| Rjmathison |
Jun 22 2019, 01:15 AM
Newbie ![]() Group: Members Posts: 17 Joined: 21-August 16 From: Tacoma WA Member No.: 20,321 Region Association: Pacific Northwest |
I have a 76 2.0 (owned for 27 years) and it still has all the original stock suspension components/sway bars. The front has been squeaking for years and I’m finally ready to address the issue(s).
Without breaking the bank, what should I order/install. The car has 55k original miles and is only driven during the summer on the streets. Any advice/input greatly appreciated!! |
| Mikey914 |
Jun 22 2019, 01:18 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
A arm bushings are probably the primary issue Not super easy, but Ian did a really good video
https://900designs-container.zoeysite.com/c...-install-tool-1 https://www.youtube.com/embed/5AysZlHr2lM Also get more that the 4 bushings in case you mess one up. We will take back what you don't use no problem. |
| Rjmathison |
Jun 22 2019, 02:28 AM
A arm bushings are probably the primary issue Not super easy, but Ian did a really good video https://900designs-container.zoeysite.com/c...-install-tool-1 https://www.youtube.com/embed/5AysZlHr2lM Also get more that the 4 bushings in case you mess one up. We will take back what you don't use no problem. Thanks Mike !! I was planning on placing an order with you ! What’s your opinion on poly bushings vs the rubber ones ? |
| Cairo94507 |
Jun 22 2019, 06:26 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I went with rubber in my car since I am not going to track it or auto-X it. In my experience the poly bushings tighten up the suspension for better handling, but at the cost of squeaking at times. I wanted to keep my car comfortable and quiet for the street and long drives. Rubber was my choice. Good luck. (IMG:style_emoticons/default/beerchug.gif)
| Mark Henry |
Jun 22 2019, 06:48 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
(IMG:style_emoticons/default/agree.gif) If it's the squeak you want gone use the rubber.
All other options are mo' money. |
| thelogo |
Jun 22 2019, 06:59 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I have a 76 2.0 (owned for 27 years) and it still has all the original stock suspension components/sway bars. The front has been squeaking for years and I’m finally ready to address the issue(s). Without breaking the bank, what should I order/install. The car has 55k original miles and is only driven during the summer on the streets. Any advice/input greatly appreciated!! Once you start pulling apart 27 year old suspension The bank may get broken . If its just the arm bushings then great But id prepare myself for something more expensive (While your there , you may find other things ) Brake lines .... Ball joints ....struts .... It never ends (IMG:style_emoticons/default/sawzall-smiley.gif) |
| 914werke |
Jun 22 2019, 08:28 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
(IMG:style_emoticons/default/agree.gif), if you are going to tear the front end down to rebuild the A arms it only make sense to rebuild the wear items that exist.
Ball joints & Tie rod ends (Turbo) are 1st on that list. Strut (inserts) are relatively easy can be done anytime and so I wouldn include them in this mix. I see you are (semi) local so if you need some help or advice drop a line (IMG:style_emoticons/default/bye1.gif) |
| iankarr |
Jun 22 2019, 09:55 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
(IMG:style_emoticons/default/agree.gif) 1000% Do it all together, then you'll also only need one alignment done. Definitely go for the turbo tie rods. Huge difference!
PS Thanks, Mark for the thumbs up on the video (IMG:style_emoticons/default/wink.gif) |
| Rjmathison |
Jun 22 2019, 10:30 AM
Thanks for the quick response gents ! Time to place an order and get dirty!!!!
| dr914@autoatlanta.com |
Jun 22 2019, 10:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
lube all of the suspension bushings with ruglyde rubber lubricant, should have been part of a 914 major service. Will squeak no more
I have a 76 2.0 (owned for 27 years) and it still has all the original stock suspension components/sway bars. The front has been squeaking for years and I’m finally ready to address the issue(s). Without breaking the bank, what should I order/install. The car has 55k original miles and is only driven during the summer on the streets. Any advice/input greatly appreciated!! |
| Rjmathison |
Jun 22 2019, 12:50 PM
Thanks!!
| Mikey914 |
Jun 24 2019, 10:17 AM
A arm bushings are probably the primary issue Not super easy, but Ian did a really good video https://900designs-container.zoeysite.com/c...-install-tool-1 https://www.youtube.com/embed/5AysZlHr2lM Also get more that the 4 bushings in case you mess one up. We will take back what you don't use no problem. Thanks Mike !! I was planning on placing an order with you ! What’s your opinion on poly bushings vs the rubber ones ? Poly graphite will work, but is actually not as good as the rubber. |
| lierofox |
Jun 24 2019, 12:06 PM
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California
A arm bushings are probably the primary issue Not super easy, but Ian did a really good video https://900designs-container.zoeysite.com/c...-install-tool-1 https://www.youtube.com/embed/5AysZlHr2lM Also get more that the 4 bushings in case you mess one up. We will take back what you don't use no problem. Having done the job without using an install tool (Heat and soap. Lots, and lots, and LOTS of soap, I don't think I've ever seen the workbench so clean) my suggestion is: use the damn install tool. |
| Rjmathison |
Jun 24 2019, 12:18 PM
Great advice ! Thanks
Lo-Fi Version | Time is now: 2nd April 2026 - 12:19 PM |
