct 16 2018, 06:58 AM
R ![]() ![]() ![]() Group: Members Posts: 1,942 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
IMO, if you use _new_ schnorr washers each time, then having grease-free threads
is not necessary. I've installed and removed a bunch of times, I could never get the area clean while still having grease everywhere you need it. I've checked the torque before each autocross, they have never loosened even a little. |
| Bartlett 914 |
Oct 16 2018, 09:22 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have said this and I will say it again. When the cv comes loose, it distorts the output flange. It causes the threaded holes to be pulled out slightly. This no longer allows the cv to sit perfectly flat to the output flange. This is the main cause of cv's coming loose. Remove the output flange and turn a cleanup cut on the face. The material is not hardened and it cleans up nicely. Twice my cv's came off in a years time. I discovered this issue. They remain tight to this day
| burton73 |
Oct 16 2018, 09:44 AM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Yep https://shop.914rubber.com/914-CV-bolt-dril...m?categoryId=-1 Got the wire and tool if you need it. Also just the Schorr washers .20 each https://shop.914rubber.com/Schnorr-washers-...-part-SCHM8.htm Just get these from 914rubber and be done. Bob B |
| porschetub |
Oct 16 2018, 01:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Rebuilding my CV joints and noticed my car was missing one roll pin and had no schorr washers ! Replacing all the bolts, adding the washers. Amazed the car did not have any issues running just on roll pin on one of the joints. I guess low power application helps ! What is the torque spec for the CV bolts? Haynes says 31lbs, others say 25 lbs Do mine @ 30lbs seem to remember Eric @ PMB stated something like that,the bolts are strong enough to take it and yes make sure they and clean and inspect the threads and bin any damaged ones. |
| TravisNeff |
Oct 16 2018, 02:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
I bought a big bag of the schnorr washer from McMaster
| Jeff Hail |
Oct 16 2018, 06:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Good morning-hope everybody had a good weekend. It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts. Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them? Thanks in advance for the help, have a good morning. "spring waters "? [b]Self loosening axle bolts-will spring waters take care of this? [/b] Sure as natures Lock-Tight it will help. A little rust will keep them from backing out. |
| jfort |
Oct 16 2018, 06:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
My notes to myself:
Axle bolts: 6mm Allen (after market wire drilled) on the inner side, 8mm 12 point on the outer side. Torque to 30 ft-lbs |
| jim_hoyland |
Oct 16 2018, 07:43 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Nice info here on Schnoor washers:. https://schnorr.com/products/safety-washers/
Lo-Fi Version | Time is now: 2nd April 2026 - 07:43 AM |
