| r_towle |
Mar 31 2020, 09:25 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Look at motor homes?
| KELTY360 |
Mar 31 2020, 10:36 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,185 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
Snake bit i guess . we had a deal at 11k But guy said . and i cant make this shit up Wife told him we need to exchange funds only at bank. That's not so strange. I've done exchanges at a bank before. Wife just being cautious. Are you sure you're not just getting in your own way of making a deal? |
| thelogo |
Mar 31 2020, 10:48 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Snake bit i guess . we had a deal at 11k But guy said . and i cant make this shit up Wife told him we need to exchange funds only at bank. That's not so strange. I've done exchanges at a bank before. Wife just being cautious. Are you sure you're not just getting in your own way of making a deal? Im sure and under normal circumstances i would go to the bank . but i went and got the cash in the first place. So i could close deals . not play games . The guy at first said bring the cash he will accept then changes his mind .... I just am not into playing games and wasteing time. When im putting out my money. And no one else is buying jack shit . And the bank right now is a health risk .period. I like the van but not enough to get sick . nothing is worth that Too much bull shit. |
| thelogo |
Mar 31 2020, 10:49 PM
| thelogo |
Apr 1 2020, 02:45 PM
Checking this one out next .
Seems beat up and not expensive So its suspect https://losangeles.craigslist.org/sfv/cto/d...7098747558.html |
| 914forme |
Apr 1 2020, 06:52 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
it is missing at least one digit on the ODO reading.
The V6 of that age has a couple of issues. Oil cooler seals leak, oil cooler is in the V of the engine and you have to remove the entire intake, and fuel system ha to be puled to get to it. For two seals, and problem solved. Fuel injector seals will blow out, and produce a leak, which creates this nice black carbon structure, which is a pain to clean up. Seat needs to be cleaned, and then the copper O needs replaced. Oil and engine blow by is sucked out of the valve cover into an area right infront of the turbo. That seal leaks, and it fills the turbo, and Intercooler with oil over a long period of time. Seal at the turbo inlet also leaks. And should be replaced, easy to do when you do the filter change. Maintenance Oil changes cost me about $180 in parts to do it right 10 quarts of oil. Trans oil changes where also about $280, every 40K Fuel filters every 20K Air filters needed to be checked at oil changes, mine had an affinity to suck all the small insects to large insects off the interstate. And the wold need replace 9 time out of 10. As the pressure built do to restrictive filters the oil draw off the vent system would increase. Oh it burned 2 Quarts of oil over the 10,000 mile interval, majority of it was from the breather system. I had a Mann Hummel recovery unit on it, I would get about 1.5 quarts out of the system. Positives, engine ran great, I had a tune done on it, and it would get 27 MPG, never noticed anything I had behind it. I would still be driving it, if I did not find a deal on two BMWs. |
| thelogo |
Apr 1 2020, 08:15 PM
it is missing at least one digit on the ODO reading. The V6 of that age has a couple of issues. Oil cooler seals leak, oil cooler is in the V of the engine and you have to remove the entire intake, and fuel system ha to be puled to get to it. For two seals, and problem solved. Fuel injector seals will blow out, and produce a leak, which creates this nice black carbon structure, which is a pain to clean up. Seat needs to be cleaned, and then the copper O needs replaced. Oil and engine blow by is sucked out of the valve cover into an area right infront of the turbo. That seal leaks, and it fills the turbo, and Intercooler with oil over a long period of time. Seal at the turbo inlet also leaks. And should be replaced, easy to do when you do the filter change. Maintenance Oil changes cost me about $180 in parts to do it right 10 quarts of oil. Trans oil changes where also about $280, every 40K Fuel filters every 20K Air filters needed to be checked at oil changes, mine had an affinity to suck all the small insects to large insects off the interstate. And the wold need replace 9 time out of 10. As the pressure built do to restrictive filters the oil draw off the vent system would increase. Oh it burned 2 Quarts of oil over the 10,000 mile interval, majority of it was from the breather system. I had a Mann Hummel recovery unit on it, I would get about 1.5 quarts out of the system. Positives, engine ran great, I had a tune done on it, and it would get 27 MPG, never noticed anything I had behind it. I would still be driving it, if I did not find a deal on two BMWs. Yes it was in sad shape the odometer had been switched At least the guy was honest about that when i asked (IMG:style_emoticons/default/bye1.gif) Rear main was leaking . cel light was on . A diaster But im considering staying far away from these for reasons stated in this post $$$$$$$ bleed |
