2 Pages V < 1 2
> Could use a hand..., First time motor pull....
iankarr
post Jun 13 2019, 07:33 AM
Post #21
QUOTE(bdstone914 @ Jun 13 2019, 09:00 AM) *
@Tjmrfe
I would be very interested to see if the Quik Jack can lift the car high enough to clear the engine coming out the back.
Removing the filler neck reduces the engine hieght.
It can be done alone but it good to have a helper to watch that it comes out well with nothing catching.
And do you have those rubber blocks for thto give a couples inches more height.
Bruce
Hey Bruce...
Yep. I've been doing it with Quick Jack. With the standard blocks you just have to take off the rear valance.
VaccaRabite
post Jun 13 2019, 10:30 AM
Post #22
En Garde!
QUOTE(cuddy_k @ Jun 13 2019, 09:33 AM) *
@Tjmrfe
Bruce
Hey Bruce...
I bet if you only put blocks on the rear that would be enough angle to not have to remove the valence.
The Quickjacks that I have used have all been taller then my 3 ton jack.
IIRC you need 19 inches off the floor to get the engine out.
Zach
iankarr
post Jun 13 2019, 01:11 PM
Post #23
Actually...using the tall blocks that come with the QJ allows the engine to clear...but they're a little less stable. I feel more comfortable just removing the valance and going with the short blocks.
Tjmrfe
post Jun 13 2019, 02:34 PM
Post #24
NON IMPEDING RATIONE COGITATIONIS
QUOTE(cuddy_k @ Jun 13 2019, 11:11 AM) *
I removed valance, wasn’t too bad, and have her up on short blocks...we’ll see...
Tjmrfe
post Jul 13 2019, 04:43 PM
Post #25
QUOTE(bdstone914 @ Jun 13 2019, 05:00 AM) *
@Tjmrfe
Bruce
Hi,
Been a bit busy, but yes, the quick jack was perfect, took the rear valance off...and used a Tangerine support plate on my floor jack, the quick jack was a big help, allowing the to raise and lower with the touch of a button....bought it used, and saved 1/2. I highly recommend it.
Tjmrfe
post Jul 13 2019, 06:14 PM
Post #26
QUOTE(mepstein @ Jun 13 2019, 03:39 AM) *
Get a Tangerine jack plate and make it an easy, one person effort. Most people only regret not buying one sooner.
http://www.tangerineracing.com/tools.htm
I did and I can’t imagine doing it with out it? Wow...motor definitely would have tipped....thanks.
Tjmrfe
post Jul 13 2019, 06:17 PM
Post #27
@Tjmrfe
Bruce
Yup she worked like a dream, that QJ was ideal.
I removed rear valance, and took off entire F.I. Assembly....slid out like butter...
Bleyseng
post Jul 14 2019, 11:05 AM
Post #28
Aircooled Baby!
post Jul 14 2019, 11:23 AM
Post #29
Resident German
Bit late to the party but we do have a nice write-up in the "Technical Articles" section:
http://www.914world.com/specs/tech_engdrop1.php
Tjmrfe
post Jul 15 2019, 06:20 AM
Post #30
QUOTE(SirAndy @ Jul 14 2019, 09:23 AM) *
Thanks!....and yes I ended up using all the resources I could find. Worked out ok. I think the worst was, like FDR said,...the only thing I had to fear was fear itself...now that I’ve done it once, it’ll be a breeze from now on! Thanks for the input.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 09:34 AM
