| bkrantz |
Apr 1 2020, 08:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
A 914 on salt? Are you crazy?
| oakdalecurtis |
Apr 1 2020, 08:18 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,407 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
| cali914 |
Apr 1 2020, 11:15 PM
cali914 ![]() ![]() Group: Members Posts: 458 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
looks like a 914 limo
| 76-914 |
Apr 2 2020, 08:22 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
There was one small, unanticipated technical problem, however, discovered during the very first test run. Since the mass of the huge engine was greater than the weight of the entire 914 body, when the driver punched the throttle on the initial run, the tremendous torque put out by the massive V12 caused the Merlin engine to stay still, and the lightweight 914's body to rotate around it! A fellow I worked for used the V12 engines (Merlin & Packard) in hydrofoil racing some 40 years ago. Flipping the boat was one problem when cracking the throttle too fast. The other outcome was to spin the prop into a ball since the shaft could rotate faster than the tips of the prop. He had a lot of stories to tell about the use of these engines. Warming them up slowly was necessary to keep oil pressure from blowing out weak sections of the case. These engines were not really designed for rebuilding since the expected service life of the engine greatly exceeded the expected life of the airframe; wartime naturally. This was true of the P-51's, also. Many a P-51 Jock's were killed on take off. You weren't supposed to apply full power on take off. Hands down, the sexiest sounding engine ever! Next to a Porsche anyways. (IMG:style_emoticons/default/biggrin.gif) |
| richardL |
Apr 2 2020, 09:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None |
“ I actually saw that car at Epsom Downs (horse) Race Course when i was a kid - simply astonishing” That’s a pretty neat trick since the whole story is a FOMI.... (IMG:style_emoticons/default/chair.gif) perhaps if you read the line I quoted - I was referring to 'The Beast' which very much did exist, and still does |
| oakdalecurtis |
Apr 2 2020, 10:35 AM
“ I actually saw that car at Epsom Downs (horse) Race Course when i was a kid - simply astonishing” That’s a pretty neat trick since the whole story is a FOMI.... (IMG:style_emoticons/default/chair.gif) perhaps if you read the line I quoted - I was referring to 'The Beast' which very much did exist, and still does My apologies richard..... (IMG:style_emoticons/default/beerchug.gif) |
| sixnotfour |
Apr 2 2020, 12:17 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Attached thumbnail(s) |
| oakdalecurtis |
Apr 2 2020, 12:55 PM
But can we fit a 914 body over it! |
| richardL |
Apr 3 2020, 01:27 PM
Here is The Beast at Epsom Downs Race Course in the '70s:
| Carbon-14 |
Jun 16 2020, 12:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 765 Joined: 7-May 20 From: Toronto, Ontario, Canada Member No.: 24,238 Region Association: Canada |
https://www.youtube.com/watch?v=eiZIU54WYxw A new idea, RR V12 into about any, thing. ![]() Power to weight. Cp. Fun and games with Dan Gurney at Bud Moore’s shop in 1966. Photo shows Dan found a use for one of the leftover 427 SOHC engines. https://youtu.be/exyzEFrmLuM?t=69 In other news of racer's speed engineering. https://www.youtube.com/watch?v=Z0rXyMwFMUI |
| 914_7T3 |
Jun 16 2020, 03:16 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
I think it's Jeffrey's car. He said he made one small modification from stock. @mepstein Just saw this thread and yes, felt that a slight bump in hp was in order. Also thought it would be cool to double up on the number of cylinders that the 6 conversions are running! The garage extension is almost complete..... (IMG:style_emoticons/default/laugh.gif) |
| Beebo Kanelle |
Jun 16 2020, 07:46 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
Funny, I always saw the Carrera GT as a updated 914, stretched to accommodate the V-10
| Carbon-14 |
Jun 16 2020, 11:03 PM
More fun and games, exposing a 914-RR12 to the salt.
An ejection pod might be well considered, auto 3speed transax. This is rediculous, the radiators mounted far forward, a venturi on the bottom. There is another, earlier, thread on this mad scratching. This is not too nutty, Ferrari transax. A 914 + big engine. +500 hp LS has a top end of 190 - 195, maybe. https://engineswapdepot.com/?p=56676 (IMG:style_emoticons/default/happy11.gif) he he Limousines can go some fast with a V8. . |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:15 PM |