| 914forme |
Apr 1 2020, 08:21 PM
Yes it was in sad shape the odometer had been switched At least the guy was honest about that when i asked (IMG:style_emoticons/default/bye1.gif) Rear main was leaking . cel light was on . A diaster But im considering staying far away from these for reasons stated in this post $$$$$$$ bleed Most likely not the rear main, Mercedes in the engineering wisdom made the weep drain for the engine V come out in the exact same spot. I would say 99% of the time it is oil cooler seals, still not a fun job, but better than a rear main. (IMG:style_emoticons/default/dry.gif) but not by much. Actually in a 2WD I would take the rear main over the oil cooler seal. Keep looking the right one is out there. |
| thelogo |
Apr 1 2020, 08:41 PM
Yes it was in sad shape the odometer had been switched At least the guy was honest about that when i asked (IMG:style_emoticons/default/bye1.gif) Rear main was leaking . cel light was on . A diaster But im considering staying far away from these for reasons stated in this post $$$$$$$ bleed Just seems like running a business out of 1 could be stressful . I dont mind being a dog trainer and a dog groomer But also a full time diesal mechinic . thats 3 big jobs Most likely not the rear main, Mercedes in the engineering wisdom made the weep drain for the engine V come out in the exact same spot. I would say 99% of the time it is oil cooler seals, still not a fun job, but better than a rear main. (IMG:style_emoticons/default/dry.gif) but not by much. Actually in a 2WD I would take the rear main over the oil cooler seal. Keep looking the right one is out there. I mean are these vans the gissell bunchen of vehicles Everybody loves the looks and wants one But so high maintence you end up regretting it Im trying to run a business and that requires a reliable vehicle |
| Superhawk996 |
Apr 2 2020, 06:21 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Keep in mind who you're buying from.
Previous fleet owned vehciles have pro's and cons. Some fleets maintain their vheicles well. Most don't. Most fleet managers view vehicles as a finite resource. The goal is to buy them as cheap as possible (stripped vehicles), run them hard, and minimize the money put into them. They then sell them for what is esentially salvage value to them. Then they buy a new one. Likewise, the guys driving corporate fleet vehicles usually don't give a rats behind about the vehicle either which doesn't help. On the other hand private owners usually have self serving reason to try to preserve thier own vehicle. There are cetainly private owners that skimp on maintenance too but a private owner is more likely to keep the vehicle well maintained. The bottom line is, keep looking for the right vehicle for you. You have cash in hand. You will eventually find the one that was well taken care of. As you know, mechanical condition supercedes cosmetic condition. You can always do a vheicle wrap to make it look nicer and promote your business at the same time. Likewise, you're largely going to strip the interior so interior appearance really isn't that important. Don't give up! |
| thelogo |
Apr 2 2020, 06:45 AM
Keep in mind who you're buying from. Previous fleet owned vehciles have pro's and cons. Some fleets maintain their vheicles well. Most don't. Most fleet managers view vehicles as a finite resource. The goal is to buy them as cheap as possible (stripped vehicles), run them hard, and minimize the money put into them. They then sell them for what is esentially salvage value to them. Then they buy a new one. Likewise, the guys driving corporate fleet vehicles usually don't give a rats behind about the vehicle either which doesn't help. On the other hand private owners usually have self serving reason to try to preserve thier own vehicle. There are cetainly private owners that skimp on maintenance too but a private owner is more likely to keep the vehicle well maintained. The bottom line is, keep looking for the right vehicle for you. You have cash in hand. You will eventually find the one that was well taken care of. As you know, mechanical condition supercedes cosmetic condition. You can always do a vheicle wrap to make it look nicer and promote your business at the same time. Likewise, you're largely going to strip the interior so interior appearance really isn't that important. Don't give up! I have not given up . And yes the sprinters so far have been fleet cars and sellers dont really know much aboit the cars . Next up is a ambulance with 189k on the clock. Gonna inspect and go. From there . https://losangeles.craigslist.org/sfv/cto/d...7088701989.html One of my customers who owns a vehicle wrap company has offered to wrap the van for free So i got that going for me And i should definitely try to buy within the next month ? |
| thelogo |
Apr 2 2020, 07:58 AM
| Superhawk996 |
Apr 2 2020, 08:10 AM
And i should definitely try to buy within the next month ? That one is a hard one to answer. The guy that does some of my landscaping has been in business forever. He buys his equipment during recessions when the other landscapers go out of business from having bought new Super Duty trucks, plows, and Bobcat's on debt thinking they could get rich off other people's money and debt leverage. I've maintained his Bobcat in exchange for landscaping services and I once traded him a utility trailer for some work. He's a fun guy and knows how to stay in business during good times and bad. No doubt there will be a lot of businesses that won't survive this self inflicted economic collapse and there will be more deals on durable equipment in the future. The question is how soon do you need to be in business and who are your clients? I think you previously stated they are very well do do (Malibu, etc.). In that case, they will largely remain financially unaffected themselves. Their current dog groomer that was in debt up to their eyebrows for a new Sprinter + custom grooming equiment on 84 months of payments, on the other hand might not make it. That leaves room for you to step in and fill a potential void as a cash business with paid for overhead. But honestly that is a really complex dynamic. How long to wait to buy equipment off the bottom vs. opportunity that may present itself sooner? Wish I had a simple equation for that one. I'm contemplating the same ideas as my current job is in automotive and I'll almost surely be laid off soon. Lots of opportunities out there but it's tough to decide which is the best move. |
| thelogo |
Apr 2 2020, 09:26 AM
And i should definitely try to buy within the next month ? That one is a hard one to answer. The guy that does some of my landscaping has been in business forever. He buys his equipment during recessions when the other landscapers go out of business from having bought new Super Duty trucks, plows, and Bobcat's on debt thinking they could get rich off other people's money and debt leverage. I've maintained his Bobcat in exchange for landscaping services and I once traded him a utility trailer for some work. He's a fun guy and knows how to stay in business during good times and bad. No doubt there will be a lot of businesses that won't survive this self inflicted economic collapse and there will be more deals on durable equipment in the future. The question is how soon do you need to be in business and who are your clients? I think you previously stated they are very well do do (Malibu, etc.). In that case, they will largely remain financially unaffected themselves. Their current dog groomer that was in debt up to their eyebrows for a new Sprinter + custom grooming equiment on 84 months of payments, on the other hand might not make it. That leaves room for you to step in and fill a potential void as a cash business with paid for overhead. But honestly that is a really complex dynamic. How long to wait to buy equipment off the bottom vs. opportunity that may present itself sooner? Wish I had a simple equation for that one. I'm contemplating the same ideas as my current job is in automotive and I'll almost surely be laid off soon. Lots of opportunities out there but it's tough to decide which is the best move. Yes i already have 19 clients who support this idea and are well to do and will be loyal customers But i am concerned that even if i build the van for 20k total . new fully outfitted vans cost 105 k to 150k I will have to work one hell of a long time to recoup that let alone make a profit. But one positive since im a dog trainer/ walker I can get more grooming clients from there and more training clients from grooming So i will in theory be maximizing my potential. or exposure To earn best money or stay busy But for training i used a old ford ranger. ( 3500 bucks)and did very well A sprinter is a whole nother animal. $$$$ But if i can make 20 x more money Im willing to spend some to make alot. " james t.kirk " (IMG:style_emoticons/default/beer3.gif) Risk is part of the game ... If you wanna sit in this chair |
| Superhawk996 |
Apr 2 2020, 10:01 AM
Don't forget the whole $20K isn't at risk.
If it doesn't work out, you can still resell the vehcile for about the same $10K price you're looking to buy for. Agree completely that $100K for a setup is (IMG:style_emoticons/default/screwy.gif) I inherited MIL's dog when we put MIL in assisted living. That little bugger needs more frequent and more expensive hair cuts than I get for myself. (IMG:style_emoticons/default/headbang.gif) And if you don't get the dog groomed often enough, it has (IMG:style_emoticons/default/stromberg.gif) stuck to the fur around it's butthole. Anyone want a "free" dog? (IMG:style_emoticons/default/av-943.gif) |
| mepstein |
Apr 2 2020, 11:19 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
And i should definitely try to buy within the next month ? That one is a hard one to answer. The guy that does some of my landscaping has been in business forever. He buys his equipment during recessions when the other landscapers go out of business from having bought new Super Duty trucks, plows, and Bobcat's on debt thinking they could get rich off other people's money and debt leverage. I've maintained his Bobcat in exchange for landscaping services and I once traded him a utility trailer for some work. He's a fun guy and knows how to stay in business during good times and bad. No doubt there will be a lot of businesses that won't survive this self inflicted economic collapse and there will be more deals on durable equipment in the future. The question is how soon do you need to be in business and who are your clients? I think you previously stated they are very well do do (Malibu, etc.). In that case, they will largely remain financially unaffected themselves. Their current dog groomer that was in debt up to their eyebrows for a new Sprinter + custom grooming equiment on 84 months of payments, on the other hand might not make it. That leaves room for you to step in and fill a potential void as a cash business with paid for overhead. But honestly that is a really complex dynamic. How long to wait to buy equipment off the bottom vs. opportunity that may present itself sooner? Wish I had a simple equation for that one. I'm contemplating the same ideas as my current job is in automotive and I'll almost surely be laid off soon. Lots of opportunities out there but it's tough to decide which is the best move. Yes i already have 19 clients who support this idea and are well to do and will be loyal customers But i am concerned that even if i build the van for 20k total . new fully outfitted vans cost 105 k to 150k I will have to work one hell of a long time to recoup that let alone make a profit. But one positive since im a dog trainer/ walker I can get more grooming clients from there and more training clients from grooming So i will in theory be maximizing my potential. or exposure To earn best money or stay busy But for training i used a old ford ranger. ( 3500 bucks)and did very well A sprinter is a whole nother animal. $$$$ But if i can make 20 x more money Im willing to spend some to make alot. " james t.kirk " (IMG:style_emoticons/default/beer3.gif) Risk is part of the game ... If you wanna sit in this chair "But i am concerned that even if i build the van for 20k total . new fully outfitted vans cost 105 k to 150k I will have to work one hell of a long time to recoup that let alone make a profit." ---You should know your numbers before you start the business. They shouldn't be hard to figure out. |
| thelogo |
Apr 3 2020, 07:37 PM
And i should definitely try to buy within the next month ? That one is a hard one to answer. The guy that does some of my landscaping has been in business forever. He buys his equipment during recessions when the other landscapers go out of business from having bought new Super Duty trucks, plows, and Bobcat's on debt thinking they could get rich off other people's money and debt leverage. I've maintained his Bobcat in exchange for landscaping services and I once traded him a utility trailer for some work. He's a fun guy and knows how to stay in business during good times and bad. No doubt there will be a lot of businesses that won't survive this self inflicted economic collapse and there will be more deals on durable equipment in the future. The question is how soon do you need to be in business and who are your clients? I think you previously stated they are very well do do (Malibu, etc.). In that case, they will largely remain financially unaffected themselves. Their current dog groomer that was in debt up to their eyebrows for a new Sprinter + custom grooming equiment on 84 months of payments, on the other hand might not make it. That leaves room for you to step in and fill a potential void as a cash business with paid for overhead. But honestly that is a really complex dynamic. How long to wait to buy equipment off the bottom vs. opportunity that may present itself sooner? Wish I had a simple equation for that one. I'm contemplating the same ideas as my current job is in automotive and I'll almost surely be laid off soon. Lots of opportunities out there but it's tough to decide which is the best move. Yes i already have 19 clients who support this idea and are well to do and will be loyal customers But i am concerned that even if i build the van for 20k total . new fully outfitted vans cost 105 k to 150k I will have to work one hell of a long time to recoup that let alone make a profit. But one positive since im a dog trainer/ walker I can get more grooming clients from there and more training clients from grooming So i will in theory be maximizing my potential. or exposure To earn best money or stay busy But for training i used a old ford ranger. ( 3500 bucks)and did very well A sprinter is a whole nother animal. $$$$ But if i can make 20 x more money Im willing to spend some to make alot. " james t.kirk " (IMG:style_emoticons/default/beer3.gif) Risk is part of the game ... If you wanna sit in this chair "But i am concerned that even if i build the van for 20k total . new fully outfitted vans cost 105 k to 150k I will have to work one hell of a long time to recoup that let alone make a profit." ---You should know your numbers before you start the business. They shouldn't be hard to figure out. Numbers work best with a 1st gen high miles van As i could get cheaper new vans with lower miles But repair cost over time will kill me The older ones is more affordable and easier to work on apparently If im going to be working on a sprinter and apparently if you have one you will . Early vans i think are more manageable pre 07 https://losangeles.craigslist.org/lac/cto/d...7095848139.html |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:37 AM |
